Question about Synergy Academic Kaleidagraph v3.6 for Mac (syn mac394) for Mac
Can't get a scatter plot.
I'm new to Kaleidagraph and can't get a scatter plot to work on it. I put my data in the columns and go to Gallery->Linear->Scatter. I change column A to the X values and column B-F as the Y values. When I click on New Plot a message comes up saying "Text data columns can only be used as the independent plot variable." I have no idea what to do and would appreciate some help. Thanks, Mike.
Invalid dim when zoomstat
Invalid dimension is displayed if the two columns have unequal length (number of elements).
Try plotting the scatter plot first, then worry with the Zoom.
Apr 11, 2014 | Texas Instruments TI-83 Plus Calculator
How to model real life data?
What is the question?
Put your calculator in STAT mode (2-var statistics or regression )
Enter your data in two lists, preferably sorted according to the x-value
Choose a regression model from the ones available and get the calculator to give you the best fit.
However to see which regression model best fits you data you need a graphing calculator to draw the scatter plot, then superpose on the scatter plot the curve of best fit given by the regression model.
Once you accept a model as the most suited one, you can use the equation of the curve to predict a y-value given an x-value (what ever REAL LIFE meaning they might have)
Dec 11, 2013 | Sentry CA 756 Calculator
I can't see all of plotted points in scatter plot
Try to set the Zoom window to ZoomStat, this way the scatter plot will display all statistical points in the data set.
Oct 06, 2013 | Texas Instruments TI-84 Plus Silver...
How do you make a residual plot? And I don't mean finding the residual line and plotting it in a regular scatter plot. I'm talking about a residual plot with a horizontal regression line at zero and the...
The simplest way would be to create a table where each x-value has a y-value that is the residual at the corresponding x. With a 2-list data set you can plot you residual plot.
Sep 22, 2013 | Texas Instruments TI-86 Calculator
I went to my table the other day, and accidentally deleted the Y column, do you know what I can do to get it back? thanks for your time.
The table corresponds to the values of a certain function you entered through the Y= Editor. Reenter the function as Y1= and the Y column will be regenerated.
If you are dealing with paired data ( statistical values) enter one variable in list L1 and the other in List L2 and use the statistical feature to draw a scatter plot or perform other data processing.
Jul 26, 2011 | Texas Instruments TI-84 Plus Calculator
Hi, I can edit my table information in my calculator but am not able to graph from it and when i go to table it shows nothing.. what do i do?
From what I understand you want to draw statistical graphs (scatter plot, box plot, etc.) If you do not see anything it may be due to the fact that the statistical plots are turned off.
Type in the data in lists L1 and L2, etc. Press [2nd][QUIT]
Press [2nd][Y=] (STAT PLOT] . Select [4:PlotsOff] [ENTER] .
Screen displays Done
Press [2nd][Y=] (STAT PLOT] . Select [1:Plot1 Off].
  1. The configuration screen for Plot1 opens with the cursor blinking ON.
  2. Press [ENTER] to turn Plot1 ON.
  3. Use Down Arrow to move cursor to second line Type:
  4. Select the type of statistical plot. Use the right arrow to move highlight on one of the 6 types.
  5. Select the type:scatter, Xline, histogram, box plot, and press [ENTER] to validate the choisce.
  6. Use down arrow to select the Xlist: use [2nd][1] to choose L1, etc. and press [ENTER]
  7. Select the Y-List (L2) and validate by pressing [ENTER]
  8. Select the data-point mark.
  9. Press [GRAPH].
If you do not see the graph or if it is not well centred, press [ZOOM][9:ZoomStat] to restrict the screen to the data entered.
Hope it helps.
Thank you for rating the solution.
Dec 09, 2009 | Texas Instruments TI-83 Plus Calculator
Graphing problems
From what I understand you want to draw statistical graphs (scatter plot, box plot, etc.) and you window is set up correctly. Usually, one must first see agraph and adjust the window, but no matter.
If you do not see anything it may be due to the fact thea the statistical plots are turned off.
  9. Press [GRAPH].
If you do not see the graph or if it is not well centered, press [ZOOM][9:ZoomStat] to restrict the screen to the data entered.
Hope it helps.
Dec 06, 2009 | Texas Instruments TI-83 Plus Calculator
How to draw histogram graph
When you finish entering you data, Press F2:Plot setup. Highlight
one plot number , say plot1, then press F1:define to define the type of plot you want plot1 to be. In the new window
Plot type : select histogram
x : enter the header of the column where you put data c1, c2 ?
Hist. Bucket width : enter the width of each band
Use frequency and categories:Yes
Frequencies : enter the name of colum where frequencies are.
Categories : column of categories (if any)
Include Categories: enter the categories that you want to use.
Press ENTER to save.
Configure the Window, then [Diamond][GRAPH].
A sound lnowledge of the theory behind the histogram is needed.
Hope it helps.
press Enter to save
Sep 24, 2009 | Texas Instruments TI-89 Calculator
Ti-89 help
You create a program by using the program editor. Press the "APPS" key and select "Program Editor".
What type of data graph do you want? The TI-89 can plot Scatter, XYline, Box, and Histgram graphs. Use the "Plot Setup" screen to select the desired plot type.
Apr 17, 2008 | Texas Instruments TI-89 Calculator
Graph plotting
Dear rachana, In MS word 2007 you can go to Insert then there are multiple graph patterns given in it, like column, pie and scatter chart. Just put your values in it and it click ok, you will get the chart on worksheet. Its that simple.
Please press fixya if that was helpful.
Nov 29, 2007 | Computers & Internet
Synergy Academic Kaleidagraph v3.6 for Mac (syn mac394) for Mac Logo
454 people viewed this question
Top Synergy Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Synergy Computer and Internet Expert? Answer questions, earn points and help others
