Question about Ovens
Oven element stays on
The oven element stays on i have tried unplugging it and plugging it back in. When i plug it back in it starts to heat up.
  • 229 Answers
You need to have your thermostat replaced it cycles the element on at of as it reaches temperature and drops below etc. this is a common problem with ovens and is not an expensive repair.
Posted on Nov 22, 2008
My electric Whirlpool oven won't heat after doing a self-cleaning.
It's possible the heating element burned in half while doing the self clean, it has to stay on a long time for the self clean cycle, try unplugging and plug it back in, might do it
Dec 06, 2014 | Whirlpool Ovens
Change bottom element
This is very easy to do. Unplug the over, take the racks out, when the heating element is plugged into the oven there should be two screws. Take them out an unplug the heating element. Plug in the new one which you can either order on line or get from an appliance repair company. They run between $35-50. But plug that in put the screws back in, plug the oven in an you should be ready to go. I've replaced 3 in my oven
Jun 28, 2014 | Zanussi Ovens
sounds like when you put it on bake only the broil element is coming on,when in bake both elements come on,set it to bake,does the bake element glow orange when it heats up,if not the element could be bad and the heat is coming from the broil element or you could be only getting 120 volts to the element,so start it and see if the element glows orange or after like 5 minutes touch the element with a wet paper towel and see if it's even getting hot at all,if not make sure you unplug it or flip the breaker before you go to remove the element,there's 240 volts going to it and power is there all the time,i've seen people try to take it out with the power on thinking that the oven isn't on and POP not only is the element bad but they took out the relay in the clock assy. to by doing that.if you want to write back and let me know what you find i'd be happy to help you if you need more help.
Feb 07, 2018 | Ovens
How do i replace oven element
Is it gas or electric ? If elect take two crews off and pull old element out carefully so u want unplug the two wires off .then unplug each wire and make sure it doesn't **** back in .if that happen u well have to take back off to get to wire. Make sure u unplug the power before u start LOL. If u need to clap wire first to make sure u don't lose it. Then plug in and push new one back in .. if gas take bottem plate out in side of the oven .two screws .one one each side or it could be a slide tab .then take off heat flame plate and u well see the ignitor .ether round or sq looken .two black 1/4 nut.they like to strip on u .its ok get them off and put alittle bigger ones in.check .match plug ends of the new to old see if match .if not cut plug of new ignitor and put old plug from ignitor and wire back on the new ignitor and install just how u took of old on off the gas tub
Nov 10, 2011 | Ovens
The oven stopped working and heating up. The top range part works.
I suspect a heating element in the oven has burned out. Some ovens have 2 heating elements, one on the bottom for baking and one on the top for broiling. If this is the case, you can try setting the oven on broil and see if the top element gets hot. Usually the bottom element fails first because food gets dripped on it. In most cases you can unplug the old heating element by just pulling on it and plug the new one just as easily. You can check the resistance of the heating element with an ohm meter. If it's burned out the resistance will be very high, probably greater than a mega ohm. In some cases you will need to take the back off the oven to replace the heating element. Just make sure the oven is unplugged and cool when you start working on it.
May 11, 2009 | GE Ovens
4 Elements and Oven not working
If there was a power surge when the power went out or came back on, it could have fried the controller.
Jan 16, 2009 | Frigidaire Ovens
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
Oven not heating up.
fault is the circular element found the fan. take back plate off inside oven and element is exposed. often but not always, you can see the damage to the element. element is easy to replace - usually held in by 2 - 7mm nuts on posts from the element base plate
Jul 06, 2008 | Stoves Ovens
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
93 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
