Question about iLO 3200 32 in. LCD Television
Sound and channels and menu not working
I was woundering if anyone went and had ad tech look at the tv. and what did they find on the sound, menu and channels not working
  • Tony Tony Dec 24, 2006
    Today i unpluged the s cable and pluged it back in now the tv works. i don't know why but it does.
  • momo601 Nov 21, 2007
    My ilo menu cant be brought up by the remote or the top button.
ESTIMADO DISTRIBUIDOR: TENGO UN TELEVISOR ILO32HD Y NO PUEDO CAMBIAR DE CANAL NI CON EL CONTROL NI MANUALMENTE ME HE COMUNICADO CON USTEDES Y NO HA SIDO DEVUELTO LA LLAMADA. LE AGRADECERE QUE SI NO ES MUCHA MOLESTIA ME PUEDAN AYUDAR AUNQUE SEA ENVIANDOME UN EMAIL ATRAVEZ DE MI CORREO ELECTRONICO PARA DICHO PROBLEMA. PARA PORDER CORREGIR LA AVERIA QUE DANDO PREOCUPACION ME HA CAUSADO. GRACIAS CORDIALMENTE, MARIBEL RIVERA 110 E. BROAD ST APT A203 TAMPA FL 33604 mirvera2025@hotmail.com
Posted on Jan 13, 2007
  • MARIBEL RIVERA Jan 13, 2007
    mi telefono es 813-431-0095
    por favor que la persona que se comunique conmigo hable esopa?ol y las instruciones sean en espa?ol. gracias
Want to turn off audio description off on my Panasonic Viera. Handbook says go to menu then sound but I can find nothing there.
iv got a panisonic i dont know if its the same but i click on the options buttion witch takes me to the options menu
then it says ad in the multi audio/ad box change this to eng
Jan 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
No sound on analog channels
I came across this problem yesterday. Digital channels sound... Analog no sound. press the tv button on your remote to change it from DTV/TV
go to any channel you want. press the menu button then go along to Sound setup. In there you will see quite a bit. I went down to an option in there.. it was sound input or something similar. this was set to BG I changed this to 'I' and the sound came straight back on. Hope this helps you out.
Little Dish Fitter
Sep 02, 2009 | LG DR787T DVD Recorder
Was watching TV and the picture just went black (still had sound)
eithor the flyback just craped out or the tube went
try turning up the flyback failing that call a service tech and ask for a quote
quote cose 30-50 bucks
atleast you will know forsurre if it's worth fixing
Aug 06, 2009 | Samsung SPN4235 42 in. Plasma HDTV
JVC TV
you should have a button on your remote for sound system may be 'BG' or 'SYS' or any other press it to change sound system to "BG". sound will be ok.
Nov 01, 2008 | JVC AV32F476 32" TV
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Mitsubishi VS-50703
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Apr 16, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Menu, volume and channel emblems will not show up
take your set to a tech the tv system control circuit might have damage, that circuit controls OSD,channel memory. it is an ic that controls that circuit along with other components.good luck.
Mar 26, 2007 | Toshiba 43H70 43" Rear Projection...
iLO 3200 32 in. LCD Television Logo
131 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
