Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
MY SCREEN IS DARK OR BLANK EVERYTHING ELSE WORKS GOOD JUST NO PIC
CAN ANYBODY HELPMY DISABLED WIFE'S 2 YEAR OLD TOSHIBA MODEL MW27F51 MFG DEC/2005 HAS DVD/VCR ON LOWER PART OF CASE. THIS TV HAS NOT PLAYED OVER 300HRS IN 2 YEARS, SHE TURNED IT ON 2 DAYS AGO TO FIND NO PICTURE AND NOTHING WE'VE TRIED HAS MADE ANY DIFFERENC.  IS THERE A FUSE OF SOME KIND INSIDE THE CASE? CAN ANYBODY HELP ME?????
  • video2227 May 14, 2009
    I have the exact problem as you. Powers up dvd opens ect. Screen is black . Any ideas?
    Genius:
  • 1,139 Answers
Hello fixedopsmike,
There is a fuse in the TV set, if you would like to check and see if it has blown, here is a way you can do it:
1) Unplug the TV's power cord from the wall
2) Take the back off of the TV by removing the screws and slowly removing the back panel.
3) Look for a component that looks like a glass tube with metallic caps on each of the ends, this will be the fuse.
4) Visually inspect the fuse to see if it shows signs of being open (Blown) These signs are burn marks inside of the glass tube, an open conductor (wire) inside of the glass tube, or no visible wire inside of the tube.
5) using a multimeter set to resistance (R x 1) test the fuse for continuity (remove and change the fuse if found to be defective)
6) If the fuse is not bad, reinstall the fuse if removed, put the rear cover back on.
Now at this point we have determined if the problem is a fuse being blown or not, if you replace the fuse and the TV works great the problem is solved, if you replace the fuse and it blows again, or if the fuse was ok to begin with, then you have a problem that will require some knowledge of electronics pass the basics to continue on. At this point I would suggest that you call a qualified TV repair technician to troubleshoot and repair the TV in question.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 16, 2009
My Toshiba 32AV500U - the picture went blank.
This problem usually happens when the lamp runs out, verify how old is your TV, lamps have a life spend of aprox. 3 years, most likely you would have to replace the bulb so your TV can start running again!!
Mar 17, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Dark spots on LCD screen
I hate to say it but what this is is contamination under the actual LCD glass. This propblem starts during the manufacturing process and can rear its ugly head over time or after running at high temperatures for long periods of time. It can also appear as dark 'tiger' stripes. There is nothing that can be done to repair this. If you have an extended warranty, the mfg should exchange the panel for you. If your warranty is up, take photos and contact Toshiba online and try to get them to cover this regardless. This is a mfg defect.
Jan 05, 2010 | Televison & Video
Everything functions fine but the picture is very dark and beyond adjustment through normal menu options, I can move the brightness all the way and it doesnt help any, is there a backlit bulb that might be...
I think you answered your own question. You have a rear projection television. It sounds like the lamp is not functioning correctly.
All projection lamps have a recommended life measured in hours. I checked the web and this model appears to be about 3 or 4 years old. from 2005 or so.
The lamp in my Samsung is rated at 3000 to 5000 hours, I had 12,800 when the service Tech was in changing another part.
3 or 4 years running one lamp is a good run. This is why DLP has lost favor for table top sets, Most are LCD or Plasma now.
Check you TV for it's lamp model and them shop around allot. Lamps are not cheap however some suppliers offer much better pricing that others. Care should be taken to make sure you order and purchase real replacement lamp and not a clone / compatible model. Original parts should produce the picture you are expecting
Jul 08, 2009 | Toshiba 57H81 57" Rear Projection...
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
I have a Toshiba TV/DVD/VCR combo model # MW27F51-had it for a couple of years. Turned it on, have sound but no picture. I have the cover off the back of it now.
sound like a defective part inside the set. i could tell you what one went bad, this is not user servicable, and could shock you bad. i would take it for service or get a new one. due to the cost of these against the cost of repair.rule of electronics-if the cost of repair is 60% of a new one you should not repair it. good luck! hope this helps!
Feb 27, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Bottom left corner, red part of the picture is making an arch
11 years old, you may need a new one, as service can be costly. if the cost of repair is more tha 60% of a new one, get the new one. the fact it is 11years old, makes this an easy choice. good luck.hope this helps..
Feb 22, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Is my Toshiba MW27F51 TV Digital?
pretty much if the television is older than a year-it probably has analog tuner. you can buy digital box (add-on) i have one and it does make picture nice. about 40.00 bucks. i'm ot sure if they still offer the card that gives you a 40.00 dollar off. look up digital converter box. good-luck, hope this helps!
Feb 21, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba Remote
you can buy a universal remote if the cost of a replacement is too high. hope this helps, good luck.
Apr 15, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
TOSHIBA LAP TOP A135-S4656 SCREEN WENT BLANK BLACK
over heated the video area in it will have to cheak video card inside or motherboard chips on it got to hot when u play games on labtops u must ua labtop cooler never set it on your bed
Jan 27, 2008 | Toshiba Satellite A135 Notebook
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
243 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
