Question about Samsung Evoca 115 35mm Point and Shoot Camera
Evoca 115 stopped working after 22 shots
In panoramic mode took 22 shots now won't work. There is a blinking light which says (I think) a8 than Ex. If I open and shut the camera it shows 22 shots and the film has not rewound. I tried changing the battery and I read the whole manual but it doesn't say anthing about an a8 appearing. Can you help me. Thank you.
    Sergeant:
  • 229 Answers
I think you have run out of film. 22 panoramic shots is the equivalent of at least 35 regular shots. Did you open the camera in a darkroom because if not you might of ruined the film. You need to try rewinding the film putting in a fresh roll and I think it should work. Hope this Helps.
Posted on Nov 22, 2008
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
My truck cranks strong but just won't start up. The interior dash lights as well as the tail lights both do not work
My ex -husband stole my 4 runner and disabled it I think he took fuses. this is what it does, it will crank but not turn all the way over, and it will not go into any gear I counld not even go to nuetral "someone PLEASE help me I am Trying to go home and he knows I can't leave any other way another method of control
May 23, 2012 | 1997 Toyota 4Runner
My brake buzzer is on all the time
have you checked the brake fluid level ?? is the servo working ?? are the brake pads worn down to the sensor so its touching the brake disk
Jan 31, 2012 | 2004 Audi A8 4.2
I have a sony DSC T300 that the back touch screen doesn't display any video. It lights up and I makes the noise when I touch where the scroll arrows are (when in play mode) or where menus should be (in...
Hi your unit has lens unit defectiveness. It won't reset itself initializing. The noise come from initializing IS unit defect. your local repair shop would charge around $45 to 115 depend on what they really want to charge. thanks and best regard!
May 25, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
How to use the panoramic function in my olympus 1050 SW.
I won't say it's in the manual.
Turn the selector to the square "camera" icon (just above AUTO).
Press the Menu button, select Panorama. Choose Combine In Camera 1.
Point your camera at the left or right side of whatever you are taking the picture of and press the shutter button. A flashing icon appears with arrows pointing left-and-right. Pan the camera left or right (your choice) as if to take the next shot in the panorama ... a blinking diamond appears and then a square box - keep moving the camera until the diamond enters the square box, the camera will automatically take the next photo. Move the camera again in the same direction, another diamond and square box appear and the photo is automatically taken as before.
To take another panorama shot, repeat this entire procedure, beginning with the Menu selection.
Oct 09, 2009 | Olympus Stylus / mju 1050 SW Digital...
Recently my canon speedlight 580 EX II TTL has been acting up...especially in low light situations. About on in 30 shots actually has enough light in them...the rest of the time the shots are...
that the camera/flash set-up I use ... there are many variables - iso/metering setting/shutter settings/flash settings .
If it's a flash function problem, try this to isolate it - first, with the diffuser/reflectors tucked into the flash head, and the head straight up, with the flash set in master mode, turn it on and look on the back screen. push the mode button til you see the ETTL in the upper left of the screen .. then press the set button in the center of the dial and the nuber in the center of the display should flash (+0) while the light is flashing, rotate the dial to change the setting (i usually under power by 1/3 stop. Play with the exposures a few times to get the feel for what the EV shifts do to your exposure. generally speaking, for interior low-light, i prefer to bounce off the ceiling (if low ceilinged), if there's too much direct it will give you an uneven and predominantly underexposed image.
if you prees the mode button you will come to the same options for adjusting the output in manual mode, but it will not work with the autoexposure in the camera.
Try playing with the ETTL settings
I think the problem may be that you have somehow altered the power output setting on the 580.
Sep 23, 2009 | Canon Speedlite 580EX II TTL Flash
Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
Panoramic pictures??
A panoramic photo on 35mm film is just cutting off the top and bottom. even if you can't set the camera that way, you can ask your local photo store to print any shot that way for you. Usually 2x the price of 4x6.
Sep 13, 2007 | Minolta Freedom Zoom 115 QD 35mm Point and...
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Samsung Evoca 115 35mm Point and Shoot Camera Logo
108 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
