Question about GE 32GT740 32" TV
GE 32GT740 wont turn on
2 weeks short of 5 years our TV only clicks when the power button is used. Everything was good up to now. Is there a 5 year button that needs to be pushed?
  • 3 more comments
  • kbelmond Jan 07, 2009
    i have the same exact problem with the the tv clicking persistently & screen not turning on...can I fix it myself for less than $100?
  • tcatterton Jan 08, 2009
    I too have the exact same problem. Turned TV off one night 01/05/08. Got up the next morning - turned on TV - only clicking. No picture & no power!! Only the clicking.
  • thebutcherki Jan 20, 2009
    42 inch ge same age same problem any other solutions?
  • big_will_63 Jan 23, 2009
    January 23, 2009 - This TV is 5 years old. I have the same problem, I turn the TV on, all I hear is a clicking noise. The screen stays black. It worked great until today.
  • Anonymous Mar 31, 2009
    Same problem. TV is about 7 years old. It just shut off and started making clicking sounds. Oh well, good excuse to get a new flat screen I guess, since it is analog anyways.
  • 121 Answers
Odds are high volt  circuit gave up. 100 150 repair 5yrs not worth repair.
Posted on Dec 01, 2008
GE 32GT740 32" TV 32GT740
It souds like a bad power supply and yes it is preferable to have it checked by a proffessionnal tech. I could be wrong !
Sep 15, 2011 | Televison & Video
My ge television just turned off. when I try to turn it back on it just clicks like four times!!!
These sets are famous for problems in the horizontal/high voltage circuit. Loose connections, bad high voltage transformers and shorted horizontal output transistors. If the picture was still good it is probably worth having it checked out. Thanks
Oct 10, 2009 | GE 32GT740 32" TV
TV will not turn on
The power supply will need to be replaced. This is extremely common now days.
Sep 23, 2009 | GE 32GT740 32" TV
Tv wont turn on
Same Problem. TV was purchased from Sams Club about 2 or 3 years ago. workede great unti llast week. We were watching tv and it just shut off. The power button on the tv started to get soft were you had to push hard or just use the remote. My guess its something with the wsitch.
Jan 28, 2009 | Sylvania 6427TE 27" TV
GE television 32GT740 Guideplus Gemstar
6/1/2010 11:34:21 AM
Good morning I have sound problem it started with the cable hook up there box to the television, now sound is very low. Turn up the TV control to max, nothing but low sound. Of course cable people have no idea of a problem, I disconnected the cable but the same problem, love the set work for two years, note: thing happen when all analog change to digital. help!
Dec 12, 2008 | GE 32GT740 32" TV
Tv wont turn on
disconnect the tv from the wall first for a few minutes,like 15 or 20 and then plug it back,lets see what happen
good luck
caypianan@yahoo.com
Oct 31, 2008 | Samsung HP-T4264 42 in. Plasma HDTV
GE 32GT740 32" TV problem
there are two things that can cause this, 1 there is a muting transistor on the bottom of the PCB that is a surface mount transistor that goes short. this is the channel mute transistor. when you change channels it is designed to mute the static between channel changes. if it shorts then it mutes. 2 the EE-PROM is defective and needs to be replaced. i'de go with the transistor first. if you are unequipped to do this repair have a tech do it.
Mar 02, 2008 | GE 32GT740 32" TV
Why is my tv doing this?
Power supply problem. Usually caused by incorrect or missing feedback voltage...accordianman
Jan 16, 2008 | GE 32GT740 32" TV
Ge 32gt740
The GE (actually RCA) 32GT740 uses the CTC203 series chassis. The most common problem in that chassis is a coil connected to the base of the horizontal output transistor comes loose, and the set may run sometimes and then it will shut off by itself. If you keep trying to run the set with the solder joints cracked on that coil then the horizontal output transistor will short out and the power supply will squeel when plugged in. Do not plug the set in if it squeels as this could eventually cause major problems in the power supply. The set needs a new horizontal output transistor and a good resoldering of the drive coil, drive transformer and all related parts. If you do not have experience in unsoldering and soldering electronic components in TV's then have a qualified tech handle it for you.
Jul 19, 2007 | GE 32GT740 32" TV
TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
GE 32GT740 32" TV Logo
122 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
