Question about Swiss Audio SW12 Car Subwoofer
When i turn my radio up all the way my speakers cut out and then come back on
I used to have a 2600 watt pyramid amp hooked up to my swiss audio twelves it worked perfect then i upgraded to the kenwood KAC-9152d 1800 watts and now when i turn my radio up past 35 my speakers will cut out then when i turn it down to 15 after a second they will come back on i hooked my freinds pioneer twelves up to my amp and it worked fine i could turn it up all the way is my amp to powerful for these speakers
  • Anonymous Mar 20, 2014
    should i check my speaker wires or my amp
If by speakers you mean your subs, your amp is going into protection mode. i have the same problem. i dont think it can run at 2 ohms like it says it can.
Posted on May 02, 2007
I soundds like its too powerfull for them beouse some new speakers now have a shut off if they are ready to go out or blow to make sure you dont damage them
Posted on Jan 15, 2007
    Problem Solver:
  • 11 Answers
Yes it is probably too powerful for those speakers. Or the speakers could be defective.
SOURCE:
My radio cuts out when i turn it up and the bass hits on my subwoofer
You are drawing to much power to the amp. I assume that there is no dedicated power fron the battery to the amp. If there is you should look into a capacitor
Feb 13, 2013 | Car Audio & Video
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
Can i wire direct to battery to get more power instead of the fuse panel.Plus i have a comet 200 hooked up and only getting 125 watts whats the prob
comet 200? its a 2 pill. 125 watts seems right. The amp should be run straight to the battery always. you can run the radio, but that will not get you more power although it will help with engine noise in your radio. You could be starving the amp if its not run to the battery, but you won't see much more wattage.
Also your dead key will effect your power output. Should have some where around a 2 watt dead key.
This leads me to my next point.
What kind of meter are you using? if its a cheapo pyramid or workman, it may only read average watts. and it will only show you your dead key. It will not show you audio swing. you need a meter that can read peak watts to see your true swing.
you may be doing more then you see on your meter.
Jan 05, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Amp for 12" Alpine Type R DVC 4ohm
i actually have 2 12" type s's and i did the same thing just wanted a cheap amp... i went on ebay and bought a pyramid 1600 super blue series amp..... its 1600 watts and ive also hooked it up to type r's and it POUNDS!!! ill copy and paste the website where i got mine from on ebay... if you tune it right it'll make it so you cant breathe inside your car......http://cgi.ebay.com/NEW-1600-WATT-PYRAMID-PB559X-Car-Audio-Amp-Amplifier_W0QQitemZ350169009069QQcmdZViewItemQQptZCar_Amplifiers?hash=item5187b30bad
Nov 11, 2009 | Alpine Car Audio & Video
How to hook up a pyramid pro plus 4 channel pb-180px without using rca jacks for 6 by 9s
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Jul 27, 2009 | Pyramid Audio Players & Recorders
Speakers cut out when i turn up volume.
check your ground if its not grounded good your amp will power down!
Jun 05, 2009 | Pyramid 4 X 10 SPEAKERS Car Speaker
Amp over heating and cutting off
sounds like the Impedance of the speakers does not match that of the amp, therefore the output stage of the amp is trying to compensate, driving the amps too hard and eventually causing the thermal cut out to activate. Check the ratings on everything are compatible before you start sending it off to be fixed.
Mar 22, 2009 | Pyramid PB736GX Car Audio Amplifier
Pb2600 car amp
It might, at say...6000% distortion. For a true amp power rating look for the RMS per channel specs. This is a much more realistic rating of what the amp can actually put out continuously...
Mar 21, 2008 | Lightning Audio FF150.2 Car Audio...
Swiss Audio SW12 Car Subwoofer Logo
236 people viewed this question
Top Swiss Audio Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Swiss Audio Car Audio and Video Expert? Answer questions, earn points and help others
