Question about Motorola Mobility RAZR V3i Cellular Phone
Text msgs go to sim card memory instead of phone memory
Text messages received go to my sim card, which has limited memory, therefore I cannot receive large messages, such as those containing pictures. Meanwhile the phone memory is almost empty. How can I change it to make incoming messages go to phone memory? The manual doesn't address this at all.
  • mbrinkley Nov 25, 2008
    For some reason, my menu doesn't have a 'text message set up' selection.
    Master:
  • 497 Answers
Go to message main menu scroll to 'message inbox' press menu key again , scroll down to 'message setup',press select. scroll to 'text message set up ' press select . in the new menu it will show u 'store to phone , sim' in that option select phone
do update me if u require more assistance
Have a nice day!
Thanks for using Fixya!
Posted on Nov 25, 2008
Hi I have a Samsung Corby S3650 and I keep getting the same messages from people who have messaged me, over and over again. what should i do to stop that???
This problem is generally seen when messages get stored on the sim card. generally sim cards have space for 20-30 msgs before phone memory gets occupied. I would recommend you to keep your sim card memory full always (as in keep some msgs permanently on the sim without deleting). To check memory usage, go to main menu-> messages -> memory status-> text messages (from top right drop down). The second row shows sim card memory status
Apr 16, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I have Samsung L700. I have a problem that the incoming text messages are stored in SIM memory by default, which has capacity of only 10 messages. It is required that incoming text messages should go...
Unfortunately, there is no way this can be done. the phone fills up the SIM memory,only then it goes to phone SMS memory. But as a solution you can transfer msgs from Phone memory to SIM memory
Feb 24, 2011 | Samsung SGH-L700 Cell Phone
My lg versa isnt sending text msgs. every time i try, it says it failed then it tries again then says message not sent. invalid destination. i have the right number and ive turned it off a bunch of times...
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jan 26, 2011 | LG VX9600 Cell Phone
I have A corby pro..I never get reply on time and then i get all the messages 3 or 4 hours late..and it sometimes sends the same message several times..how do i get rid of this problem..?
Jan 23, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Why when i'm using my samsung corby S 3653 i always received delayed and multiple messages?
---Pls rate if its useful---
Jan 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Cannot receive any texts.can make and receive calls and send text
Just had this on my wifes phone. I did 2 things she had too many Apps & phone was showing out of memory in top left hand corner. 1) Delete large Apps 2) Select MESSAGES, MENU,SETTINGS,MENU, RESTORE DEFAULT SETTINGS. Hope this is of some help. Steve
Dec 29, 2010 | HTC Wildfire Cell Phone
I have a sony ericcson w910i. i am unable to receive texts from my wifes phone. She has sent numerous texts and they haven't come through. i receive texts from other mobiles no problem and can send them no...
Hey John
Issue is not with your phone.. Your wife's phone or network might have a problem.. Wat about the msgs sent to others from your wife's phone.. Check the message centre number in your wife's phone.. If it's correct(Find it from the network provider) remove it and restart the phone. Or try entering the same message centre number. (No proofs, but stillthis cliche works... Try restarting the phone, remove the sim and insert it properly again.. Use a different sim in your wife's phone, send a few msgs, check it works.. then try sending msgs from your wife's sim from her phone).. Reply back if it works...
Dec 19, 2009 | Sony Ericsson W910i Cellular Phone
Text Memory
I've had this phone since it came out and have used it with both the memory card and without it. The limit is the limit it has always been about 115 messages or something very close to it before it will stop receiving or sending messages due to the lack of memory. Maybe it was all in your head. Perhaps?
May 21, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Text Messaging
That's a problem the Network Service Provider should be able to solve. I don't think it's your phone.
Remember to delete msgs, when you no longer need them. The phone only has a set amount of memory.
Phonebook 500 x 16 fields, Photocall
Call records 20 dialed, 20 received, 20 missed calls
Card slot microSD (TransFlash), up to 2GB, 64 MB card included - 6 MB internal memory
Apr 08, 2008 | Nokia 6233 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
328 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
