Question about Brother MFC-440CN InkJet Printer
Brother 440cn error 51
Cleaned inside and out of printer. No paper jams or debris anywhere and still recieve aerror 51
Unplug the printer, wait 10 seconds and plug back in. (reboot) This should fix your problem....
Posted on Apr 15, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Uninstall the printer.
Reboot.
Install printer and try to print a test page.
Posted on Nov 22, 2008
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Unable to Print 51 is showing on my printer screen...Will not print.
Check for obstruction in printer. Paper chads, paperclips, staple etc. You may need to move the print head manually to find the problem.
Jul 08, 2009 | Brother MultiFunction Center MFC-440CN...
Brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Jan 20, 2010 | Brother MFC-465CN InkJet Printer
Error code 51
That error is telling you that the cleaning assembly is not cycling properly. Usually I find paper scraps on the right stopping it or a broken drive gear that means the entire engine assembly neeeds to be replaced.
Jul 23, 2009 | Brother MultiFunction Center MFC-440CN...
Is showing Unable to Print 51 on the screen and will not print or do anything.
This message means that one of the sensors (you can't pin-point which one) has detected something and stops the printer from continuing.
You will need to manually check (after turning off the printer) that there is no paper or debris inside the printer that could be causing the error.
If that doesn't help, try running a head clean as part of its maintenance software (may be under Brother in the Start Menu) or in the Control Panel under Printers.
Boyond this, it looks like you will need to get the printer serviced. If that costs too much, it may be a better alternative going for a new printer instead, but this would be the last resort. Please try the above first.
With regards.
Jul 09, 2009 | Brother MultiFunction Center MFC-440CN...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-440CN InkJet Printer Logo
528 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
