Question about LG WM-2277HW Front Load Washer
LG WM2277HW Washer
Found Repair manual for washer but it does not have exploited parts break down where can i find one
  • cet73 Nov 25, 2008
    thanks for info helped some was looking for a hard copy but info you gave will work thanks
  • 370 Answers
Sears.com Put in your model number under the parts section and you be able to see the entire breakdown of your machine.
Posted on Nov 22, 2008
I just bought a house with an lg washer. I ran a load of towels and the screen says "LE see owners manual". What's wrong?
Hi
An LE error code on the washer's display indicates that the motor is locked, possibly due to a heavy wash load. ... But if the error code displays on every washing cycle, the unit will require a repair service. How to reset the washing machine: Press POWER to turn the washer off.
I hope this helps Nick
Dec 30, 2017 | LG Washing Machines
93 corvette tilt steering colum rebuild
It will be the top shaft bush that locates the steering shaft in the centre of the column tube . It is normally just a push in fit . You will find reference to it in a parts break down book
Jan 26, 2014 | 1992 Chevrolet Corvette
Our washer recently started to leak and we have been unable to find a manual so we can break it down and repair it. It also becomes unbalanced very easily. Do you know where we can get one? Model #...
to get a parts breakdown of this go to sears.com go to upper far right hand side click on parts and service,, go down to parts under home services ,, type in your model number use the xsw2 one as the w or n just distinguishes what color it is same thing... this will give you a breakdown of the parts as well as part numbers hope this helps...
where
Feb 05, 2010 | Whirlpool Washing Machines
Washer leaks from the bottom.
http://www.fisherpaykelparts.net/partmanuals/GWL11US.pdf
this web site has a parts break down. just find your part and order from your local repair shop
Mar 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
OASIS KENMORE WASHER
Before you junk the machine try calling and complaining a ton to kenmore. It is a faulty part no matter what they tell you. They have completely remanufactured it to make the board better. so they know this is a problem. If you can get them to pay for part of it... its a great washer!!!!
Nov 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
LSQ9520LQO Top loading washer
It sounds like you have a defective lid switch. This is a typical symptom when the washer stops when it gets to the rinse cycle and won't drain. You can check by opening and closing the washer lid and listening for a "clicking" noise as the lid switch activates. The switch is located on the right hand side of the wash tub opening and is activated by a plastic piece on the lid (called a lid strike) through a small hole. You also attempt to use a small screwdriver and push down on the lid switch contact through the hole to see if the switch will make contact. Typically the switch either comes loose, the lid strike breaks off, or the switch breaks. If you diagnose the problem and it turns out to be the switch, you can use the following link for instructions on how to replace it:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Replacement parts can be found at searspartsdirect.com. Just type in your model number and your part can be found under the "Top & Cabinet" heading on the next page as item 11 (part #3949247). The lid strike can be found under the same heading as item number 20 (part #358684).
NOTE: You do not have to drain the wash tub to replace the lid switch. The switch repair does not require you to move the washer. Let the washer to the work. With the switch replaced, the washer should drain on its own by placing it on the SPIN cycle. You can also make a by-pass by using the old lid switch. With the old lid switch removed, simply cut the white plug off the end of the switch, leaving about an inch or two of wire (This is the connector that's attached to the SWITCH, NOT the timer!). Cut the middle wire flush and splice the two remaining wires. You now have a by-pass that you can connect to the timer plug to drain the washer. This will also enable you to use the washer until your part arrives. CAUTION: It is not recommended to leave the washer in this state, as the tub will no longer stop when the lid is opened. You will have to stop it by manually pushing the timer in, or wait until the timer completes the full wash cycle.
If you do not wish to order parts online, use the part numbers provided and take to your local applaince parts retailer. I hope you find this information helpful. Please post back if you have any questions, or require further assistance.
Jun 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Nylon or plastic bushing around tub breaking down
sounds like you have abadrear bearing, not cost effective to repair by you, parts have a 5-10 yrs warr, you would need to check your manual, usuallt wind up replacing, the rear drum, inner basket, without warr theese parts are probalby 650 dollars. so i would call an authorized servicer(whirlpool wont send you parts even though they're warr)
Apr 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM-2277HW Front Load Washer Logo
762 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
