Question about HP Photosmart M525 Digital Camera
My camera wont turn on at alll
We've bought a new battery, a new charger, a new usb cable, and NOTHING works. like when we charged it all the way and push the on button it blinks twice and the shutter moves but nothing happens. i have a kodak easyshare m1063.
The same thing happened to me, I just called HP which took like an hour and told them what was going on and they walked me through trouble shooting steps over the phone which took another hour and then they mailed me a new camera and i sent them the old one with a prepirinted shipping label from them. this happened to me twice.
Posted on Jan 16, 2009
Why wont my sanyo vc-e760 hold a charge
Since you've already tried different batteries, you have a couple of other options...
  • Instead of plugging the USB cable into the camera's wall charger, plug it into the USB port of a computer, or even into a USB phone charger.
  • Try another wall charger.
  • Try another USB cable.
Here's the PDF manual for your camera, if you need it: http://us.sanyo.com/dynamic/extranet/servicers/VPCT1495.pdf
(Page 16 contains info about charging the camera)
Aug 04, 2014 | Sanyo Cameras
Nikon coolpix s205My camera wont charge any more. I had it stored for about 6 months and when I plug in the charger the light pulses with a green light then a solid green light for a couple seconds th
The manual says, when the light is flashing green:
The USB cable or Charging AC Adapter is not properly connected, or there is a problem with the battery. Disconnect the USB cable or unplug the Charging AC Adapter and correctly connect it again, or change the battery.
So make sure you are using a good USB cable, the cable is put in correct. (far enough and straight) And I hope you did not put in the battery the wrong way around, because that could cause damage to the camera and battery.
Make sure the battery and the camera do have clean and shiny contacts. Only to clean with a dry cloth.
And if the problem stays, perhaps you should accept the battery is dead.
You could try to charge it on an external charger, if you have one. And start and stop charging, if you think it is not yet charging.
But if after just a few attempts nothing changes, I think you should buy a new battery.
Jan 22, 2014 | Cameras
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Wont turn on
well maybe there is the lince stucked what you can try plugg it to a usb cable and that to a extern cable to the charger cable for usb once you see the light you take the usb cable out of the fotocamera should open now . but propably the fotos have on the side some damage -
Apr 17, 2012 | Nikon COOLPIX S5 Digital Camera
Nokia coolpix p100 wont charge
In General. Nikon Coolpix cameras TURN ON when you change them. This means when you plug in USB with a computer the camera turns on and the computer sees it.
If you turn the camera ON. And the Battery indicator shows "FULL CHARGE" you may NOT be able to charge it.
To eliminate variables. Do not charge with the computer until you charge with the adapter (wall charger). When the wall charger works then try the computer.
Look at page 145 in your manual for Computer charging.
Make sure your date and time are set in the camera.
Make sure it NEEDS a charge.
Aug 13, 2017 | Nikon COOLPIX P100 Digital Camera
My Nikon Coolpix 8700 wont turn on!
Try another battery. Even though you bought a new battery and charged it doesn't mean it is not bad.
Jul 17, 2009 | Cameras
Sony dsc-s600
1= Use rechargeable battery cells and must be fully charged.
2= Check battery terminals in camera battery compartment. Must be cleaned and shiny.
3= Sony camera DCS-S600 won't charge batteries through USB cable plugged in PC. You need external battery charger to charge battery cells.
Oct 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
HP Photosmart M525 Digital Camera Logo
99 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
