Question about GE JVM1653 Microwave Oven
Inside of microwave doesn't work
I have a ge jvm1653 it is less than a year old about a week ago it started to lose the date and time every so often even when I know that we didn't have a power failure. Today it doesn't work inside at all, All the ouside buttons appear to work hasn't lost the date and time The inside light doesn't even come on when you open the door and when you start it on express or regular all it does is the timer counts down. The vent fan works and the lights over the range work. I tried unplugging it and resetting the date and time still does the same thing. What could it be?
  • barbara meeks Dec 30, 2006
    I had the GE service technician come out and he had to replace the circuit board which he had to order and the magnatron. Now all seems to be working fine again.
  • peterfremo Jul 25, 2008
    Yes I have same microwave and same problems and not only with it not stay working. I have found it running when I have got home before. only runs for 3 sec then off and wants thr time and date
You should try the soultion of posted at the link below of putting the control board at a 45 degree angle. It worked for mine but I still don't know why it works. http://www.fixya.com/support/t122426-microwave_shuts_off_after_few_seconds
Posted on Dec 28, 2006
  • GE Master
  • 9,156 Answers
I'm hearing of this more and more, and I'm begining to be concerned that a recall or "campaign" by GE may be in order! Since your is less than a year old, it should be in warranty. If so (or even if it's not) I would strongly suggest that you call the GE Answer Center at 800-626-2005 to tell them abou tyour unit and ask them all about this. Please do let us know here what you find out! Assuming your power, circuit breaker, and outlet are all okay, then the problem is inside the oven. Some of the many problems inside the microwave which could cause this are loose or intermittent power cord, fuse, fuse holder, thermostat / thermal cutout, wiring, circuit board power part, or the code in the microprocessor. But the last one is the one I'm most concerned about. The others just aren't very likely unless there has been a breakdown in the design or manufacturing process. Post back if you need more help, but please do let us know here what you find out.
Posted on Dec 24, 2006
  • William Miller
    William Miller Dec 28, 2006
    If moving the control panel or wiring (as suggested in another post) makes it work more or better, then it seems pretty clear to me you have a bad connection, probably on the circuit board.
    If the problem is the control panel, we do repair them nationwide for $32.50.
    Feel free to write me or repost if you'd like more confirmatiuon of this possible diagnosis.
SOURCE:
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Our GE JVM 1653 spacemaker microwave looks like it is working but the food doesn't heat up. It lights up and goes around but no heat? Whats up?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ysss
Jul 06, 2010 | GE JVM1653 Microwave Oven
My JVM1653 loses power after 3 minutes of heating
it may have been the hi voltage at the magnetron,but the shut down is your heat thermocouple mounted on the magnetron side and when the mag overheats this thermocouple opens up and shuts off power to the mag to prevent overheating and fire
Apr 17, 2010 | GE JVM1650 1000 Watts Microwave Oven
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
My GE model JVM1653 has problems when heating I
Take the 2 screws out of the top outside grill. Take the 1 screw out of the top of the control panel. Lift the panel slightly and it will tilt out and hang there. Try a cook cycle with the panel in this position. If it works, your problem is interference from your magnetron. It is very common on these units. I do not recommend adding EMI shielding with tin foil as many have been suggesting on the help sites. If you are still under warranty, call GE. If not, call GE and threaten to sue. This is a known problem with these units and they should have been recalled.
Mar 15, 2009 | GE JVM1653 Microwave Oven
GE JVM1650 Microwave Suddenly Stops
Your magnetron tube is leaking RF energy inside and zapping the main board. It is NOT dangerous as any leakage will be contained inside the unit. You will need a new mag tube and it is covered by a 5 or 10 year parts warranty. Call GE Factory Service at 1-800-432-2737or schedule online at www.geappliances.com
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker microwave and the buttons just stopped working last week. The screen only says "press clock". It is not a year old. Bought at home depot and lost original paper work.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If it's less than a year old, it's still under warranty, and they can tell by the serial number & date on the label that it's sunder warranty.
I would contact GE to get it fixed free. GE Customer Service is here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | GE Microwave Ovens
Microwave not working, please suggest
Your magnetron tube has failed. According to the warranty on the Profile Series microwave ovens, the magnetron is covered for 5 years from the date of purchase, but labor is not included. I would call GE Customer Service and when they ask for the model number (which begins with JVM) and the serial number, be sure to give the date of purchase as the date you closed on your house. If they insist upon charging you for a service call and labor, I would call my builder's Customer Service Department and demand (very nicely) that they intervene with GE to waive the service and labor charges. That worked for me (Lennar Homes).
Jun 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Enter clock and time every usage
It sounds like it is momentarily losing supply voltage, in other words, like unplugging it and plugging it back in. Check your plug in at the outlet to make sure it is tight. If that doesn't help, then a service call may be in order as something may be loose inside the service area.
May 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1653 Just shut down with out warning
rich, after you take it down, open the housing and look for something like a white tube with two wires on each side, inside is a glass fuse .
Feb 18, 2008 | GE JVM1653 Microwave Oven
GE JVM1653 Microwave Oven Logo
118 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
