Question about Ingersoll Rand Type 30 Electric Driven Two Stage Horizontal Air Compressor 120 Gallon Fully Packaged Ir 2545E10VFP
I need a wiring diagram not a scematic
I have a three phase 5HP type 30 compressor that needs to be wired, the scematic doesn't show the blocks or any diagram of the inside of the box. Is there anything available.
  • 685 Answers
Rotary Phase Convertor You will find bundles of stuff about building and running phase converters on Yank sites, the main differance is in the UK we have proper lecy, 230 everwhere and three phase is three lot's of that, quite what they have in the states I am unsure, whatever the setup they have around 200 volts three phase - someplaces seem to have 208 some 230- and i think they also have 440 and 600, gets weirder.
Anyway in 'blighty' we have three lot's of 240Volts so that's a phase voltage of approx 415Volts, from one conductor to another that is, no neutrals here- well there is but forget about them. The basis of the rotary converter is a transformer at approx 1.73:1. That gets 415 volts to wack across phase one and three in my diagram, then the motor generates the third phase, well a few caps to ballance it and thats it sort of it.
you can get a three phase motor, spin it and apply some 240 volt's to it, it will happily run and produce the third phase. the voltage will be low but it will run other motors. I gather some motors are rated for 230 volts three phase so no transformer needed, but an alectirician said he can't remeber seeing 230 volt's on three pahes motors and all the ones i have are 415/440, then there is the talk about they are alright wired delta, well all my old motors are wired delta the only ones I am not sure about - 3 wired- are modern motors.
I need a wiring diagram not a scematic - convertor.gif The diagram is a bit confusing, so I can't draw. I did the whole thing off the top of my head, that's why I just spent ages wondering why it wouldn't balance;-) it was much clearer before I started to add the control wiring. the stop switch is a normaly closed switch, the start switch presses the conatactor in, I need to wire it to a switch so I can setup some remote on/off point's
The setup above has voltages of something like 457, 427 and 464 Volts unloaded. whan it's loaded with a running mill taking a cut I get 426, 427 and 427, first thing in the morning it did have all three at 429V. the current is 4.1, 4.2 and 4.2 amps.
I bought 100, 60 and 40 Uf caps. When I sat and figured out capacitances possible with these, I was quite suprised to find the number of permutations possible was so high. I am running L1-L2 fixed capacitance of 34.3Uf and the switched caps are the run caps from phase L2-L3 and the start caps on these phases, the start caps are 200 Uf, though I did have it starting with 100 - but I had drilled holes for two caps in the enclose;-)
I had a static converter, from which I copied the way they switched the start caps out. Simply a capacitor being charged with DC across the contacts of a relay, hence the bridge recitfier and resistor.
there is also a breaker, I am told it's an 'MCB', the whole caboddle is supplied via a fuse but the mcb means you can take liberties while playing with it and you don't need to have to keep replacing fuses...**** it and see, electrickery..
I checked the voltages on the caps while I was fooling around and the ones 'burried' in a pack had several hundred volt's dc on them-days after turning it off-so I put resistors to bleed the voltage off, means you can stick your hands in it and move the wiring around without getting bitten - though I still check them first.
I put it together in an old computer case, it did the job but looked like something Victor [Frankenstein] would have had. I got this rather nice fire panel- with loads of relays and nice neat wiring, which i tore out- I mounted the contactors and relay on a DIN rail and put the switched caps in the enclosure. then knocked up a large box to put the transformer in, the other caps live with the transformer. The idea was to rubber mount the motor on top of the transformer box and mount the main convertor enclosure on the wall. The motor is on top of the trans' box but the box vibrates with the motor - it runs a bit rough when unloaded. So I might have to rethink that, I have the motor on a sheet of Plastezoate and the box is on adjustable feet and they are on rubber.
Anyway it works and I have power that runs all the motors on my bit's'n'pieces and even runs a 5hp type 30 Ingersol Rand compressor, though it needs some extra caps - the idler motor rocks in time with the compressor, starts it at 175lbs though....
convertor02.jpg I will sort out my voltages and capacitances, I wrote down all the voltages for a large number of capacitances, when you have a list like that its easy to see the trends and how to alter the voltages, I opted to tune the mill and lathe spindles as clean as I could, I will only need to add capacitace to the compressor.
I need a wiring diagram not a scematic - convertor01.jpg convertor01.jpg Well it all got bolted to the wall.
Well almost done, it's amazing the number of little bit's you need to finish a job; I still need some more armoured cable or cable and conduit... hint hint young Maxwell. If you need any electrical testing try Max Knight Electrical, he doesn't touch conductive surfaces when he comes to my garage;-)
Anyway the box bolted to the wall with the two yellow buttons is the converter, the transformer and idler sit below, on the floor, The transformer weighs 40+ kg so i didn't want to put it in a box that i woudl have to lift, well i did but i didn't scrounge a big enough box.
I still have to tidy it all up, put a few more three phase spurs in and make a dc control circuit, so i can run a controll wire and buttons around to a few strategic point's - the places that you can usaully get at without having to climb over a motorcyle or a stack of old car bit's..
Of course the box came with a nice white engraved plate on the front, I spose I will paint 'on' and 'off' next to the relevant button, as I am the only one to use it it probably don't matter...Still it would be nice to find a bit of formica and cover the holes - formica do they still sell that?
Posted on Nov 22, 2008
  • 2 more comments
  • Juanita Vega
    Juanita Vega Nov 22, 2008
    here you go
  • Juanita Vega
    do you have an e-mail address i can send you picture diagram of it
  • Juanita Vega
    http://www.powerexinc.com/uploads/101220... here is a file to help you please let me know how this works.thatnk you for using fixya.
  • Juanita Vega
    Sergeant:
  • 229 Answers
Google Ingersoll Rand Compressor wiring diagram and the first result is a site I have used before it is very comprehensive and easy to access. This will definitely help. Thanks!
Ajax 5hp air compressor wiring diagram Problems
If you're running 3 phase, swap 2 infeed wires. If you're running single phase, look in the wiring diagram in the motor head for the wires to move.
Jan 31, 2012 | Air Tools & Compressors
Need wiring diagram
Mike I do not have a wiring diagram. If you let me know what you need maybe I can help.
Dec 21, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
I want to wire a 3 phase planer up. I have three
install 30 amps 3phase breaker, then wire it up with royal cable 5.5mm x 4wires
Nov 25, 2009 | Powermatic 1791297/Model 209 5HP 3Ph 230V...
I'm trying to figure out how to wire a 5hp motor
Go to the website for the motor manufacturer- it will show how these capacitors are to be wired. You'll need the motor model number.
Sep 22, 2009 | Air Tools & Compressors
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Ingersoll Rand Type 30 Electric Driven Two Stage Horizontal Air Compressor 120 Gallon Fully Packaged Ir 2545E10VFP Logo
152 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
