Question about Kenmore 22422 Top Load Washer
Water is coming out of the bottom of the washing machine
It's leaking water from the insdie not the drain. How do I open it up to see where the problem is? Kenmore 70 series top loader.
  • ctjshansen Mar 15, 2009
    water is comming out of the bottom of my washer!!help!!
  • 370 Answers
Tip the machine back and remove the 2 clips holding on the drain pump. Remove the hoses. Then turn the pump over to where the motor shaft enters it. There will be signs of water leaking out of the pump. Your local parts store will have the pump instock.
Posted on Nov 22, 2008
2 Suggested Answers
  • 46 Answers
SOURCE: kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Posted on Jun 27, 2009
My GE washer leaks water during spin cycle only, seemingly from bottom of valve(?) where water hoses hook up, hoses look to be in good shape, only a year or so old.
If it is leaking at where the drain hose comes out of the wash machine, make sure the plastic spider clamp is seated securely in the groove on the drain hose. If that's not it, then, yes, you'll need to open up your washer to gain access to the inside of it. I don't know which model GE wash machine you have, but most of the GE top loaders can be opened by following the instructions in this youtube video:
Oct 19, 2014 | Washing Machines
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Washer leaks out the bottom in rear of machine
Thank you for using FixYa. Does water leak out of the machine from the beggining of the cycle to the end? If it only leaks when spinning or Pumping out water and water comes from the rear bottom of the machine? This is where the drain pump is located and I would say that the leak is coming from there---either a perished hose or a loose retaining clip.
Mar 16, 2011 | LG WM2101H Front Load Washer
When driaining out water comes out
Where does the water come out from? From under machine or where the drain hose hooks to the drain. If it is coming out the drain where the hose hooks the drain is most likely stopped up. If coming from underneath could be a hose or the pump leaking. I have seen something like a screw get caught and wear a hole in the tub. Check around the bottom of the tub if there is water leaking around the bottom of the tub could be the tub seal is bad. Hope this helps.
Dec 23, 2010 | Washing Machines
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My ZWD1471 started leaking during the drying cycle recently. It doesn't leak during the wash cycle. The water seems to be coming from underneath the back of the machine, I think on the righthand side. Any...
open it and see where the leack come from it might be the drain pump and it easy to replace or it might be a hose that got burst...
see if you can open it from the back or the bottom front
Feb 07, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Water coming out from the bottom of washing machine
Have the unit panel taken of to see where the source of the water comes from. It could come from a leak or the water overflows or is not draining. Check for leaks in the valves or hose, as you inspect where the water comes from. To check if it is not draining see after wash if the water drains while the panel is taken off. IT could be caused by the water level sensor (usually a floating device on the tray) may have been dislocated or needs replacement or a faulty water pump.
Sep 12, 2009 | Kenmore Washing Machines
There is a leak at the bottom of the washing machine. Water is coming out the bottom front and bottom left.
The leak is from the drain hoses or the fill pipes.
No need to worry.It's a common issue and easy
to fix of your own.
Sep 01, 2009 | Maytag Washing Machines
There is water draining from underneath the machine?
I have the same unit, I had to replace my drain pump and clean the entire machine out. THis unit has many design flaws however once they are corrected with new parts it is a good machine.
Mar 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22422 Top Load Washer Logo
1,295 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
