Question about OKI C5200n Laser Printer
I'm Getting Doble Color The Undertone Is Magenta The Original Color Is Blue For The Document I'm Printing. Everything Was Fine Until i listened To A tech Support Tell me To Adjust The Life Levels Of Drum kits To 0. Thats' When The Problem Started. i think i just need To Adjust The Colors Correctly, But How? Thanks I Have An Oki data C5200 Lamont Long Island NY
  • janannski May 06, 2009
    I replaced the image drum for cyan, magenta and yellow all at the same time. Of course, it then indicates that I'm out of toner for those same colors. I replaced all three toner cartridges at the same time as the image drums.
    Got a dark magenta overtone on any color or black/white photographs I tried to print (with advanced color chosen in print properties), and get a double color on any blues, with magenta being the predominant color. Blues are either a dark indigo, or a dark purple. Blue fades to a slightly lighter color on right hand side of page.
    Had NO TROUBLE until I replaced image drums and cartridges. Is there a denisty changer?
Soulvisitor
  • 1113 Answers
SOURCE: OKI C5200
Clean led head's on underside of lid, check tranport belt under drums for damage, test with different colour does the strip exist in all colours or just black?
Posted on Jan 18, 2008
SOURCE: oki c5200 printer driver for MAC
Get the driver from Oki US http://my.okidata.com/pp-C5200n.nsf/openingdrivermenu?OpenFrameSet
Posted on May 20, 2008
sir fixalot
  • 146 Answers
SOURCE: oki c5200 prints double on page
Sounds like the fusing unit needs to be replaced.
Posted on Nov 18, 2008
SOURCE: oki c5200 paper jam
I used tweezers after I took every thing that could come out--out.
Posted on Apr 17, 2009
SOURCE: How do I find out the life left on the drum for a
Push the menu button on the C5200 Printer. Pust it twice or until you see Usage Menu on the LCD screen. Once you see it, press enter. Press menu button to cycle through the various details for each item in your printer. You will see toner life and drum life for each color and black as well. You will also see Fuser life and page counts and much more.
Posted on Jan 05, 2010
Problem printing yellow.
IIf the cartridges is original epson there is some color (light magenta that is clogged.
if the cartridges is non original check that is with the right order
Apr 23, 2015 | Epson Stylus Photo R300 InkJet Printer
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Why is the printer printing color in a very pink color?
Registration problem. like the colors not on top of each other??? Also mite be the magenta (pink) image unit is bad, replace or have a tech check the color registration
Apr 24, 2014 | Konica Minolta magicolor 5550 Laser...
Can I print with one cartridge at canon pixma ip1300 with out replacing or installing other cartridge.
Absolutely, the only thing you need to do is to configure your setting to the right appropriate ink, say for example you ran out of black ink you can go to printing properties and select to be printed in blue, in this case the color match will use magenta and cyan to create blue.
1 select your default printer 2 select printing preference from your printer from there you can change the color of your desired print 3 you can select print in color for example or grayscale 4 then print your document.
cheers
Jan 06, 2010 | Canon PIXMA iP1300 Printer
Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Jul 12, 2009 | Epson Stylus Photo 820 InkJet Printer
Prints "blue" on a document that supposed to be "red"
the red color contains the blue and magenta colors so your problem is not printing blue insted of red , your red laser miror is dirty from inside you should open the back of the printer then open the laser scaner then clean it then replace it
Jun 19, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
Colors not correct
it sounds like a print cartridge problem to me.
sometimes they have other problems. try to replace the cartridge. if this does not work then try replacing the print head
Dec 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Mfc 210
if the MFC is a brother..your print head could be dead.
Jun 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Can't color balance 2605
well, the density is actually a combination of two aspects. The original document settings, especially in color transforms. Usually, the software will have a transform specific for the printer. In my experiences, trying to tweak the printer for each print job, can cause extreme frustration. Check the software manual for settings for your printer, and perhaps you'll get closer to this solution.
Got backup?
Feb 07, 2008 | HP Color LaserJet 2600n Printer
OKI C5200n Laser Printer Logo
54 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
