Engine stall when I hit a bump and then goes back to full power. Replaced carb,fuel lines and filter, seat switch cleaned tanks and still stalls. Driving me nuts!
SOURCE: 2002 craftsman 23 hp kohler pro series stalls and wont restart
try playing with the throttle adjustment or it could be a saftey feature malfunction, like the seat shutoff for example.
SOURCE: My tractor stalls like it is starved for gas
I had a similar problem with a sears tractor. close to the carbarator is a rectangle box with a rubber hose going to the engine block - remove the hose and spray carb cleaner in the hose wait a few mins and try again - its a vacuum for the carb
SOURCE: Have Exmark 52 LazerZ with Kohler ch25 engine.
try looking for a broken wire or a wireing harness shorted to ground, the fuse blowing in the harness will lead you to it if you are able to see where the wire goes. you have a short somewhere may be the fuel pump, too
SOURCE: 19 hp kawasaki carb acting up
sounds like the carb is gummed up from the old gas you will need to clean and rebuild te carb(this is a easy job)...good luck
Testimonial: "Thanks. I came to same conclusion but because of limited ability in this area(I'm an electrician by trade)I wondered if I could cheat & spray it out?"
SOURCE: 14 hp kohler engine (Cv14s 1451) runs good for 5
I had this issue on my 14hp kohler and it was the ignition module. Would run until it heated up then shut down.
