Question about Dell UltraSharp 1907FP 19" LCD Monitor
Digital video stopped working
Analog works OK. Called Dell and they sent a new digital cable and a new video card to try. Put the old parts back in. Sending new parts back after Holidays. Same problem. No digital signal. Could it be the monitor itself?
  • Thomas Fischel Jan 05, 2007
    Dell sent next a new monitor, same model.
    Problem did not go away. No digital video.
    Of course I had digital video since last May/06 when I purchased system.
    I packed up new monitor and sent back.
    Dell is sending out an in-home repair Tech to replace the motherboard.
    I may never know what the problem was/is.
    I have great praise for the Dell Tech on the phone many times now ( same one ). If he had any more patience, he would be practicing without a license :))
    He works out of Nashville. That helps.
    All shipping has been over night and free to me.
    It seems that all XPS owners are treated in this manner while unit is under warranty.
    Tom
  • 558 Answers
Did you try to set the out put on the monitor to dvi on the display settings? in windows
Posted on May 01, 2008
How can i use dvi port
DVI stands for (D)igital (V)ideo (I)nterface.
DVI is a new form of video interface technology made to maximize the quality of flat panel LCD monitors and high-end video graphics cards. It is a replacement for the P&D Plug & Display standard.
you can connect high definition monitor , LCD projector , LCD T.V to a DVI port
There three kind of DVI connector
1. DVI-D (Digital)
2. DVI-A (Analog)
3. DVI-I (Integrated Digital/Analog)
DVI-D format is used for direct digital connections between source video (namely, video cards) and digital LCD (or rare CRD) monitors
DVI-A - High-Res Analog
DVI-A format is used to carry a DVI signal to an analog display, such as a CRD monitor or and HDTV
DVI-I - The Best of Both Worlds
DVI-I format is an integrated cable which is capable of transmitting either a digital-to-digital signal or an analog-to-analog signal, but it will not work transmitting a digital-to-analog or analog-to-digital signal.
How to Recognize These three types of DVI Cable
There are two variables in every DVI connector cable, and each represents one characteristic.
The flat pin on one side denotes whether the cable is digital or analog:
A flat pin with four surrounding pins is either DVI-I or DVI-A
A flat pin alone denotes DVI-D
The pinsets vary depending on whether or not the cable is single- or dual-link:
A solid 27-pin set (rows of 8) for a dual- link cable
Two separated 9-pin sets (rows of 6) for a single-link cable
Jul 12, 2011 | Computers & Internet
I am looking to purchase a new Dell computer. In
HDMI is digital and uncompressed signal while the above mentioned interfaces are analog. A digital source is translated into less precise analog signal in an analog interface. After that signal is sent to the television and then converted back into digital signal to display on screen. Due to this, some distortion of picture quality is caused at each translation. HDMI removes the analog conversion and preserves original signal and delivers richest, sharpest picture. Separate audio signals are required by other video interfaces. Due to large amount of bandwidth available in HDMI, it not only transmits video but audio channels up to eight digital audio channels can also be transmitted through HDMI. The entire process becomes simple because a number of wires are replaced by a single wire. It also delivers much better performance.
The HDMI “Type B” have 29 wires while standard HDMI or “Type A” has 19 wires. Motion picture industry and other professional applications use “Type B” HDMI wires. HDMI enabled components talk to each other via an interface that is why it is also called Intelligent HDMI. All-in-one functionality of remote and other interoperable features are provided by HDMI but not by other technologies.
High-Definition and enhanced video and other standard formats are supported by HDMI. Backward compatibility with DVI (Digital Video Interface) is also supported. DVI/HDMI cable can be used to connect HDMI interface in high-end graphic cards that have DVI port. DVI/HDMI cable has HDMI connector at one end and DVI connector at the other. Another point to note is that degradation of signal can occur if the length of the HDMI cable exceeds 5 meters (15 feet).
At least one HDMI interface was provided in many high-end televisions since 2005. Two HDMI interfaces provides more flexibility and three might be better in cases where one wants to connect a game console. As the TV industry installs HDMI interfaces into more peripheral components, multiple interfaces will become common on TVs.
It is good to have it.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 15, 2010 | Dell Inspiron 580 Desktop Computer (Intel...
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
I have a old computer (Dell) and a new flat screen (Dell) i hooked them up and the screen is black (won't work). It's a digital screen and a analog computer does this make a difference?
Not at all - as long as there is a VGA connection (analog) for the monitor, you're fine. Make sure that if you have a video card that you set your bios to automatically send the video signal through the card (where you'd hook your monitor cable to).
In some cases, if you have a video card, (and you're connected to the VGA output from the motherboard), the signal is bypassed and trying to go through the card automatically. If there is no card, disregard this last paragraph.
Apr 06, 2009 | Dell E193FP 19" LCD Monitor
Need adaptor for older Sony analog camcorder - CCD-TRV70 DC 6V
You need to get a Digital to Analogue converter such as the Canopus ADVC110 A/D Converter. (circa $225). There may be cheaper alternatives. (you might also be able to use a digital camcorder that has a built in Analogue to digital converter):
 Canopus 77010150100 ADVC110 Converter
The Canopus comes with a 6-pin firewire cable. Since your Dell Studio has a 4 pin Firewire (actually called iLink) you will also need a 6-pin to 4-pin cable or an adapter:
 Firewire 6-PIN To 4-PIN Cable
 Cables To Go - 27028 - Firewire 6-Pin Female 4-Pin Male Adapter
You hook your Sony up to the A/D converter with audio and video cables (usually supplied with your camcorder) and hook the converter to you Dell with a firewire cable. Then you capture the video using some video capture software. I don't know what comes with windows these days.
Jan 22, 2009 | Sony Handycam CCD-TRV308 Camcorder
I have just installed a crucial x1600 pro graphics card,when i fired up the computor the monitor displayed multi coloured vertical lines and a box appeared saying it was in analog mode, how do i configure...
change cables on card you should have two ports on the card one for analog and one for digital and the cables are different check the ends of the cables digital and analog are different configuration.
Dec 31, 2008 | Computers & Internet
No connection to monitor
i would try the card in another mainboard, if available and watch the refresh rates. hope this is useful. and try other cards.
Nov 04, 2008 | Evga 512-P3-N862-AR GeForce 9600 GT GDDR3...
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
I was tring to Connect Two Computers to One Monitor, but i didnt get it, does someone know how to do so? I bought a KVM switch, USB to use between a new Acer running Win XP and old Dell with Win 98. Could...
I guessing that since **-one responded you've given up and returned the whole mess but what the hey.
A lot depends on the KVM you're using. There are some high end units that will match different sources to the monitor but most work best with matched input and output. Unless you's specifically states that it will convert analog to digital it won't. So if it's an analog KVM then both the computer video boards need to have an analog VGA jack and the monitor does too. If the KVM is ditital you need to have all the systems and monitor digital. Savi? The Monitor may support boath analog and digital input but NOT at the same time. You can't plug in two computers at the same time, that's what the KVM is for.
The bottom line here is that you typically need to run the least common de**minator to use a KVM. Also, if the computers have different frequency (resolution) out put and you hit the KVM switch then the monitor will freak out. Some monitors will auto-switch between frequencies but most don't (especially the cheapies).
There are adapters that will down convert digital to analog. If you're dead set on using the KVM with that old Dell then you may need to plug the down converter into the Acer Video Board but you'll loose the high resolution and sharp picture from the digital video. If it was me and I had to use the KVM, I'd get a cheap digital video card for the Dell or just run two monitors.
I run 5 systems on my desk, Three of which are older servers with analog video. They share an analog KVM with video and keyboard on the wall. The other two systems are current generation and share a KVM and 27" flat panel center desk. I also have a laptop that hangs on the other wall with a laser blue tooth keyboard on the other side of my desk. Now if my wife would only let me turn part of her craft studio into a server room.....
Feb 14, 2008 | AOC 19LVWK LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
