Question about Canon NP 6551 Black and White Copier
Grey background on copies from a Canon 6551
Service tech told me I need to replace Developer Unit. Total cost is close to $800. The age of the copier makes this too costly a replacement. Any options or ideas are needed to keep this copier functioning. Please help!
  • mgivan Nov 25, 2008
    Dumped all the toner from the developer unit and hopper unit, vacuumed out any excess, replaced with a fresh bottle of toner and ran toner function. PROBLEM SOLVED!
    I have replaced toner before when I got a bad batch, but when the tech told me it was the unit itself, I took his word for it and did not try the first thing that came to mind, which was the solution recommended by Cogz. Thank you for the help. I have to remember that techs are usually right, but trying that one last thing can save you a bundle and get you up and running again.
    Again, thank you very much.
  • Canon Expert
  • 1,326 Answers
Yes, there maybe one thing that can also cause this problem.. You may have a bad or contaminated toner. You can have the all of the toner vacumed out of your hopper unit and removed from the developer unit and have underneath the dev. mag roller vacumed out and restart or install a New OEM toner back into the hopper and have them run a install toner funcation. That should take care of your problem. Even if you just change the developer unit you will still be using the same bad toner it all needs to be removed. I only really say a copier get contaminated more then once, was where the copier was in a very,very Cold room. The toner get water dew in them and the toner clumps. And you get grey and a modeled back ground and bad C.Q..... Good Luck
Posted on Nov 23, 2008
Why toner spills ?
when toner spills it could be that the seal between toner tray/harper/ hopper is not working properly, it could also be developer inside the drum that is worn down, if you page/print has a slight grey background then replace the developer, you will need a qualified technician for this as there is settings that need to be done after developer replacement
Apr 29, 2014 | Ricoh Aficio MP2352 Copier
Why is our printer copier printing so light?
The developer should have been replaced by the technician. the solution is simple...replace the drum and developer and you will have nice crisp prints and copies.
May 13, 2013 | Minolta Di3010f Printer
The copies come out with dark background, how do I service the machine?
There really is not a service mode for this copier. Have you tried to adjust the flush knob on the control panel? The copier is kind of old, when you **** shell it open is there a black small knob on the inside front of the copier.... If so adjust that... Also, I would try to clean the optic's of the copier under the copy board glass. There is a "VR" on the back of the copier to adjust the lamp. Finally, have you replaced the drum unit???? Good Luck
Jun 08, 2012 | Canon Office Equipment & Supplies
How do i clean my canon pc 921
these isnt toner problem. The toner when is out, gives light pictures.
These is optics problem or drum unit problem.
You need to clean beneath copy glass, clean mirrors on scaner rail assy, and beaneth zoom lens cover.
If the problem still occurs replace drum unit. Beare in mind that you after replacing of drum unit must do initialisation under service mode.
Jul 21, 2010 | Canon PC-920 Black and White Copier
What is a fixing web on a cannon 6551 Black and white copier
The Fixing Web is a roll of oil impregnated fabic that sits on top of the upper fixing roller. Its purpose is clean the fixing rollers between copies. It lasts somewhere around 250,000 copies. Needs to replaced by a service tech and have the counter reset. If the Web runs out you get a E-005 error code.
When you open the front door and release handle and pull out the Paper Transport fixing assembly. The Web is under the yellow cover on the left side.
Mar 19, 2010 | Canon NP 6551 Black and White Copier
Toshiba eStudio 210c grey background on copies
U need to check your developer material. How many copiers has been made?
U can also perform 05-200 for the auto toner adjustment. The value should be in the range of 235-245% ( 2.35v - 2.45v )
Mar 26, 2009 | Toshiba e-Studio 232 Black and White...
Error message - re insert unit 1
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Feb 17, 2009 | Canon NP 6551 Black and White Copier
Thanks!
To me it really depends on how many copies the unit has. If you are over 200K it may be time to upgrade, only because parts are expensive after that point. I have always liked Canon copiers, because you don't have to mix developer, it is already blended with the toner.
Jun 13, 2008 | Sharp SF 2020 Copier
Change Developer indication doesn't go of even after replacing the Developer?
after replaceing the developer you have to clear the counter by going into service mode for techs and clear the total count for the developer to do this you need the service manual.
Dec 15, 2007 | Toshiba e-Studio 161 Copier Copier
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
Nov 21, 2007 | Canon imageCLASS D320 Digital Copier
Canon NP 6551 Black and White Copier Logo
83 people viewed this question
old marine
old marine
