Question about Brother NX-400
Sewing stops using foot or start button: sews for a few stiches, then stops.
I sprayed air into the bobbin area - it just needed a cleaning.
Posted on Nov 23, 2008
My brother sewing machine wont finish sewing the button hile. It starts and then stops and just sews up and down making a wad of thread under the fabric. It won't finish the stich. What will fix it?
THERE MIGHT BE DUST OR THREAD STUCK UNDERNEATH THE PRESSER FOOT. OR IN THE BOBBIN CASE . IF SO , TAKE A BRUSH AND BRUSH IT OUT. SOMETIMES I WILL HAVE TO TAKE A LIGHTER TO BURN THE THREAD OUT. HOPE THIS HELPS.
Oct 10, 2015 | Brother Sewing Machines
My Aunt gave her D'lite sewing machine. It sews correctly but will not stop sewing unless you unplug the cord. The start and stop button will start the sewing if not using the foot pedal but it will
There's a possibility that your foot pedal is sticking; if that is the case, it's probably overriding the stop button. See if you can take the cover off and clean it using alcohol, and leaving it open for a couple of hours to make sure it has dried. Visually check the wires while it's open, too, to see if you can see any fraying, and make sure the plug on the machine side is firmly seated in the machine.
Sep 14, 2014 | Sew D'Lite Sewing Machines
Janome 6600
You may have inadvertently dropped your feed dogs. Look on the back side of the throat just in line with stitch plate. There should be a slide there. You can see it by turning the machine around as well. As you face the front and reach around to move the slide, to the right is up and to the left is down. Check that first. Next make sure you have sufficient pressure on the presser foot.
Nov 11, 2017 | Sewing Machines
I have Singer Curvy 8763. It seems that the foot control stopped to work. The machine does not sew, its impossible to wind the bobbin. It is possible however to sew backwards with the help of reverse...
I be s 8763 was sewing beautifuly, took off pressure foot to make a buttonhole read the manual followed directions button holer kept gumming up with thread and the alarm kept going off, then got flustrated, put back on the sewing pressure foot now it is like the needle is out of line will not pick up bobbin, and is definately hitting something by the bobbin, will not sew
Nov 04, 2010 | Singer 8763 Curvy
Janome 5124 keeps running after I depress foot
Greetings, I experienced the same problem. Mine only ran a few stitches. Foot pressure on the foot feed was always "tension" problem in my foot.
I turned the foot feed around and upside down.
I press on the foot feed at the open end not the pivot (cord) end. This has given me much better control. Janome had no options for foot feed adjustment or replacement, but this has helped greatly. You may have to practice to get used to it
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Brother LS-2125 presser foot stuck
i bought a new brother stiching machine ls2125. when i started to stich the same no stiching is coming only the mark is coming. why?
Sep 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Hole width
After putting on the buttonhole foot, you lower the foot, put in the size button you want into the button hole foot. Lower the button hole lever all the way (so machine does not blip) Then the machine automatically sets the length and width of the button hole...you can adjust the length and width manually by pushing the button on the top right hand part of the machine above the LED screen the top one is stich length the other is stich width....if you put the levers to the left it will be the smallest stich length or width...if to the right it will be the largest stich length or width the machine allows. But, really the machine automatically does this for you...so I don't see the need to do it.....but you can....BBill01
Jul 22, 2008 | Juki HZL-E80 Computerized Sewing Machine
Brother NX-400 Logo
127 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
