Question about Cell Phones
Brake screen i seat on the phone and breake the screen
  • bubstro Nov 26, 2008
    the front screen of my motorola razr v-3 cracked on my new phone .the display still works fine i have a older razr for parts and it looks identical. how hard would it be to replace this glass?
  • jilleseb Dec 31, 2008
    Motorola Rizr V3 with broken screen - powers on okay. Can this be fixed?
  • 101 Answers
Hi. I may be able to help with this, as I repair mobile phones, but you'll need to tell me what model your phone is
Posted on Nov 22, 2008
What common faults for Breaking problems on seat ibiza tdi
Pads worn! Water in brake fluid! Old brake fluid!
Sep 09, 2014 | Seat Ibiza Cars & Trucks
Brake booster from 1997 vw jetta removal instructions
Hi. Ther is a special tool for this, but it is clumsy and difficult. The plastic retainer is cheap enough to just break it out and fit a new one in place. fit it into the pedal first then clip the rod in otherwise the rod breaks through the clip before it seats into the pedal.
Jan 18, 2014 | 1997 Volkswagen Jetta
2007 dodge ram 2500 4wd 5.7 hemi. Changed the break pads today and after pumping the breaks firm with engine off, I turned it on to try driving around and the breaks wont hold pressure. I checked to see if...
Could be the master cylinder has gone, if you took the brake line off then you will have to bleed the brake system and that should fix it, you also need to backup and press the brakes so that the pads and piston seat into place but just go slowly and not very far, 10 feet maybe.
Jun 14, 2011 | 2007 Dodge Ram 2500 Mega Cab Laramie
Driver Side Rear Tail lights: running, brake & turn signal do not work. The ground connection is functionind at the lights sockets. The resistance .3 ohms black wire at each light socket to chassis...
I suggtes test the "brake light switch", generally, is located in backside of break pedal. With the flasher unit, just replace it.
Keep us updated.
Feb 14, 2011 | 2004 Pontiac Grand Prix
If I remove a break line from one caliper for replacement, do I need to bleed the breaks on all four wheels or only the one that I have replaced the break line on?
When replacing any brake components it's always a great idea to bleed the brakes. Because your life depends on the serviceability of your brake system. When you open, crack or brake any line in your brake system, you automaticity introduce air into the system. Air can be compressed easily as opposed to brake fluid, which is designed not to compress as well as resist heat. The air in your system will cause your ABS and sensors to malfunction and or not work at all. When bleeding your brake system use this sequence start with: 1)right rear, 2)left rear, 3)front right, 4)front left. All vehicle parts and locations are referred to as the vehicle's left and right sides. Or as your setting in the drivers seat. Hope that helps.
Dec 21, 2010 | 2001 Lexus RX 300
Engine runs good but dies when brake/clutch is let out . This happens with me on the seat,in neutral,parking brake in off but continues to run with parking brake in on position, and motion control lever in...
well the not moveing could be the brakes are rusted look were the break rod goes put some wd40 on that its on the side of the trans and you will need to move back and forth to free it up and the cluch break switch is bad i hope this helps you
Mar 07, 2010 | Husqvarna Garden
NEED TO KNOW WHERE TO WIRE THE PARKING BRAKE TO. I need a diagram for the wiring scamatic
Simple solution i have the same one in my truck! U take that green parking break wire on the screen and conect it to the black ground wire on the vehicle and your screen will work all the time even when moveing!!! Hope this helps!
Oct 14, 2009 | Kenwood DDX-6019 Car DVD Player
Parking break & break fluid indicator is ON
did you check your hand brake? did you check your brake fluid's level? seat belts or doors not properly locked will give a warning sound
Aug 10, 2009 | 2006 Kia Sportage
Brake lights stay on all the time. For some reason, they stay on... I had to disconnect the battery...any clues to why???
ONE SOLUTION, THERE IS A SWITCH BEHIND THE BRAKE, WHEN YOU PUSH DOWN THE BRAKE THE STEEL ARM PRESSES THE SWITCH TO ACTIVATE THE BRAKE LIGHTS, SOUNDS LIKE YOURS MIGHT BE DEFECTIVE.
Feb 24, 2009 | 2001 Dodge Dakota
BREAKS!!!
The brake reservoir is underhood. You'll see it mounted to the firewall at the back of the engine bay, in front of the driver's seat position. It's the only reservoir there, and sits on top of a cylinder made of metal. Should say something like DOT3 or DOT4/5 FLUID ONLY on it - that's the brake reservoir.
Aug 08, 2008 | 2001 Dodge Caravan
Cell Phones Logo
43 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
