Question about Logitech QuickCam Communicate STX Personal Web Camera
Mic works through the 1. USB port, CAM from the 2.
I'd like to have the QuickCam Communicate STX's mic and cam active at the same time.
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Feb 01, 2009
I or they my friends can not get volume
first record the volume in your own pc, then start chatting, and if its a logitech then i hope there is no mic in web cam, try with diff mic
Feb 09, 2010 | Logitech QuickCam Communicate STX Personal...
How do i get my webcam to let me talk to other people
if your web cam doesn't have a mic built in, then i don't think you can talk to other people.
Oct 08, 2009 | Logitech QuickCam Communicate STX Personal...
The mic on my web cam wont work with skype..
If you have a laptop you have to change the default there as well
Audio set up Skype x Vista
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart Computer
When in skype conversation - left click on speaker icon in system tray and check Skype volume is not muted and slider is up the scale.
Aug 29, 2009 | Logitech QuickCam Communicate STX Personal...
Cannot disconnect Mic
It seems to be after new os has been booted the realtek doesnt match wit it so uninstall realtek AC97 audio driver and instal new copy from the mother board cd or use this link http://www.softwarepatch.com/utilities/ac97.html
Jun 04, 2009 | Logitech QuickCam Communicate STX Personal...
No sound
try to find the setings for the mic..and chec for volume ...mute ...if it has something like call setup...also see if the proper mic is selected if it has somethig like this ..it will apear like ...your camera name ...or realteck driver ...selection ...this occures mostly when the mic doesnt have a separate jack ..but works via the same usb plugin
Sep 06, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech
I fixed the problem. Uninstall ed everything and anything that said Logitech from the system. Detached the cam, then rebooted. Then I installed the software & Drivers. Then plugged in the cam and it worked. Had to upgrade the mic drivers for some reason the logitech software debunked it.
Mar 07, 2008 | Logitech QuickCam Communicate STX Personal...
My mic doesnt work
to put that in cam microphone working, you need to see on audio settings properties and change the "recording device" to usb audio device, instaid of the soundcard as is. That means that the sound recording will be from the cam's microphone.
The steps are:
1- rigth mouse click on the speaker next to the clock OPEN VOLUME CONTROL
2- OPTIONS - PROPERTIES - RECORDING
3 - in MIXER/RECORDING DEVICE (where is your soundcard's name) change to USB AUDIO DEVICE and then OK
4- In the remaining volume control window, select MICROPHONE and then close all the volume control windows
5- you can test the mic settings in messenger (any version) because of volume and to a clearest voice sound in your pc.
ATTENTION: carefull with the distance between your cam and your sound speakers because of distorcing sound and feedback
Jan 23, 2008 | Logitech QuickCam Fusion Webcam
Mic wont work
Search for the following file: wdma_usb.inf (be sure to include hidden files in your search)
You will probably find it here: c:\I386\wdma_usb.inf
It also needs to be here: c:\WINDOWS\inf\wdma_usb.inf
If it is not in there copy and paste it.
Then update the driver on the Logitec Mic in the device manager.
This should take care of it.
I got this in the logitech forum, after significant searching for an answer. It worked for me. Good luck!
Oct 05, 2007 | Logitech QuickCam Communicate STX Personal...
Logitech QuickCam STX vista compatibility?
when you were installing the software did a taskbar pop up appear and tell you that hardware was found, and then proceeded to install the cam and inform you that the Logitech STX is now installed and ready for use? If not then the cam may need to be tried in another usb port as of yet it has not been recognised by windows. Also if this is being used on a laptop, sometimes there is not enough power amps being sent be the usb port to recognise, again trying a different port may solve that. If all else fails re install the software again, but make sure windows is allowing the cam to work, as sometimes there is an updater programme that works in conjunction with the cam to update drivers etc, this will probably be being dissalowed by either windows or your internet security programme and any part of the software that is being blocked may be stopping your cam also.
Jun 11, 2007 | Logitech QuickCam Communicate STX Personal...
Have you updated DirectX?, I'm not sure if Vista has DX9.0 or 9.0c, but you could try and update DirectX before you install the cam software. Also if the cam is usb, did you install the software "before" connecting the cam?, some people aren't aware that usb devices have to have the software installed first, before connecting the device.
Logitech QuickCam Communicate STX Personal Web Camera Logo
50 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
