Question about LG WM-2077C Front Load Washer
Leak in the front door
Every time the washer is working there is always a leak in the front door that falls on the floor. The machine has a rubber round thing inside with three holes. One time was plugged with paper I took it off but the leak is still there. Can you please tell me what to do?
  • LG Master
  • 3,463 Answers
If the water is running down the outside at the front of the m/c, then you probably need new door seal.
If however it is coming down the front from the top, then it is coming from your dispenser, check for blockage
Posted on Nov 22, 2008
Wbvh5300k2ww washer leaking
door gasket or door boot or the door bellows, it can be referred to by any of these 3 names
Nov 11, 2012 | Washing Machines
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
Small **** in the rubber molding inside the door; leaking.
You may need to replace the door seal. But first take some 100% pure silicone and push some in the hole and around the hole. Let this dry for 24 hours before using this should seal it up. If this does not work replace the door seal. Here is a link that should help http://appliancehelponline.com/washerdoorseal.html
Jul 12, 2010 | Kenmore 42822 Front Load Washer
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Order/Replace Rubber Boot on Maytag Washer?
it can be quite tricky to fit, you can buy one,I would however advise to get a supply/fit quote from an engineer as he will get discount on the part, unless you are good diy person ,get hired help....
Nov 28, 2009 | Maytag MAH6500 Neptune Front Loading...
My whirlpool front loader washer leaks water in front of the washer from the bottom of the machine. It does not happen with every load. Any idea on the problem?
Check the rubber boot just inside the door. You have to push the drum back slightly and rub your fingers around the entire boot. I had a similar problem and a key had fallen out of a pocket and cut into that boot. The leak would run out of the damaged boot then come out the bottom onto the floor. I purchased a new boot and it took me about 30 min to install it. The problem was solved. If the rubber boot is fine then the over soap thing is probably your problem.
Oct 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE FRONT LOADER WASHER LEAKING WATER
inspect the door boot the rubber thing between the tub and door also inspect the hoses inside the machine you will see the leak
Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door seal is torn at the bottom and leaks water on the floor
take the top off look down where the seal meets on the drum there should be a metal band the goes all the way round the rubber seal .you should see a long screw and bolt holding the band together unscrew the bolt and pull the seal off . the same on the front of the washer good luck
shaun
Mar 27, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
LG WM-2077C Front Load Washer Logo
118 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
