Computer was suppose to have internal modem cant find it...no phone jacks found
  • Mike S
    Mike S May 11, 2010
    maybe it is a "Wireless Phone"
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Is this a desktop or a laptop? What operating system are you using?
Posted on Nov 22, 2008
Setup poster
If you have a phone modem, it usually has two jacks, one goes to the wall and the other is for a phone. There will be little icons that will represent a wall jack or phone.
If all you see is one large "jack", that may be the ethernet or NIC jack; you might not have a modem, as many newer computers don't come with a phone modem.
It's cheap enough to buy a phone modem that plugs into a USB port, or to get an internal modem.
With the model number, someone might give a link to a picture showing the ports available, and their titles.
Oct 29, 2013 | eMachines Computers & Internet
My dimension 3100 is not detecting a modem
Sir,
Respectfully please first check if there is a modem in the desktop PC since the dimension 3100 is not pre-equipped with a modem. you have to attach an internal modem manually on one or more PCI slots on the mother board.
the process is given here....
  • Turn off the computer. Unplug the power cord from the electrical outlet. Disconnect the power cord, attached peripheral devices and any other cables.
  • 2 Locate the cover release latch on top of the computer, near the back. Place the computer on its side, with the removable cover facing upwards. Slide the cover release latch back and lift the removable cover off of the computer. Set the removable cover aside.
  • Locate the PCI and PCI Express slots near the bottom of the system board. Select a slot that corresponds with your internal modem card. Open the card retention door on the back of the computer and remove the filler bracket for the card slot you will be using.
  • 4 Place the internal modem card into the appropriate card slot and press it firmly into place. Close the card retention door. Replace the removable cover and return the computer to an upright position.
  • 5 Connect one end of the telephone cord into the LINE port on your internal modem card; plug the remaining end into a telephone jack. If desired, connect a telephone to the internal modem card via the PHONE port.
  • 6 Reconnect the power cord and all previously disconnected cables. Plug the power cord into an available electrical outlet. Turn on the computer. If any installation software came packaged with the internal modem card, run the program and follow the onscreen directions. Your internal modem is now ready for use.
  • May 06, 2011 | Dell Dimension 3100 PC Desktop
    HOW DO I CONNECT DSL LINE TO LINKSYS WRT54GS
    The WRT54GS does not have a jack to connect a phone/DSL line to, so in order to use this router with a DSL connection, you'd have to connect the DSL line to a modem and then connect the modem to the router, or connect the DSL line to a computer if you have an internal modem, and then connect that computer to the router.
    Dec 15, 2010 | Linksys Wireless-G Broadband Router
    Got dynalink V1456VQE modem need to install please help how to
    internal modem installing:
    1.Switch off the power,and remove the power card from the cpu.
    2.Get the cpu separately.
    3.unsqrew the sqrews and open the system box
    4.you can find the white color slot in the mother board.
    5.fix the modem with that slot (Modem Board has the single cutting).it must be fitted with the PCI slot.Slight press down.
    6.then ON the system,
    Start->all programs->control panel->system
    ->Hardware->Device Manager
    now you can see more items on screen,also you can found the modem which you have installed.
    Your new modem is ready to use...
    7.If your modem came with cd,then insert the disc in cd/dvd drive .Gently Installed the cd...
    8.Then Restart the computer.
    External Modem Installing:(We do not need to open the system case)
    Type 1:(Using Ethernet Cable)
    1.Insert the ethernet cable(RJ 45) in the modem,and connect the other end of the cable to cpu.
    2.insert a power adaptor in the modem jack.
    3.insert the phone line in modem phone jack.(RJ 10)
    4.On the system and Modem.
    5.Your new modem is ready to use...
    Type 2:(Using USB cable)
    1.Insert the USB cable in CPU,and connect other end of the cable to modem .
    5.You must install the driver software cd came with your modem
    6.Restart the computer
    7..Your new modem is ready to use...
    Feb 13, 2010 | Dynalink (V1456VQH) Modem
    Cant find the ethernet port on my sony desktop
    It should be located on the top right hand side, on the SIDE of the computer. It looks just like a phone jack hook up. Hope this helps. Also, if you don't have one or can't find it you can always plug in an adapter to the telephone line and then you can plug the ethernet cord into that.
    Mar 07, 2009 | Sony VAIO PCV-RX470DS PC Desktop
    Lightning strike
    It is the computer's internal modem. Replace the modem and the problem will be solved.
    Thanks and please take a moment to rate as FixYa. Thank you.
    Jul 23, 2008 | 2wire HomePortal 1000HW DSL Modem and...
    Reconnecting phone line
    Because the new computers from Dell don't come with modems. You have to ask for them. I found that out yesterday when I was purchasing a new computer for work. Quite frankly I haven't seen a modem on a computer in years.
    If there is a modem on your computer it should be a card with two phone jacks. One for line and one for the phone. If you are going to use a dial up connection take the phone cord from the line and plug it into the phone jack marked line. If you dont have a card with two jacks next to each other then you don't have a modem. If you already have a network in the house you can run a network cable to the router.
    Jul 04, 2008 | Dell Dimension 8200 PC Desktop
    Two modems
    easier to just get a wireless usb adaptor works fine. :)
    Jun 19, 2008 | Actiontec (GS503AD3-01) Modem
    No Dial Tone on phones or modem
    if you have a dial tone when your computer is not plugged in, then the problem ls with your computer[ a possible short in the computer] the phone cord to the jack, or anything in between such as a dsl modem.if you have dsl, be sure your ethernet cord [ that's the wider plug cord] is in the wider jack in back of the computer. it wont fit in the regular phone jack.if you have dial up, be sure the phone cord is in the regular jack not the ethernet port.[if you have one]
    good luck
    wg
    Jan 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
    Computers & Internet Logo
    27 people viewed this question
    Alun Cox
    David Payne
    David Payne
