Question about Whirlpool LER5636P Electric Dryer
Dryer not heating
Whirlpool heavy-duty-extra-large-cap ) is not heating
  • Anonymous Nov 25, 2008
    Dryer is not heating
  • Anonymous Feb 18, 2009
    dryer runs wont shut off unless i shut it off and has no heat
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
2 Suggested Answers
james klgr
  • 362 Answers
SOURCE: how do I get to the heating elements in my dryer.
there is a metal panel on the back that bolts on remove it then you will see a metal tube and it will have wires to it and a place to remove 2 or 4 screws to remove the area with the wires these wires attach to heating elements its easy to spot once back is off
Posted on Oct 26, 2009
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I get to the heating elements in my dryer. It is a ge model 5 cycle automatic heavy duty extra large cap
Oct 26, 2009 | Dryers
Whirlpool dryer won't heat how can I fix?
Hey, I just read an article online titled, Testing for 240 Volts to Your Dryer - Without a Voltmeter, here's the link http://www.davesrepair.com/DIYhelp/DIY240Vtester.htm
I am not sure how you could test anything else though, such as the thermal fuse or thermostat, without the Volt/Ohm Meter. They are about $10 at any big box home store--we just went ahead and bought one.
Apr 26, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Jan 19, 2009 | Whirlpool GGQ8831L Gas Dryer
Heavy duty cycle no heat
IF there is heat on every other cycle you have a bad timer. Replace the timer and that should fix ya up.
Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
203 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
