Question about Dryers
Not getting hot then made loud noise and quit
The dryer was not getting hot so my husband cleaned the vents and then it seemed to be working, it heated up. Then about 10 minutes into the cylce I heard a loud noise and then it quit. When I tried to restart it it wouldn't, help. This was a great dryer, it dried so quickly compared to my others and I haven't used it that much so I would like to repair it if possible. Can you offer any help. Thank you, My dryer is only 2 years old. I do maybe 3 loads a week. One day last week it stopped heating. We cleaned the lint out , it then worked right for 2 loads and now doesn't heat atall. Can this be fixed ??
  • alanw04104 Nov 23, 2008
    Dryer still not giving heat. cleaned the lint it worked two loads then stopped giving heat . this dryer is only 2 yrs old. should it be doing this already??
    Guru:
  • 1,342 Answers
Here is a link to a great troubleshooting resource. Sounds like the thermal fuse may have blown. This guide will explain exactly where it is located.
Posted on Nov 23, 2008
    Novelist:
  • 98 Answers
There is a possibility, depending on your circuit-breaker setup, that your dryer is on a double breaker. If one of the sides of that double breaker trips, you will usually not get power at all, however, sometimes when this happens, the motor will still turn, but there will not be enough voltage running through that one breaker to power the heating element as well. Hopefully this will help. Have a great day!
    Genius:
  • 3,422 Answers
HI,
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Nov 22, 2008
    Genius:
  • 1,847 Answers
Is this a heating issue or the fan is not working. let me know the status ...thanks ...kevin
2 Suggested Answers
WhoDoctorK9
  • 41 Answers
SOURCE: After one 80 minute drying cycle, the clothes are
Depending on the make and model, you should have a temperature sensor somewhere on the heating element box. That may be malfunctioning. They are usually less that $10 USD and replacement is real easy. Simply unbolt the old one, pull the two wire from it, put the wires on the new one and rebolt it to the heater unit.
Posted on Mar 29, 2009
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 | Dryers
Makes a loud noise
needs new bearing kit ,it will collapse soon,
Apr 09, 2014 | Bosch Nexxt 500 Dryer
Our dryer is making a VERY loud squeaking sound. 18 months ago we had this problem and we heard that some dryer models are designed to make an irritating sound if there is an airflow issue - typically...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 09, 2011 | Fisher and Paykel Dryers
I have a Maytag dryer that started making a loud noise (loudest when first turned on) but was still functioning. We still used the dryer until we could get it repaired. Now the noise has stopped but the...
Make sure to wash the lint screen with detergent and hot water to remove fabric softener deposits which block air flow. The noise may have been the air impeller (fan) which may have come loose from the motor. Have you checked for air flow from the exhaust? If nothing, look to the impeller. Hope this helps!
Sep 23, 2010 | Dryers
My Kenmore front loading dryer squeaks loud now when I start drying clothes. I clean up around the dryer and took the vent off and cleaned the lint and particles out of the vent and vent tube.sometimes it...
either the bottom pulley or the rollers are whats making the squeking noise you can buy a dryer belt kit which comes with two rollers pulley and a new belt for around 25-30 from marcone appliance
Jul 12, 2010 | Dryers
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
GE Dryer makes deep sounds when hot and tumbling
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Dyrer gets to hot
heatman101
a454a
Jan 04, 2009 | Kenmore 62602 Electric Dryer
Maytag dryer
it sounds like there is no air flow check outside of home where vent exits house there should be strong air flow it either a blocked venting or a bad blower fan in the dryer most likely blocked venting start outside then work your back to the dryer if no air flow outside remove venting from the dryer ifgood air flow here the vent is blocked if not blower fan most likely broken these blower fans drive hub round out on the motor shaft of the motor but it would be very loud this should fix it for you thanks kevin
Sep 30, 2008 | Whirlpool Dryers
Bosch Dryer doesn't dry clothes
With the dryer not connect to the external venting turn the dryer on and see if there is air coming out ot the vent from the dryer. Is this flow of air strong or weak?
If weak then there could be a problem inside the dryer some where. Perhaps the fan is not operating properly. Just my thoughts.
You say you have check the beginning and end of the duck vent pipe. How about seeing if it venting duct is clear from one end to the other.
Good luck
Jul 13, 2008 | Bosch Axxis WTA4400 Dryers
Dryers Logo
74 people viewed this question
Top Dryers Experts
Marvin
Marvin
