Question about Epson Stylus CX3200 All-In-One InkJet Printer
CX3810 printer will not print
The pop ukp keeps teeling me there is a paper jam and that is the reason nothing will print. There is no paper jam, but it won't print. I have followed all the instructions to clear up this problem, but after following all the instructions it still won't print. The the sheet of paper comes through blank.
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Take out the cartridges from the printer, put them back.
Remove the printer completely from your computer. Reboot. Re-install the printer.
Try to print again.
It sounds like your print heads are shot.
Posted on Nov 21, 2008
This printer keeps displaying 'paper jam' every time it loads a sheet of paper to print. There is no paper jam & I have rebooted it many times to no avail.
One of the reasons why such error flashes is because the paper or media your are using might not be suitable for the printer. Always check on your paper preference before printing.
Oct 22, 2012 | Brother MFC-3240C All-In-One InkJet...
Message shows 'clear paper jam then press check paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Hp6210 says "Paper Jam. Clear Jam and then Press OK". There is no paper stuck in it, nothing visible at all.
Open the rear clean out cover and check for a jam. Or the rear clean out cover could just be off like mine was. I was get out of paper message. So I found a the HP help manual that there was a rear clean out. I reached around back and found that i twas off, I popped it back on and it works just fine now.
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printer jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 04, 2009 | Lexmark JetPrinter Z605 Color InkJet...
Paper tray feed problem
the shaft the roller is on is bent or the clutch on the left of the shaft iis broken.
Jan 02, 2009 | Samsung ML 1510 Laser Printer
Paper jam
My CX3810 started doing the very same thing. To solve the problem, I un-plugged the printer, turned it upside-down (while holding the scan-bed cover closed) and shook the printer vigorously for a few seconds. Lo and behold, a small, white finishing nail, a peanut and a ball of fluff fell out of the slot where the paper loads. I sat it down, plugged it back in.... works flawlessly again. Hope this helps.
Jul 22, 2008 | Epson CX3810 Stylus Color All-In-One...
Paper Jams and Margin Incorrect
Check the humidity of your paper, type and weight. Nothing more than 32# will run through the tray, any heavier should go through the bypass to prevent jamming. Margin follow the internal tutorial for moving your margins. Xerox machines do skew 3 degrees left for some reason or the rollars that feed from tray 2 need to be changed.
Apr 01, 2008 | Xerox Phaser 7750DN Laser Printer
"not ready to print" message
I just recently had the identical problem. Go to "start," click on "printers and faxes"; right-click on the icon (or copy for it) for your printer; select from the popup menu, "default printer." This will put a check mark by the printer icon, and possibly simultaneously remove the check mark from another icon that was a deadend. I encountered this problem when I replaced my paper-jammed epson stylus CX3810 inkjet printer with another almost identical printer that had been abandoned by an acquaintance. [He had abandoned it because his ink nozzles (except black ink) had clogged up. I was grateful for it despite the seemingly irreversibly clogged nozzles.] I think printer manufacturers should work on more user-friendly designs that allow easier repair of mechanical problems like paper jams!
Mar 28, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
53 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
