Question about Garmin Nuvi 660 GPS Receiver
Add Europe sd card to Garmin 660
When adding the new Europe sd card do I need to first back up the United States maps on my 660
  • Garmin Master
  • 2,130 Answers
No. When you plug in the SD card, the Nuvi will load the map from your SD card. Once you get to the main menu, select the wrench symbol, then the map symbol and then "map info". You should see both the US and Europe map. Make sure the Europe map is checked. You can uncheck the US map. This is how you switch between maps. The reason why you have to have the extra map on the SD card is because the Nuvi can only have one map on it's internal drive, one at a time.
However, backing up your US map is a good idea.
Good luck,
- Jim
Posted on Nov 22, 2008
Why when I try to enter an Address with State = California, my Garmin Nuvi 660 only shows "Cayman Brac" and "Connecticut"? I'm on software version 4.90 and I have "CN North America NT 2015.40 ([1] Lower...
CN North America NT 2015.40 ([1] Lower 49 States NE)
NE = NORTH EAST... California is not in the North East of the United states. This device only has a small internal memory so you need to use a 4 GB memory card and load maps to that card with MapInstall:
How do install mapping to my device with MapInstall
Mar 24, 2015 | Garmin Nuvi 660 GPS Receiver
I HAVE PURCHASED EUROPE MAPS FOR MY NUVI 600, I CANNOT DOWNLOAD IT ALL AS I DONT HAVE ENOUGH MEMORY, CAN OU SUGGEST WHICH SD CARD TO BUY PLEASE
Any standard SD card will work (not micro SD unless you have the standard SD adapter) and you will need a 2GB card. You can find them on eBay or most electronics/PC retailers.
- Jim
Jan 27, 2011 | Garmin Nuvi 660 GPS Receiver
I ERASED MY SD CARD TO MY GPS HOW CAN I GET MY
If you don't have the discs, you can buy new maps from Garmin.com
Dec 15, 2009 | Garmin Nuvi 660 GPS Receiver
I have a Garmin Nuvi 260 and I just purchased a City Navigator Europe N/T data card. I inserted the card and didn't see anything that showed it was added. Do I need to be in Europe for it to work or do I...
As long as you can see the software on the list of Maps, you'll be fine. It wont show any maps right now because there are no European maps for your present location, you need to be in Europe for the maps to show on the screen.
Sep 19, 2009 | Garmin Nuvi 660 GPS Receiver
Change map setting
Buy the package first from Garmin.com
SD card, download, disc, which ever.
in your Menu, touch maps, map info, tick the box when loaded on the device.
You may need unit I.D. to activate it,
it's in your tools-system-about menu
and serial number on the bottom of device.
I hope this helps
Regards.
Apr 13, 2009 | Garmin Nuvi 660 GPS Receiver
How to upload maps in garmin 200w from sd card
on menu touch tools, maps, map info, tick the box, you may need unit I.D. and serial number.
Regards.
Mar 21, 2009 | Garmin Nuvi 660 GPS Receiver
New Maps - Can't update unit
The new maps will be unlocked to your GPS using the code Garmin supplied you.
You will have to add these maps to a second SD card if your present card is full, or else purchase a larger card. Since all the Mapsource NT 2008 Europe maps are 1,395MB in size, you'll need to purchase at least a 2GB SD card.
Mar 27, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Nuvi 660 MapSource
Henry,
You cannot replace American maps with European maps.  Garmin does this in order to protect the European retailers.  The European SD card eliminates the need to load the maps into the 660, however, if you need to use the card slot to store extra data such as MP3s then you might be better off buying the 670.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
CN Europe NT will not download on Nuvi 660
From the main menu look for settings, then Map, then Map Info, verify that a check mark is placed next to the new maps.
Sep 04, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
826 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
