Washer still leaking
My washer is leaking alot of water. I thought it might be a hose but I've checked them all and nothing! I pulled out a piece of plastic that was tangled in a wheel at that shoots the water into the drum and sucks it out when spinning but it just keeps on comming out.
  • 111 Answers
THAT SOUND S LIKE UR PUMP REPL/
Posted on Nov 30, 2008
Kenmore washer Model A107 is pouring water out from underneath
More then likely it is the dis-charge water from pump hose. But if ya got a new machine why not!
Feb 16, 2013 | Washing Machines
How to remove powder drawer indesit w1a101
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front
Sep 27, 2012 | Washing Machines
Machine leaks water
The most common place for a front load washer to leak is in the bellow. This is the rubber piece right inside the door. Pull the rubber piece back and check for tears or holes. If there are not any holes then there is probably a hole in the hose that runs from the tub to the pump. Sometimes stupid things like bra underwire and bobbi pins get in here and tear them
Aug 25, 2012 | Maytag MHWZ400T Front Load Washer
My Maytag Ensignia washer is leaking water from the pump area of the washer. I've eliminated the drain hose and I've traced the leak up to the area of the plastic casing around what looks to be the...
Look for broken plastic casing of the pump. A hairline crack would also leak water. Check for proper fitting of flexible hoses to & from pump. Another thing is to check for loose filter cap. A loose filter cap or broken O ring of the filter cap can leak water.
Sep 18, 2011 | Washing Machines
Water leak coming from under my washer wirlpool duet. what would be causing that?
you can remove the bottom panel in front on this unit... the screws are near the floor then that bottom piece can be pulled away... there is a clean out next to the pump assembly run some water and see where water is coming from most likely a hose or pump assemble is leaking ..check all hoses like i said run unit and you should be able to use a flashlight and find the culprit water leak...
good luck to you
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
RE: Water Leaks from Detergent Compartment
I don't know what else to tell you.  I hope that whatever the problem was, it is permanently gone.  Good luck.
Apr 27, 2008 | LG WM-2277HW Front Load Washer
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
WD640 Aquarious supersilent washer/dryer leaking from powder draw
during the rinse the machine uses a higher level of water, therefore check the door seal for holes,if the water is leaking from the soap drawer in the spin then this suggests that you may have a blockage in the outlet hose or in the sump filter, to check the filter remove the sump hose, the filter is hidden in the hose. Regards Engineer
Jul 29, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
