Question about Zanussi ZJD1219 Front Load Washer / Dryer
Maytag Washer won't switch from rinse to spin
I have a Maytag Dependable Care plus top load machine that won't automatically change from rinse to spin mode unless I open and close the lid. Water level and everything else are fine except for this little annoying problem. Any help would be greatly appreciated.
You have a bad lid switch. Before I retired Maytag had a lid switch kit that improved the switch that was originally in it. The problem would usually present itself if a person accidentally dropped the lid with a bang which would put the lid switch out of adjustment.
Posted on Feb 01, 2007
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Maytag dependable care plus will fill up with water but wont start cycle
sounds like you have a bad lid switch part 3949247 and it's around 50 the lid,look at the right side,you'll see a hole,stick a screw driver into the hole and push down easy with the machine set on spin,if it doesn't spin and when you push up and down on the switch with the screw driver the lid switch is video
Mar 29, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag dependable care plus washer. Top Loader works through all cycles, but will not initiate or complete final spin.
Bad lid switch wore out needs replace ment or you have bad pump and takes to long to drain send us a model #
Jan 30, 2013 | Maytag Dependable Care LAT9706
Maytag Dependable Care model LAT9634AAE During
there is probably some sort of debris in the water pump a button or other items blocking the flow of water please make Shure to try and turn the water pump by hand in order to free any obstruction eric
Dec 25, 2017 | Maytag Dependable Clean Top Load Washer,...
My top load washer smells like moldy, nasty water
use some vinagar let wash
i heard deluted CLR works too, but delute it really good
Apr 18, 2010 | Maytag HAV2557 Top Load Washer
Should I buy a gently used Maytag dependable care plus model# LAT8824AAE washer? What's the reliability of this machine?
Maytag makes very dependable machines. They are fairly easy to repair and parts are easy to find. If I was in the market for a used washer, a Maytag would be my first choice. Since its used there is no guaranty that the thing isn't going to need repairs. If you can see it run through a cycle before buying it would be a plus. My first washer was a mid seventies model Maytag. I had two minor repairs twice in 15 years and its been working ever since at my buddy's. I hope this helps you.
Aug 27, 2009 | Maytag LAT3600A Top Load Washer
Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Aug 08, 2009 | Maytag Dependable Care LAT9706
Maytag Dependable Care Plus LAT8824
I think that you mean "Agitate" some of the time that you write "Spin" Yes?
If I understand you correctly, you have no agitation during the "wash" cycle, this is almost certainly a corroded agitator shaft seized up in the transmission.
Oct 05, 2017 | Maytag Dependable Care LAT9706
Zanussi ZJD1219 Front Load Washer / Dryer Logo
344 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
