Question about Microsoft Xbox 360 Console
My xbox 360 fan does not work
When i turn on my xbox it does not work. one day when i turned it on it sparked so i opened it and the power supply to the fan is fried. can i wire it somewhere else
  • Anonymous Jan 01, 2009
    3 flashing red lights on xbox360 elite also the center green light does not flash fans will not work and a red light on power supplie stays on always
  • Anonymous Jan 08, 2009
    i put water on my xbox because it got the rrod and the fan stopped working can some one help me.
  • 63 Answers
I am taking a look at the MoBo right now and I cant see any visible traces to the fan connector. I would suggest saving up for a new one. Preferably a Falcon board 360.
Posted on Nov 23, 2008
Well I have understood when you get the three lights and the fans are not working you have to try fixing the first posibilities, like reflowing CPU, GPU, and RAM if one of these do not fix the problem then your motherboard has one MOSFET mess up and need to be replace. When you have overheating problems and your fans are not working, well this is not going to sound so good but helps a lot, what you have to do is cut off the cables from the fan and take the cables out and get them conected to some AC Adaptor and set it to 6V, so this will resolve your problems with overheating. Hope this help.
Posted on Apr 15, 2010
    Problem Solver:
  • 7 Answers
My giant winer in your ********* :)
Posted on Apr 17, 2010
Mine stopped working as well, i wired it to a usb cable but you need to unplug it when your done... is there anywhere else i can wire it to on the board?
Posted on Feb 21, 2010
I have the same problem I got a dc 6v plug charger and spiced it to the fan and it works but it you always have to plug it in when your playing and unplug it when your not
Posted on Jun 19, 2009
I short circuited my positive and red wires to my fans (which are 5.5 and i though they were 12 volts) while trying to wire in leds like a ********, is there some sort of voltage regulator that fried? because as soon as i turn on my xbox my voltage meter says that there's about 10.5 volts coming from the fan pins. When I put any sort of load on to the pins, like a fan or a couple of leds in series its like the pins short circuit and im left with .80 volts. then I have to restart my xbox to get 10.5 volts again. btw this is a jasper console. So im guessing its a voltage regulator or a transistor located near the ran pins.
Posted on Jul 03, 2010
The ac adapter red light stays on and the counsole will not work
This problem occurs when the external power supply has detected a fault. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if one of the following conditions is true:
• There is too much current.
• The voltage is too high.
• The temperature of the power supply is too high.
When any of these conditions are true, the light on the power supply turns red. Here are some steps that you can use to try to fix the problem.
Step 1: Make sure that the power supply is cool
The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red:
1. Make sure that your Xbox 360 console is turned off.
2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
3. Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time.
4. After the power supply has cooled for two hours, reconnect the Xbox 360 Power Supply to the console and to the wall outlet.
If cooling the power supply does not resolve the problem or if the problem persists, use the steps in the next section.
Step 2: Make sure that the power supply is plugged in correctly
Make sure that the power supply is directly plugged into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
If the power supply is still not working as expected, use the steps in the next section.
Step 3: Plug the power supply into a different wall outlet
To eliminate the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a different wall outlet in a different area of your place of residence.
If this does not resolve the problem, use the steps in the next section.
Step 4: Try another Xbox 360 Power Cord and Xbox 360 Power Supply
If you have a different Xbox 360 Power Cord and Xbox 360 Power Supply, try to use them to test the console. If the console turns on when you use a different power cord and power supply, you need to replace the faulty power cord and power supply. If the console does not turn on, the issue may be with the console itself.
Step 5: Obtain a replacement Xbox 360 Power Supply
If the steps in this article did not resolve the issue and the Xbox 360 Power Supply light continues illuminate red, you need to obtain a replacement power supply.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 18, 2010 | Microsoft Xbox 360 Console
Xbox 360 is turning on for less than a second
Got kind of bad news , It is the power supply ,but it's the power supply
in side the box itself. It's more than likely a shorted regulator specifically
one of the 12 volt liner reg chips , I had to swap a few out to resolve
this a few times.
Rob
Jan 21, 2010 | Microsoft Xbox 360 Console
Xbox 360 won't turn on
I had this problem. Make sure the pins in the USB ports (2 on the front and 1 on the back of the console) aren't bent and there's nothing obstructing them. I unbent some of the metal inside these ports, and voila! I have a working xbox.
Oct 09, 2009 | Microsoft Xbox 360 Console
Xbox360 power cycles by itself
do any lights flash etc, if so check below;
Two red indicator lights flash on the Ring of Light, or no lights flash on the Ring of Light. uparrow.gifBack to the top CAUSEThis may happen in the following situations: The auto-off setting is turned on,... loadTOCNode(1, 'cause'); This may happen in the following situations:
  • The auto-off setting is turned on, and the console has been inactive for six hours.
  • The console is too hot.
  • There is a problem with the power supply.
uparrow.gifBack to the top THINGS TO TRYTo identify and fix the problem, follow these steps:To begin troubleshooting thi... loadTOCNode(1, 'whattotry'); To identify and fix the problem, follow these steps:
  1. To begin troubleshooting this problem, check if the auto-off feature is turned on. To check if the auto-off feature is turned on, follow these steps:
    1. Start the Xbox 360 console without a disc in the disc tray.
    2. In the System section of the Xbox 360 Dashboard, select Console Settings.
    3. In the Console Settings area, select Auto-Off.
    4. Examine the option to see if it set for auto-off. If it is set for auto-off, change your selection.
  2. If the auto-off feature is not turned on and this is the first time the Xbox 360 console has turned off unexpectedly, let's do a simple test before we continue troubleshooting.
    To do this test, turn the Xbox 360 off for about 10 minutes. Then turn the console on and see if the problem occurs again. If the Xbox 360 console turns off unexpectedly again, make a note of how long the Xbox 360 console is on before the console turns off automatically.
  3. If the auto-off feature is turned off but the problem happens again, check the appearance of the Ring of Light to determine what to do next.
    • The two lights in the left quadrant of the Ring of Light flash red: The internal temperature of the Xbox 360 console may be too high. In this case, turn off the Xbox 360 console, and let it cool down. It may take several hours for the console to cool enough.
      Also, make sure that the ventilation openings on the console are not blocked. (For example, the ventilation openings may be blocked if you place the Xbox 360 console on a soft surface, like a bed or a sofa.) Also make sure that the console is not located in a poorly-ventilated place, such as an enclosed bookcase or stereo cabinet. For more information about what to do if the two red lights in the left quadrant on the Ring of Light flash red, click the following article number to view the article in the Microsoft Knowledge Base: 907533 (http://support.microsoft.com/kb/907533/ ) Two of the lights on the Ring of Light on the front of your Xbox 360 console flash red
    • No lights are flashing on the Ring of Light: In this case, we should check the lights on the Xbox 360 power supply for hints on how to fix the problem. A green light indicates that the power supply is correctly functioning.
      For more information about the power supply light, click the following article numbers to view the articles in the Microsoft Knowledge Base: 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red
Jul 31, 2009 | Microsoft Xbox 360 Console
My xbox 360 elite worked fine i played it fine then turned it off and went down stairs for dinner came up tryed to play nothings happening the power wont even turn on please i need your ideas on it because...
first try elevating your whole power cord, then make sure its plugged into the wall.
It may be that it needs clean power, and some cheap surge protectors cant supply this forever.
Jul 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 overheats on startup
there could be hardware problems! mine never gave the two lights when it started it but when playing certain games it overheated and thats whats happening.. i got upset and opened mine up[ voids warrenty for three red lights] and added a 3 inch fan with a 12 v converter for its on power. i set it in on the heat sink and the bottom right corner of the xbox..
so i think you should get a powerful 3inch by 3inch fan with its on power supply and set ur xbox so you can point the fan at the bottom of the xbox! this will help! dont open ur xbox just set a powerful fan[ radio shack, walmart, hardware store] and let it cool the bottom of ur xbox!!!!!!!!
Cheapist way
!!items needed!!!
1. 12 v dc brushless fan
1. 12 volt ac power adapter that hooks up to the wall and the fan for a Direct Current!
thats it may cost over 20 and walmart is cheap and a little less quality
but as long as air pushing on the bottom of ur xbox is moving fast[ dont put the fan to close] so heat is transfered ur good
Jun 19, 2009 | Microsoft Xbox 360 Console
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
Xbox360
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one
Sep 06, 2008 | Microsoft Xbox 360 Console
Dead Xbox 360
Yes, the power brick has a yellow/orangeish light, It does not turn green when I try to power on the console.
Aug 20, 2008 | Microsoft Xbox 360 Console
Xbox wont turn on!!
u might just have a overheating prossesor.try cleaning the vents with an airosol spray and either adding a prossesor fan to the vent or setting the xbox infront of a large fan to help cool it .
Jan 05, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
6,700 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
