Question about Yamaha RAV-205 Remote Control
No sound from main channels of Yamaha RX-V2095
I hooked up Yamaha RX-V2095 after four years and I found that main channel of receiver has no sounds. what could be wrong with main channels?
  • 151 Answers
SOURCE: Yamaha RX-V800 - No audio on left and right channels
make sure the (a) speakers are switched on,this may be a switch on the front panel or in the main set up menu.
hope this helps.
cable guy.
Posted on Jun 04, 2008
  • 336 Answers
SOURCE: sound not coming through speakers correctly
Check that the speaker setting on the receiver is set to large not small. (if you have 6inch or larger woofers)
If you have only small speakers you will need a subwoofer.
Posted on Feb 22, 2009
  • 3 Answers
SOURCE: Yamaha RX-V596 main rigth channel problem
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
Posted on May 22, 2009
SOURCE: RX-V1 (No left main channel sound)
Sounds like the output stage of the amp is bad. Needs service.
Charlie
Posted on Aug 24, 2009
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
were you able to solve this one ? I have the same problem with mine. The only way to clear the lack of sound in one of the speakers is to rotate the input knob !!
Posted on Dec 20, 2009
How do I hook up a Yamaha RX-V377 receiver to a Samsung HW-H450 soundbar?
Not sure why you would want to set things up this way, but you have to set the audio output in the receiver hdmi setup menu to tv. This will allow the receiver to pass audio info out of the hdmi jack. By default, this is turned off.
Jan 29, 2015 | Yamaha RX-V377 Receiver 5.1 Channels, 70...
My RX-V2095 cuts itself off about 3 seconds after I power it on. I have unplugged it from the wall to give it time to reset itself and unplugged all components and speaker connections and still I get the...
Try setting the "Auto Power Down" in the "Setup" menu to "off". Double check the selection of the speaker impedance on the back of the unit to make sure it matches your speakers.
Feb 19, 2014 | Yamaha RX-V2095 5.1 Channels Receiver
Charlie
Aug 24, 2009 | Yamaha RX-V1 Receiver
Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
Jul 05, 2009 | Yamaha RX-V463 Receiver
NO INSTUCTION MANUAL. CAN NOT GET IT TO WORK AS A 2 CHANNEL AMP.
Click Yamaha Support and download required user manual of receiver to figure out to set it on 2 channel output.
Need further help, please intimate receiver model number.
Mar 18, 2009 | Yamaha RX-V870 Receiver
Rx v2095 receiver - No sound from either front main speaker
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Nov 29, 2008 | Yamaha RX-V596 Receiver
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
Yamaha RX-V660 right channel gone
Try checking the connections.
If your really value your receiver it would worth it.
Jun 22, 2008 | Onkyo TX-DS575 Receiver
I too am experiencing this problem.... and my receiver is only 5 months old. Its a RX-V661
Oct 30, 2007 | Yamaha RX-V2500 Receiver
Televison & Video Logo
54 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
