Question about HP Office Equipment & Supplies
The printer has stopped printing, will only run the paper thru and stops about half way, and shows an error, when I reset the printer, the same thing happens all over again. 1510 all in one printer HP
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Uninstall the printer.
Reboot.
Re-install the printer and try to print a test page.
Posted on Nov 22, 2008
Epson wide format printer stops in the middle of a job saying paper jam. But I know it is not paper jam.
I do not know this particular printer but several things might be wrong. Make sure all the paper handling sensors and rollers are clean. Check to see if the next sheet of paper is sticking to the first and blocking a sensor. Check to see if the paper is advancing properly. Sometimes the roller will spin but slips on the paper, if the printer senses that the paper is not advancing properly it will throw a paper jam code. Make sure you are using fresh, crisp paper and the holding tray is at least half full.
Mar 17, 2016 | Epson Stylus Pro 10000 InkJet Printer
I'm trying to copy a photo on to edible paper and half way through the printing it stops and says error tried multiple times and every time it's the same thing
Things that can help us solve your issue:
1. Make and model of your printer.
2. Can you print the same image on plain paper?
3. What is the error message you get? It may not mean anything to you, but it may mean something to us.
May 21, 2015 | Office Equipment & Supplies
Canon Pixma iP 6600D printing problem.. went to print a scanned document .... paper began to feed in askew from autopaper feeder . Printing process stopped. the process was repeated a couple more times...
To fix the paper feed problem, Clean / rub each roller with a damp cloth with a dab of detergent.
Check for paper residue , especially near the paper empty flag,
Then reset the printer:
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 29, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Error code E27, ink absorber is full. Call service.
Follow these steps :
1. Unplug the power cord
2. Press and hold down the Stop / Reset.
3. Insert the power cable
4. Press and hold down the power button (the button Stop / Reset fixed in press)
5. When pressing the Power button, then release the button Stop / Reset.
6. Press the Stop / Reset 2 times then release the Power button.
"Wait until the digit 0 appears in the display"
7. Press the Stop / Reset 1 time.
8. Press the Power button 1 time, the printer will print a sheet of paper.
9. Press the Stop / Reset 2 times.
10. Press the Power button 1 time, the printer will mecetak a sheet of paper
11. Press the Stop / Reset 3 times.
12. Press the Power button 1 time. (No printing)
13. Press the Stop / Reset 4 times
14. Press the Power button 1 time rather long and loose (to turn off the printers).
"If the printer still can not get turned off, unplug the printer power."
15. Turn on the printer.
16. E27 error message is gone & the printer is running normally.
Oct 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper starts half way thru printer & stops. have tried different types ofpaper to no avail
Shut down and remove the motor from drive , then manually thread a paper to see the movement. if the paper moves OK then reset and check the paper in detect of the printer.
Now connect and check if thepaper stops after loading, remove printer and uninstall, teh reinstall, connecct printer back and run.
make a test , if not there is error in the main board.
Sep 24, 2010 | HP PSC 1610 All-In-One InkJet Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
Paper jam problem in pixma mp145. E3 error.
I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
Nov 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
