Question about ViewSonic PF790 19" CRT Monitor
PF790 monitor picture issue
Hi, My PF790 had been unplugged/unused and stored away in its original box for a few months. I recently removed it from its box to connect it to a spare computer that we felt could be used as a bedroom HTPC system - for our bedroom, the PF790 could double as a decent size TV. Anyways, once I connected the monitor to the computer, it worked fine for about 10 minutes. I had not used the spare computer for some time either, so had to install few updates and reboot the PC a few times as well. During one of the reboots, the monitor simply stopped showing the picture. The green power LED light stayed green and did not turn orange even after the computer was turned off. I have even tried disconnecting the vga cable from the back of the monitor so that the only cable connected to the monitor is the power cable. Even then, the monitor power indicator led remains green - the LED does not turn orange or display a message on the CRT similar to "No signal - Going to power save mode". Another thing - when I turn the power on (whether or not vga cable is connected to monitor), I hear a very high-pitched/faint noise from the monitor. Finally, the 10 minutes that the monitor did work, for the initial few minutes, I had noticed the lower left and right corners were showing "discoloration"(?) similar to what one would see if non-magnetically shielded speakers were kept near a CRT screen. However, there weren't any speakers or any other sources of magnetism near the monitor or anywhere else in the room. I can do simple repairs (I've built computers, assembled/soldered together DIY-home theater speaker kits, etc), but haven't worked with CRT monitors - would appreciate any feedback on what could be the problem and whether the monitor is repairable or not. Sorry for the long post, but I hope the details can help someone provide an answer to whether I should even try repairing it or not and if its repairable, what would be a good starting point. Thanks and Happy Holidays, -Topper
  • 9,098 Answers
Was it dropped? If so, it could be a board crack or damage to the CRT. Was it stored in an unheated garage, shed, or attic, etc.? Damp air or widely changing temperatures can cause condensation on the circuit boards. Minerals and other impurities can collect on the board via the condensation, leading to some nasty corrosion. Plus in my opinion, late-model CRT monitors are a real pain to work on. Many of them have so many shields and so many screws that before you get the board free to work on it, you're sick of messing with it! *grin* Then when you do some work on it and want to test it, you have to do a lot of reassembly first. I'm sure others will be tempted to jump in here and tell me how crazy I am, but unless they belong to a family member, I don't even work on them any more. When it comes to monitors, I only work on the flat-panel types. But if you go for it, look for electrolytic capacitors with bulging tops or leaking bottoms, bad board connections, etc. Good luck!
Posted on Jan 12, 2007
I have an emachines E181H TFT LCD monitor and a few months ago it would turn off at random and would come back on.After a few days it stopped turning off by itself I have had no problems till recently,...
After a while LCD monitors develop problems that are usually caused by faults in the internal circuitry. This could be an issue with the power capacitors failing. If you feel confident enough, you can remove the back cover and check to see if any capacitors are bulging or leaking. (Give it at least 24 hours unplugged to allow the capacitors to discharge before doing so). I found THAT little bit of knowledge out the hard way
Jan 22, 2011 | Acer AL2017 20" LCD Monitor
I have a Dell 15"
You need a new driver for the monitor. Are you now using a new Operating System? Perhaps Windows 7? Go to the websit and look up your monitor under downloads and drivers. Fidn the compatible driver for your operating system and download it.
Dec 31, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
Hi I am Nithya form Bangalore, India. I bought an Acer CRT monitor (14" inches) 4 years ago. I am facing a problem with it since the last 2 days. I am unable to view the picture clearly, only part of...
Hi Nithya
Try this Turn off the monitor then unplug all the cables , press and hold down the power button for 15 sec , see whether there is any magnetic device near by the monitor , eg Anything which is made of Iron, or any metal, keep them away from the monitor , if this is not fixing the issue , i Guess the monitor need to be serviced !
Nov 09, 2010 | Acer Computers & Internet
Screen "blinks" black every few minutes - Dish Network
Hi, Mary with Dish Network Customer Service. When the picture alternately goes from normal to a black screen, it is an indication of an intermitten signal issue. You can attempt to reset the receiver box by unplugging it from the power for 10 seconds and letting it reboot. Hopefully this will resolve your issue.
Jul 31, 2010 | DISH Network 322 DTV Receiver
Veiwsonic vx912 - ficking on/ off every few seconds
try different video cable or check it, if not power supply.
Apr 21, 2017 | ViewSonic VX912 19" LCD Monitor
Have a look on the back of the monitor for the output socket.
If the socket is blue with 15 round holes then this is a SVGA socket, if it is white then it's a DVI socket. Though I believe that this monitor only had SVGA outputs.
Look for these same sockets on the G4, and connect the cable to the matching socket.
If you have one which is blue and one white you will need an adapter for the cable.
Mar 25, 2009 | ViewSonic PF790 PERFECT FLAT 19" Monitor
Golf 1.6 auto missfire when wet
spay all electrical leads and boxes with wd40 to repell water
Aug 20, 2008 | 2001 Volkswagen Golf
Compaq P1220
If that monitor is out of warranty, it's pretty much a throw away item. If you can find a "donor" monitor with a cracked CRT or case, you could probably swap the high voltage units and get it going again.
Oct 04, 2007 | Compaq P 1220 22" CRT Monitor
ViewSonic PF790 19" CRT Monitor Logo
80 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
