Computers & Internet Logo
Posted on May 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What connector does this hard drive have? Sata or ata? Or what is called? http://www.flickr.com/photos/78399316@N03/7183923756 I need an USB adapter to recover the data from this hard drive, that's the reason why I want to know before buying it.
Anonymous
Level 3:
  • Fujitsu Master 32,281 Answers
  • Posted on May 13, 2012
Anonymous
Fujitsu Master
Level 3:
Answers
32281
Questions
Helped
7907744
Points
102259
You have not specified the make and model of the hard drive so it is impossible to give you the correct advice.
I suggest you take your hard drive to the computer shop and ask them for an USB adapter that connects to your hard drive. That way you be certain to have the correct USB hard drive adapter.
1 Related Answer
Anonymous
  • 132 Answers
  • Posted on Aug 16, 2008
SOURCE: Hard disk power Socket
If its just a case of the power socket broken..
I am able to recover this problem - Where are you located.
Depending on your location - will dictate the next steps..
I have an iomega 31868500 external hard drive I haven't used in years. I now want to use it to store files from my wife's Toshiba laptop running Windows 7.
Hi Jack
It would be pointless having a hard drive fixed to Read Only.
I don't think there is a switch setting to set as Read Only.
The original Iomega (early days) removable cartridge drives had a plastic tab on the cartridge to allow it to be write protected (RO).
So perhaps the Iomega Enclosure (Interface electronics inside) is getting out of date.
The oldest part of your drive will be the Enclosure & USB port.
I would suggest you open the enclosure and take out the actual hard drive. Should still be good to use.
Drives are either 2.5" or 3.5" Size Standard.
Eg Pocket drives are 2.5" size, Slower operation as they use 5 volt only. One bump during use can kill them!
3.5" use 5v & 12v & spin much faster (3500 to 7200rpm) for high speed transfer. Eg Movie Streaming / Fast Backups and are more robust.
The internal connector will either be the older IDE / ATA type connector Or
The new universal SATA connector (serial ATA much smaller)
You will need to determine this.....
The Fix:
The most convenient enclosure these days would be a DOCK type that allows you to plug in both 2.5 & 3.5 SATA drives. AND use USB 3 as a faster Future Proof Hard Drive
Then you can plug one in for Movies and another for Music and a third for Backups. Each drive purchased separately.
Eg 3x 1TB should be cheaper than 3 separate enclosed drives.
I'm sure there is a dual DOCK also for the older ATA connector.
But all future Drives will be SATA.
Once you determine what connector your drive uses then you can plug it in to the more modern housing and format the drive for Windows NTFS or FAT32 (Windows & Mac & TV's)
Cheers
Good Luck
EG: SATA
Amazon com ezDISK EZ0330 USB3 0 hard drive docking station support SATA II...
https://en.wikipedia.org/wiki/Serial_ATA
IDE Connector / Adapter
Vantec CB ISATAU2 SATA IDE to USB 2 0 Adapter Supports 2 5 Inch 3 5 Inch 5...
Amazon com SATA PATA IDE Drive to USB 2 0 Adapter Converter Cable for 2 5... Serial ATA Wikipedia the free encyclopedia
Connector
Parallel ATA Wikipedia the free encyclopedia
Bare Hard Drives: SATA & IDE
They all work on Windows or Mac (After Formatting)
Search Results for Western Digital hard drives at MacSales com
Need connector
I found this possibility
http://www.startech.com/HDD/Enclosures/18in-USB-to-Micro-SATA-Hard-Drive-Enclosure~SAT1810U2 - I am sure you can buy this in other countries, perhaps through Amazon or other retailers. I am sure there other manufacturers of similar products besides Startech.
22.April.2014
1helpful
2answers
Gateway gt4016 motherboard
It has Parallel ATA
PATA or also generally known as IDE,
http://en.wikipedia.org/wiki/Parallel_ATA
1) Harddrive:
101311 - Western Digital, 200-GB, 7200RPM, PATA harddrive,
http://support.gateway.com/s/PC/R/1008842/1008842cl2.shtml
2) Motherboard:
105553 FIC KTBC51G
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553nv.shtml
Product Views; F - Primary IDE Connector,
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553mvr7.shtml
Left side of motherboard, near the black long Ram Memory slots.
This is where the Harddrive plugs in.
Product Views; E - Secondary IDE Connector;
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553mvr6.shtml
Near the black long Ram Memory slots, and next to the blue Primary IDE Connector.
This is Serial ATA, or also known as SATA,
http://en.wikipedia.org/wiki/Serial_ATA
Uses this style of SATA data cable, and connector on motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
(NOTE* Color does NOT matter for cable connector.
Color really doesn't matter, for a SATA connector on the motherboard, either.
You are supposed to plug the Primary SATA harddrive, into the SATA 1 connector, on the motherboard.
The beauty of SATA is, that you can plug into any Ol' SATA connector on the motherboard, that you want to.
BIOS will find the harddrive with the Operating System on it, and will find all the other SATA devices plugged into the motherboard, too )
You do NOT have SATA.
Regards,
joecoolvette
[You may be interested in this,
What's Inside: Computer > Computer Hardware > Explore These Categories,
http://computer.howstuffworks.com/
Also to the left;
Computer Peripherals
Computer Security
Computer Software
Internet
And,
http://www.hardwaresecrets.com/
Click on the headings at the top;
Case, (Computer cases), Cooling, CPU, (Processor), Input, Memory, etc.
Has basic information leading up to technical ]
Is Hitachi 320GB SATA 2,5"
you perches ata to sata connector or sata to ata connector
2answers
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
2answers
I have a sharp avtius al27 laptop. Do all hard drives for laptops fit mine? my hard drive is ATA and new one I ordered is SATA
http://www.pcmag.com/article2/0,2817,1046951,00.asp Read that. You can't just jam a SATA drive into your machine if your old one was ATA
Can Vantec CB-IS100 IDE to SATA converter works to convert Motherboard ide port to sata or it made only for hard drives,cd-roms and DVD rom ?
It attaches directly to the drive, whether it be IDE hard disk or CD/DVD, and is used in boxes that already have sata connectors on the MB. Connector attaches to drive, cable from connector attached to drive to sata connection on MB.
Note: Sometimes these may not work (for a variety of different reasons).
Here is a link to one seller of the converter, read through the reviews. While it works well for most, sometimes there are issues.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232004
1helpful
How can i connect a seagate barracuda hard drive to a sony vaio desktop pcv-rz22g? i'm installing an a additional hard drive but can't seem to find a sata connector on the motherboard, so there's no way...
You can't find a SATA connector because there isn't one. That computer was built before SATA drives were widely available. You will need a Serial ATA controller PCI card to connect your SATA drive to your computer, such as here:
http://www.compusa.com/applications/category/category_slc.asp?CatId=1455&name=Serial-ATA-Controllers&
Make sure it is a PCI card and NOT a PCI-Express (or PCI-e) card, as your computer doesn't have any PCI-Express slots either. Here's an example of what you need:
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=3501402&CatId=1455
Also, the Barracuda is probably a 3.0 Gbps drive, but will only run at the slower 1.5 Gbps speeds from the PCI interface cards. Again, it's an age thing. That computer was a top dog in it's day.
It wont start.. what is sata?
You have to make sure first, what is your HDD type? is it IDE or SATA (Serial ATA).
Check it out: http://www.wisegeek.com/what-is-sata-or-serial-ata.htm
You should plug the data cable, to your hard disk. Remember, there's no way to plug your SATA cable to IDE HardDisk because the connector are not the same (I don't know if there's a converter between it).
So, make sure it first. If it IDE, find IDE data Cable, and make sure it plugged to your MainBoard and Hard Disk. Do the same procedure if it is SATA Hard Disk, only this time you should connect the SATA cable from your mainboard to your SATA Hard Disk.
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
