Question about Panasonic NN-T990SA Microwave Oven
Microwave not cooking
My 1.5 yr old panasonic 1300 wat ss microwave clicks and counts down after I hit express cook or any type of cooking and does not cook. The turntable does not move either.
  • Panasonic Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
The best place to order parts is Tritronics. You can also call them at 866-779-5835
Posted on Nov 23, 2008
My Panasonic 1300 inverter microwave counts down to cook but then shuts off without actually cooking
We don't recommend customer's attempt to repair products themselves. However, if you are going to attempt the repair we recommend you call 800-833-9626 to obtain the unit's service manual.
Mar 25, 2014 | Panasonic Microwave Ovens
I can't enter a specific cook time. only goes 1 - 6 minute. the express cooking times
hit power then select the power setting you want to use 1-10 then enter the specific amount of time you want your food cooked for up to 99 min. then hit start you should be good to go =)
Jan 23, 2011 | Cuisinart CMW-100 Microwave Oven
We have a Frigidaire FMV156DCC that is about 3+ years old. as of last night when the door is closed and the time is selected one of 3 things happen (or doesnt happen) 1. is nothing, just a dark...
I would replace the door switches and set up the door gap to 1/8" just enough to alow for a little play.
Setting the door square is acheived by slackening the lower door hinge and re tightening it when the door is square.
Hope that helps.
Jan 03, 2011 | Frigidaire FMV156DC Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
Oct 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
Timer will run, but won't cook
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
101 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
