Question about Dell 924 All-in-One InkJet Printer
Message says lower exit tray then press select
I do the above and nothing happens
  • Dell Master
  • 4,338 Answers
  1. With the power on:
  2. Unplug the power cord from the wall socket.
  3. Disconnect the power supply from the back of the printer.
  4. Wait 15 seconds.
  5. Reconnect the power supply to the back of the printer.
  6. Plug the power cord back into the wall socket.
  7. Power unit up , this should reset the printer
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 30, 2008
  • Glenda Powers Nov 21, 2010
    This did not work for me. Can you offer other advise?
Keeps telling me to lower exit tray and press select. where is the lower exit tray located/
Perhaps these images will help you. Steps shown is on how to load paper on your Lexmark X7170 printer.
I hope this information has been helpful. Thanks.
Jan 07, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
The printer shows an error message of "lower the
  1. lift the paper exit tray
2. lower the paper exit tray again 3. press the select button 4. Resend your print job to continue.
Dec 27, 2010 | Dell 962 Photo All-In-One InkJet Printer
Top left corner of screen completly black everything else is fine. Please help determining problem?
hi,
i think ur tvs closed caption option is ON. make it of by the following procedure .
1.press menu and select setup
2. in the setup menu select cc.
3.in the cc menu select mode and change it to off.
4. then press ok. exit menu and and watch the corner.
if nothing happened ,
do the above mensioned first two setup and
3. in the cc menu select cc reset and then press ok
ok,
Dec 15, 2010 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Print enevolopes
You are correct. There are no settings listed for envelopes at the Toshiba Interactive Tutorial.
Mar 29, 2010 | Toshiba E-Studio 3511 Color Copier
How to change message tone
do these steps,
1. press menu
2. select settings
3. select phone profiles
4. select on the drop down list (you can see it above on the right hand corner) incoming message,
5. from incoming message settings,scroll down and select tone,
6. locate the file or the tone you want to assign as message tone,
7. select save.
8. exit setting.
Mar 02, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
When switching on laptop. message appears A disk read error occurred. Press ctrl+alt+del to restart. When done this nothing happens. please help.
This usually happens when the operating system is not being read from the harddisk or it is corrupted.
Do one of the following Go the BIOS (Press Del at start up or may be another,it depends on the Motherboard)and in the exit select Load Setup Defaults and exit...select Yes when Prompted.
If this doesn't help press F8,F6 or whatever it is according to your motherboard on start up...and it will direct you to the boot options where you can select 'Last known good Configuration'.
Try and remove any other external devices attached (like pen drive and printer etc.) and then reboot.
Lastly you can install the Operating System again,keep *********** board drivers handy.
Hope it helped...
Nov 22, 2009 | Compaq Presario Notebook
I don't know where to insert the pages to be faxed
Load the paper into the document feeder on top of the machine.
Jul 06, 2009 | HP LaserJet M1522nf Multifunction Printer...
I have Samsung fax & copy machine, SCX 5312F,
Press "Menu / Exit", then "System Data" on the one-touch dial keypad. The display shows the first system data option "Cassette Paper" on the upper line of the LCD display. Scroll through the options by pressing ^ until you reach the option "Message Conf." Then press < or > to select your choice. Options are: ON, OFF or ERR (prints only when a transmission is not successful). When the desired selection is displayed as indicated by the blinking cursor on the lower line of the LCD display, press "Mode / Enter" to save the selection. Press 'Menu / Exit" to exit the menu or "Stop / Clear" to return to standby mode.
Source: Samsung Laser Facsimile User Guide - Digital Laser MFP - SCX-5312F, pages 6.2, 6.4 and 6.5
Jun 12, 2009 | Konica Minolta bizhub C250 All-In-One...
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
Dell 924 All-in-One InkJet Printer Logo
113 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
