Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Problem for Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
I have the HE265B By-Pass
By wongnick on Nov 21, 2008
I have the HE265B By-Pass Flow-Through Hunidifiers installed in the summer, but it never on, until this fall, I tried to turn, but no water flow through. How can I test it?
The contractor is NOT willing to come back with so many excuse ..
Please advise
Comments:
Nov 29, 2008
- After I made sure there is water in, and I turn the humidistat to ON or HIGH, I did not hear a click sound from the solenoid value, does it mean no power to the humidistat or the solenoid valve is not working?
Best Solution
posted on Nov 26, 2008
Helpful)
jjplumber
Rank: Master
Rating: 81%, 6 votes
first break or loosen the water line connection at the humidifier and if you get water then you know it is something else. While the heat is running and main blower is also running, turn the humidistat from low to high; if you hear a click in the solenoid valve (where you checked the water) then you know it has power and the humidistat works. anything deyond that call a good contractor.
Comments:
Dec 01, 2008
- Yes, it sounds like there is no power (24v) going to the unit or it was not wired properly. I would have a qualified hvac contractor come in to fix-it and advise ther other contractor that you are going to notify the better business bureau.
jjplumber
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Questions and Unsolved Problems for Honeywell Power Humidifier:
Do you recommend Honeywell Power Humidifier: Furnace Humidifier/ Humidifier?
Answer
Answer
I have one humidistat honeywell H8908B which presently controlls honeywell humidifiers(HE440A ). I... (More)
Answer
I am getting six blinks on the call for service light after I push the reset button.What does that... (More)
Answer
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate... (More)
Answer
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell Power Humidifier:...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2528
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
