Panasonic dmr-ez45vebs displays hold whenever a button is pressed on the controller, no functions work other than that.
Dear James Birkett,
The problem is "Child Lock" - ergo the solution is just to unlock this protection. The way to do this: Press and hold the "Return" and "Enter" buttons simultaneously until the "X HOLD" title disappears. Anyway, if you wanna activate again, just do similar. :)
Posted on Aug 06, 2009
My panasonic dvd/vcr combo displays the message DV D 2 in the display. Cnnot play DVD
Sounds like your remote code is different to what's in the unit's display (DVD 2). You can try to 'reset' the remote, by pressing (and holding) 2 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore your remote function back to your unit. If it does not, replace the batteries with new ones, and try again.
The remote may require a 'reset' of its command mode (to match the unit) whenever the batteries are replaced.
I assume you can play DVD by pressing the PLAY button on the main unit.
Apr 28, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Hello, my remote for my Panasonic DMR-EZ47V DVD Recorder / VCR Combo recently stopped working, and whenever I press a button on the remote, I get a message on the display as "RC1" I'm guessing...
Actually, you are sort of correct, in a sense, RC1 means remote command mode 1 (the default mode of your combo unit). There is one way you can try to fix this:
Remove the batteries from the remote, press any button on it to clear its existing memory buffer, then re-insert them or replace them with new ones. While unit is on (no DVDs or tapes in it), point the remote at it - press and hold 1 and ENTER/OK buttons together for 10 seconds, then release.
This should (in most cases) restore full remote command operation to your combo unit - if when you press a channel button on it, and the unit's front channel changes, the remote is now functioning as it is meant to.
The good news is this will constitute any workshop repairs or costs (except perhaps new batteries for the remote if required).
I hope this helps a bit.
Apr 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I would like to download the English version of the manual (PDF) for the Panasonic DMR-EZ 45V Video/DVD recorder combo
The manual is available from Panasonic: http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239 . When I fill in the DMR-EZ45V, I got manuals for the DMR-EZ45VEB and DMR-EZ45VEBS.
Additional models are available from the Panasonic UK support site.
I hope this helps.
Jan 04, 2011 | Televison & Video
We have a Panasonic DMR-EH50 DVD player/recorder. We recently moved house and following the move, the FUNCTIONS button on the remote no longer works. Everything else on the remote does. I've tried...
The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Apr 04, 2010 | Panasonic DMR-EH50 DVD Recorder
How do I unlock my panasonic DMR-EZ45VEBS to play all region films
You need to buy a service remote to do this on your model, but the official service remote costs more than the player and is not sold to the general public.
Alternatively, you can rent a chipped regular remote control which does the same job.
In the UK you can get them from www.multi-region.co.uk
Note that on your model there is no other way to hack the player, it can only be done using the correct remote control.
The remote chips are available separately but are not easy to fit unless you're an experienced electronics technician; you can buy read-chipped remotes but they typically cost the dame as the original player.
I hope that you have found my reply to be of use and only ask in return that you rate my answer.
Nov 08, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Remote control to Panasonic DVD/VCR recorder not working
In the setup you can change the remote for DVD1 or 2 .Your handset must be one the same adres as the set.
Jul 24, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Jan 22, 2009 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
