Question about ViewSonic E70 17" CRT Monitor
Viewsonic E71f suddenly a change in colour as if a layer formed
While working the display colour changes into as if a mist formed r a layer some times it regain its colour.
  • gerardapollo Feb 12, 2009
    in fact i thought it was my VGA card i changed it to a Radeon 7000 but the screen lost all his green colour leaving place to a reddish color screen
  • 348 Answers
There must be a loose contact between tracks of base on crt or may be dry solder remove it problem may be solved
Posted on Nov 22, 2008
Windows misting up
Check where the mist is forming.
Does it smell like anti-freeze?
A lite mist on passenger side with loss of coolant you should do a coolant pressure test.
Jan 11, 2014 | Cars & Trucks
My 99 cl has a check engine code of P1297 it says the ELD circuit low input. What does this mean and how do I fix it?
Improve the experience for everyone by voting!
This is just a fancy way of saying your instrument panel lighting is based on diodes.
Electroluminescent display: (More than you really want to know)
Electroluminescent Displays (ELDs) are a type of display created by sandwiching a layer of electroluminescent material such as GaAs between two layers of conductors. When current flows, the layer of material emits radiation in the form of visible light. Electroluminescence (EL) is an optical and electrical phenomenon where a material emits light in response to an electric current passed through it, or to a strong electric field.
Mechanism EL works by exciting atoms by passing an electric current through them, causing them to emit photons. By varying the material being excited, the colour of the light emitted can be changed. The actual ELD is constructed using flat, opaque electrode strips running parallel to each other, covered by a layer of electroluminescent material, followed by another layer of electrodes, running perpendicular to the bottom layer. This top layer must be transparent in order to let light escape. At each intersection, the material lights, creating a pixel.
Since you have a low reading, I'd check the wiring for a corroded ground or frayed wire,
All the best
Jun 05, 2011 | 1999 Acura CL
My Monitor ViewSonic E70fSB 17" Monitor is working
Causes of OSD LOCK
1. The monitor is incompartible with the system unit, especially for newer version units versus older monitors
2.Older monitors display attempting to much up to the improved definition functions of newer system units display an operating system malfunction, interpreted as monitor malfunction instead. OPERATING SYSTEM DISPLAY MALFUNCTION
hardware checks
1. consider changing the graphic card on the system unit after attempting to adjust the appearance settings on the desktop once the computer is powered on.
2.Once changing the graphics card on an old system unit, consider changing the processing chip for reasons of achieving peak performance of the new part installed.
3. Once the fxing of the parts are complete, the monitor would continue to display OSD requiring entire system restart or book. after which, adjusting the appearance setting that should by which time display new list capacities due to the new device changes
Dec 06, 2010 | ViewSonic E70f 17" CRT Monitor
In my View sonic CRT monitor E71f 17",there is a curve appearing on the upper side of the screen and there is some space between the display and the screen, please help. thanks
It's time to responsibly recycle your old CRT monitor, and spend about $100 to buy a new 17" or 19" LCD screen, rather than spending any money at a qualified TV/video technician, trying to trouble-shoot the problem.
Oct 17, 2010 | ViewSonic E70f 17" CRT Monitor
My E771 monitor colors suddenly shifted with
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
My ViewSonic TV suddenly stopped working. The
hi do you mean the colour flashing on the screen, if so it's gone in to screen burn mode try press menu on the remote, retune the tv, if this don't work get back to me with model number of the tv help you a bit more thanks
Jun 12, 2017 | Televison & Video
Viewsonic n3251w will no longer display Closed Captions
You can reset your viewsonic remote control by removing the batteries, and holding the power button down for 10 seconds. Just 10 minutes ago I repaired my remote, which was doing absolutely nothing, not even turning the set off and on, Called Viewsonic, they told me this, and it worked ! Yay !
Dec 11, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Monitor hit with a Headphone
The black spot can stop or keep spreading, but it will never disappear or reduce in size. This is caused from a leak of liquid between layers inside the lcd panel.
Nothing to do apart changing lcd panel. Bring monitor to nearest service and check if it is worth being repaired (changing screen panel).
Mar 04, 2008 | LG Flatron L1750S 17" LCD Monitor
Screen colour error
Recommend to go to the color settings and change it to the use settings and adjust accordingly.
Oct 17, 2007 | ViewSonic VA1930WM LCD Monitor
ViewSonic E70 17" CRT Monitor Logo
165 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
