Question about Jenn-Air JMV8196 Microwave Oven
Jenn Air JMV8196AAS
I was cooking and then the fan came on .... I pushed the fan button off but the fan will not shut off. I unplugged the microwave and the fan will still not shut off. Is the unit safe to use? And what could cause the fan not to shut off?
  • Jenn-Air Master
  • 9,149 Answers
It's most likely a shorted hood fan thermostat or a stuck relay on the control circuit board. We repair these controllers nationwide with our $32.50 service. You can find out about that through the link in my profile. Concerning the thermostat, if you or a friend is handy, it's not hard to check and replace. It should be electrically open when it's not hot. My profile links you to my Web site, where I offer free critical text files on safety & disassembly. Lastly, you can visit the Sears parts Web site where they have helpful exploded view diagrams and where you can order a thermostat if needed. Sears carries parts for many brands. Post back if you need more help.
Posted on Dec 24, 2006
Ihave a Jenn-Air JMV8196 microwave oven. The clock works,the fan works and the light works. Not sure why the microwave will not come on to cook. Help?
The problem is caused by one of three things, the magnetron "heats food" the high voltage diode "sometimes shorts" or the high voltage capacitor " shorts"
Mar 10, 2012 | Jenn-Air JMV8196 Microwave Oven
My Jenn-aire microwave says locked and has a picture of a padlock. I was microwaving bacon and had just put it some to cook ( my second batch per se) and everything was locked up. I tried pushing options...
Most likely you set a child lock (front panel lock) by holding a button too long (3 seconds). Without a model number, I can't be absolutely sure of the keypad lock for your Jenn-Aire microwave. Usually, the key will have a small padlock icon on it. Press and hold this key. On my microwave you press and hold Start to toggle the lock off.
On a Jenn-Aire JMW2430 and similar models, the Button Lock is activated by a several step process (More and Button Lock). However, pressing and holding the Start button will deactivate it.
I hope this helps.
Apr 19, 2011 | Jenn-Air Microwave Ovens
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
Sep 16, 2009 | Jenn-Air JMV8000 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Everything works but no heating?
With inside light and turntable on, louder sound, and no heat, this is usually a shorted high voltage rectifier diode or a bad magnetron.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 14, 2008 | Jenn-Air JMV8196 Microwave Oven
Kenmore 665 68610891- built-in 1998 model
Fan relay on circuit board stuck. Give it a tap (the relay), to free it up. Otherwise get the relay or driver transistor replaced. Easy fix. Take it to an electronic repair place, not the brand agent.(They,ll just replace the whole board).If this Item is under warranty you should not be wasting my time.:::Spiceweasel.au
Mar 30, 2008 | Kenmore 80809 Microwave Oven
JMV8208AAS Jenn-Air runs all by itself
check the door connection. it may be stiking. unplug from the wall and open up, spray wd40 and give it a clean.
Dec 13, 2007 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air JMV8196 Microwave Oven Logo
239 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
