Question about Motorola DCP-501 Receiver
Low channel out put from 2 to 78
Hello, I just received the Phantom. It looks nice. I hooked the unit to my 50 inch Panasonic flat screen an I only get up to 78 and missing quite a bit of channels in between. I have the premium digital channel package and recieve more the 400 channels. This boxs channels from 2 to 78. What do I do with it. Thank you, Thomas
  • blckscape Nov 22, 2008
    Hello, I am going to send the Phantom back. This is not a useful tool at all. The unit was installed correctly, but does not work. Thank you, Thomas
U HAVE TO HAVE IT ACTIVATED BY YOUR LOCAL CABLE COMPANY ASK 2 SPEAK WITH A MANAGER
Posted on Nov 23, 2008
How to hook up cable box to model tz55x71 manufactured 2000 diagram please
You can Google the model number of the Toshiba for a 'manual" or owner manual which will show your set.
Usually with a cable box in goes to box and out to cable fitting on rear of set and set to channel 3. Output of a box with audio/video cables is same except they connect not to the cable fitting but to the rear inputs on back of set.
FYI most cable companies will come out, connect it and hook it up for little or no charge.
May 20, 2012 | Toshiba 50 Inch Big Screen Flat Tv Theater...
How do i hook my dvd player to my jvc 32 inch flat screen tv
U might be putting them in the wrong places or the wrong channel try and go through the channels but make sure they are hooked up right cause it will mess the TV up I did it on time and had to go get me another one cause I messed the sound up Hope this helps ya
Feb 20, 2012 | Televison & Video
Is it possible to hook up a powered subwoofer to this unit? It has a centre pre-out, but nothing labelled for a sub, and the manual is useless. This is a very nice old receiver, works perfectly, and I'm...
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSXD903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
(To the guy [dunnbiker] that says there's no rear channels: You're wrong.) The VSX-D903S has 2 stereo (A/B) channels, dual center channel (place center speakers to the left and right, or above and below the screen), and two rear satellite channels. It is a 3-Ch Logic/Dolby Pro-Logic Surround equipped receiver, not a DolbyDigital/DTS multichannel x.1 surround unit.
Dec 19, 2010 | Pioneer VSX-D903S Receiver
My 50" panasonic tv screen goes completely green I turn off tv and restart and the picture is still great, but it is doing this more frequently
my 50' panasonic some channels are in another lanuage then some channels have no volume the people mouth are moving but no words then some channels are good.
Oct 03, 2010 | Panasonic TH-50PH9UK 50 in. Plasma...
Screen comes on all red 50 inch panasonic viera
the rest of your color spectrum in you r tv has burt out
Aug 21, 2009 | Panasonic TH-50PX75U Plasma HDTV
Sennheiser em100 g2 receiver passes major static to mixer
This is a well known problem with the EW100 series that is easily solved.
You will need to run this reciever into a line input via a mono(TS) jack to jack lead. this will bypass the phantom power.
Make sure that you set the AV OUT to +18 in the reciever menu to get optimum level.
Phantom power is only present in the microphone inputs XLR3.
Hope this helps.
Rus.
Mar 01, 2009 | Sennheiser EM100G2 RACK MOUNT G2 RECEIVER...
Hooking up external speaskers to my Panasonic TV
you will need to buy a surround sound receiver. the new tv's do not have an external speaker jacks on them. you might also try a old stereo receiver hooked up to the tv's audio out jacks
Jan 24, 2009 | Panasonic 50" 720p Flat-Panel Plasma HDTV
My plasma screen reads no signal and not available
Well make sure it's on the right source, I have a 50 inch Samsung and when you're on the wrong channel it'll read no signal and you can't do anything. So make sure you have cable hooked up right and make sure it's on the right source or video channel first. I don't know but this might help.
Dec 21, 2008 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Problems with 50 inch flat screen Panasonic
Yes there is a way to work with formatting your Tv. On your controller go to menu and settings and look for display. you can change where the words display. Bring them up or down. The lines, I'm not sure about. are all your connections nice and tight?
Jul 31, 2008 | Panasonic Televison & Video
Screen blanks out int when on local channels
I had the same problem (a flashing HDMI 1 text box in the upper left hand corner of the screen every +/- 10 seconds) and rebooting the cable box seemed to help. I'd previously tried disconnecting and reconnecting the cables, but wasn't successful. I assume my problem originates with Time Warner Cable.
Jan 29, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Motorola DCP-501 Receiver Logo
110 people viewed this question
Top Motorola Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
richie46
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
