Question about Sony KP-41T65 41" Rear Projection Television
Black Screen: SONY KPR4110 (new='86) 41'' Rear Projection TV
Black Screen: SONY KPR4110 (new='87-'88) 41" RearProjection TV ...about a year after this unit was new it started giving (only) a Black Screen at turnOn (but PowerLight=green/on). The unit has been in storage ever since. Now its out of storage - and still doing the same thing (...thought it might 'fix itself' - guess not!) Found service manual on web (for $36): https://www.partstore.com/ModelDetail.aspx?ModelCatCode=075.100&ModelID=16192 A--SERVICE MANUAL ***NLA*** Sony Part Number: 9-963-419-01 Sony Model: KPR4110 Is there any possibility that this would lead to solution? (used to do electronics in Navy - '64 thru '71 but not since - so skills = 'rusty'. Any suggestions ?
SOURCE: sony tv KDF55WF655
I had the same problem. The sound and picture went off for about one minute and the green power light flashed green. Then the TV came back on. It sometimes stayed on for hours and sometimes went off again in a few minutes. The TV is just over 3 years old. Had the service people out and the problem was the bulb. It cost $420.00 to fix. He said our bulb lasted twice the average life. I wish that I had known this since it is a simple fix and the cost of the bulb on line is under $200.00.
Ken
Posted on Mar 25, 2008
Slinteriors
  • 8617 Answers
SOURCE: sony projection tv convergence issue
You will need two STK392-560 Convergence ICs and you will also need two of the 3.5 amp pico fuses as Sonys will always blow at least two of the Pico fuses. You can get replacement ICs and Pico fuses at the fiollowing link and they provide free instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 10, 2008
  • 185 Answers
SOURCE: sony 65 inch rear projection
behind the front grille there is a wooden panel remove it and yo will see a small black epoxy box with 6 knobs sticking out from it.
with the color turned down all the way, look closely for r,g,b on the box beside each knob this denotes which knob is for which color.
you need to adjust the 1 marked g on the bottom row. this adjusts the green bias to the green tube. this will get rid off the whiteish lines. adjust this knob counterclockwise in a darkened room untill the color shows a black and white picture. adjust slowly as the set will be monitoring what you are doing and will adjust itself as you adjust. bring the green down just enough so you don't see anything, make sure that you don't see red or blue either, if you do also adjust untill you don't see any color. these adjustments should be done with the input set to a video input that has no signal coming in the set will show the input label and nothing else.
when you have the raster( screen ) all dark you can go to an input with a signal and make sure the image is black and white adjust the bias of the color that is too much so that it is black and white.
hope this makes sense to you. now turn the user color control back to where you want it.you are done. reassemble, enjoy
you might have to do this again in a few months as the control you have adjusted are dirty and can't be cleaned with a cleaner.
moving these controls cleans them but the color balance procedure would have to be completed after such movement of these contols and any quick movement would have to be done with the set turned off. a quick back and forth movement will do a better job cleaning the tracks inside that adjustmet block but will mean you will need to do the setup adjustment all over again in order to get the screen blank and the color to balance to black and white. the top 3 knobs are for focus of the individual colos only adjust if the red, green or blue isn't sharp, you can try these to see with out doing harm. finally if thebias is too low then th lifgt on the front of the set might blink at you and the auto alignment might get part way through and stop. if this happens you need to bring the bias adjustment back up slightly. adjust only the bias for the tube that has too much color to start with and if this happens you will know that the bias control you just adjusted is the 1 that needs to be adjusted slightly.
Posted on Jan 04, 2009
video-tek
  • 150 Answers
SOURCE: Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
Posted on May 29, 2009
SOURCE: Sony KP-FX432M91 TV 10 blinks
yuo must repleace ic 8002 MZC3001db
Posted on Sep 06, 2009
Loud pop and then black screen had sound and now notying but a red light in front
Flat panel or rear projection??? If rear projection you need to replace the lamp. If not rearprojection then the powersupply might have blown. Hope this helps.
May 28, 2011 | Televison & Video
I have a GE 52 " rearprojection flat screen picture TV 4 years old. The color conveyance is off and it will not realign using the remote. Help!!
If the convergence option is still visible under the picture settings in the menu. Then the problem will usually be related to the convergence power supply board, which is the board on the far left which is suspended over the main chassis. You can get the convergence power supply board, or have yours repaired at www.tvrepairworld.com
Nov 29, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Watching rear projection tv. A flash and picture went away(Black screen) can still hear program. Is there an easy fix. tv is 13 years old
we have a sony rear projection tv and the picture went but sound is still there. Can you give me an idea what it might be.
Aug 13, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KP-41T65 41" Rear Projection Television Logo
136 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
