Question about Sharp AL-1655CS Laser Printer
SPF/RSPF Jam Sharp AL-1655CS; Paper will not go into the machine when fed through the RSPF tray on the top of the machine. Enters about an inch and then seems to get stuck on the left side and does not feed through. Thanks
  • Mike S
    Mike S May 11, 2010
    You probably need new rollers and separation pad in the RSPF...
    look in where you placxe the paper make sure there is nothing obstructing the path. also ope tne lid, look where the paper comes out, look for an obstruction.
    spay it all out with a can of air..
  • 62 Answers
SOURCE: Paper Jam Message
It the fuser unit thier is a gate on it that sticks.Best if you replace the whole fusing unit.
Posted on Oct 29, 2007
SOURCE: feeder problem..
I had the problem. The feeder didn't work but everything else was okay and the error code sounds familiar. The problem was cleared and fixed with the following codes entered from the panel
#*C*14CC
Where C means push the copy button.
Good luck
Posted on Jan 29, 2008
SOURCE: Sharp AL-1655CS Laser Printer stays in download Mode
you can´t. the only way to fix that is replace to main pwb. i have 3 whit the same problem.
Posted on Jan 31, 2008
goodgold
  • 389 Answers
SOURCE: Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Posted on Mar 24, 2009
  • 990 Answers
SOURCE: I have a sharp al-1551cs copier. When attempting to copy using th
Hello Sir; May be the clutch for the paper deliver roller is defective go change it see what will be happen.
Posted on Apr 27, 2009
Tryong to use top feeder, it keeps reading
SPF is normal document feder
RSPF is autoreverse document feder.
Select the your document feder instaling the copiers,remove any originals to the glass.
Oct 21, 2009 | Sharp AR-168D Black and White Copier
How do you calibrate the scanner bulb? I get a "Check SPF/RSPF" error message when trying to scan a document through the auto-feed tray and a local service company said that the scanner bulb needs to be...
The Calibration of the scanner and calibration of the monitor - a complex process. Prcess requiring special equipment and experienced specialist. Not advantageously buy high-priced equipment for Calibration of its one scanner and monitor. If work high skilled, you it is necessary to return in service for calibration if you want this execute themselves, recommend to build apart monitor on test list, but then on test table by means of regulations adjusting the scanner on colour and density of the scene to build scanner
Sep 24, 2009 | Sharp AL-1655CS Copier
Clear paper jam
Pull out the paper tray and look inside. Open the right door and look for the paper in the bottom and look in, around and above the fuser. If no paper is present, you have have a bad/broke paper detect sensor.
Jul 27, 2009 | Sharp AL-1655CS Copier
Sharp AL-1655CS prints copies off-center to one side, both when being hand fed and via printing through a network copmuter. Is there an adjustment for this?
Check the paper guides in the paper trays, if they are adjustable, make sure the are firmly against the paper in each drawer.
Hope this helps.
Ed
Apr 28, 2009 | Sharp Office Equipment & Supplies
Mar 23, 2009 | Sharp AL-1551CS Copier
Error Message: Check SPF/RSPF START to Resume
I just fixed this problem on my sharp all in one. The white rollers on the underside of the copier cover were not rolling well. I took an alcohol prep pad and started cleaning them, rolling as I went. A large piece of lint fell out. I put the documents in the document feeder and they fed through like a charm. Hope this helps.
Aug 06, 2008 | Sharp AL-1655CS Copier
Feeder problem..
#*C*14CC
Good luck
Nov 09, 2007 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Laser Printer Logo
844 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
