Question about Viking DDBB363 Bottom Freezer Refrigerator
Lots of water in drip tray
I have a three year old Viking bottom freezer. Recently the drip tray has started to fill up and spill over the floor. I spoke to a repair guy I know who doesn't work on Viking but suggested that the element that sits above the drip tray may not be heating and therefore the water overflow is not being evaporated. I felt the heating element and it was cold.
Does anyone know if there is heating element that needs to be replaced,or is there maybe a fuse or a coil or something lese that makes the element heat up? If there is, where can I get a spare and how easy would it be to install.
Thanks in advance for any help.
  • 2 more comments
  • david486 Dec 20, 2008
    The element is above the drip tray and it is coppoer colored and loops up and down on itself to almost fully cover the drip tray.
  • aloof Dec 30, 2008
    I have the same issue in that the drip pan seems to be filling faster than the water can evaporate. Here are some photos. If this post does not work, here it is on an alternate site. http://www.oratech-controls.com/Personal...
    Basically, how can I be sure the Drip pan heater is working or connected properly.?
    This is the view of the wiring. The Drip Pan has what appears to be an element below the pan with two black wires. The black wires are connected to a splice connector. Shown in RED. Two Black wires extend from the RED splice connector and dead end to a plastic connector.
    It appears that it may connect to the mating connectors shown on the lower left.
    Here is the drip Pan. The heating appears to be below the pan with wires coming out on the lower right from under the foil.
    There is a flow switch of some type. I am not sure if this triggers the heater. I can test it but am unsure of what voltages to expect and where. No Schematic that shows this.
    There is a Copper tube that Zig Zigs above the Drip Pan. It feels warm to the touch but will not evaporate the fluid.
    Here is a close up of the wiring again.
  • crabsnak Mar 30, 2009
    i've had the same problem for years and have always had to pull the tray out to drain it manually (resulting in some spilled water and a wet floor). the plastic pan itself is in horrible shape now - several cracks through the plastic that originally i had sealed with silicone. i'm now just trying to find a replacement pan but unbelievably can't seem to find one. i'm currently sitting on hold with Viking (horrible customer service - no one's answering!). anyone know where i can buy a replacement black pan? i have a 2002 model VCSB483-ss
  • Tom Hurley May 11, 2010
    the element you see is it above the drip tray or below it?
  • 42 Answers
Thats called a SERPENTINE, DRAIN PAN (its part of the refrigeration system i'm sure its fine if temps in the unit are good.. There is a small 24 volt dc motor that you can hookup that will help in evaporating that water. Its in the front small motor with molex plug . You need to locate the molex plug from the motor and then find the other side mounted right around it and connect those together. Let me know if you still have issues because viking has aheater you can install that will help with this.
Posted on Dec 20, 2008
I have a whirlpool refrigerator model # eb9fvhxvq0 and serial k00801735
in that tray is a hole for drainage. you may have gotten a frozen pea or something in it. take a turkey baster with very hot water and flush through that drain hole till water drains normal. problem solved.
Apr 01, 2012 | Refrigerators
Freezer icing up
Experienced this problem with Evaporator coil icing up (coil is located inside back wall of the freezer compartment; the ice/frost was visibly blocking the series of louvers or slots along the bottom of the freezer back wall. I think the power outage caused partial melting of an already somewhat iced coil, but when the power was restored the water on the coil just froze solid. When these slots become obstructed the Refrigerator will not cool to its proper 36-40 deg.F temperature and the compressor motor runs frequently and the noise level is louder than usual. SOLUTION: fastest and safest way to Defrost this iced up coil is: (1) turn off 120V power / unplug refrigerator from the outlet; (2) remove all food to another refrigerator / freezer and take out ice cube tray & flip icemaker bail wire to its up (off) position - but leave top freezer basket in-place; (3) remove Bottom freezer basket (which should lift up and out; (4) move refrigerator away from wall - and carefully unscrew and remove white-painted, rectangular metal panel at bottom in the back....... you will see a white plastic water tray below a small fan with black plastic blades...... have a 3x5 cellulose sponge and bucket handy...... (5) open freezer door all the way and set a 21-inch box fan on the floor in the opening or area where the Bottom freezer basket was removed... put a single towel on floor under the box fan if there is significant frost on the bottom of the freezer compartment (there should not normally be any); (5) turn the fan to "Medium" speed with air flow pointing toward the freezer... you will be amazed at how much faster this works than pans of hot water or hair dryers (the latter is potentially damaging and dangerous); (6) with a flashlight you should soon see the water drip-drip-dripping from a spot at the center and bottom of the Evaporator coil - where it goes down a white tube and into the white plastic pan beneath the small fan you saw in Step #4; after awhile (maybe 20 minutes) check the white plastic tray in the back - which will be full of water (sponge it out)... continue defrosting with the 21-inch box fan... check the plastic tray again - and sponge out the excess water. A completely iced-up coil will probably fill the plastic tray three times. Eventually the water will stop dripping - which means the Evaporator coil is completely defrosted. There may be some water that gets onto the floor under the left side of the refrigerator which you will have to wipe up. Reattach the metal panel and reinstall the Bottom freezer basket and ice tray. This process takes long enough that you can clean the inside of the refrigerator while you're at it.
Jul 09, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
There is water leaking in the freezer. I imagine it is the ice maker. There is an "ice puddle" on the bottom level and occasionally water seeps out onto the kitchen floor. Is this easy to fix for a...
my model is not exactly the same but check for this this anyway:
Take a flash light & check for ice in the back vent underneath the very bottom shelf in the freezer. If you see ice in there, completely defrost until the ice is gone & the plastic drip hole is unobstructed. The leak on mine was happening because that hole had frozen over & caused excess water to flow into the bottom of the freezer & out the bottom of the door instead of through that hole.
Apr 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
WATER FREEZES ON THE BOTTOM OF THE FREEZER
I have an LG armoire style fridge/freezer and it had lots ice in the bottom and would eventually drip onto the floor. The problem was with the defrost controller. The moisture that enters the freezer when it is opened condenses and freezes on the freezer coil/fins. There is a heating element that sits under this coil which gets turned on by the defrost controller to melt the frost/ice. As the frost/ice melts it drips into a metal tray which channels the water to a drain hole to have it drop into the drip tray underneath the unit for it to evaporate. The problem is that the before the water has time to leave the freezer, it freezes thereby plugging up the drain hole and thus causing subsequent defrost cycles to have the water flow into the bottom of the freezer where it freezes. Eventually the bottom of the freezer fills up with enough ice for the melted water to flow onto the floor. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
Sep 22, 2009 | Maytag Refrigerators
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Have a 17 year old Kelvinator N640T side by side no frost fridge freezer. Runs well except ice builds up on the bottom of the freezer compartment and when it builds up too much some melts spilling water...
You problem lies in a blocked drain or a broken drain connection to the metal drip tray at the bottom of the freezer heat exchanger. You could try blowing the drain out from beneath the fridge, which is difficult as it is very hard to access. Alternatively you will need to remove the tray. This means you have to remove the contents of the freezer, remove the lower long white metal cover and blow out the drain. Then test the drain with a cup of water. If it leaks into the bottom of the freezer compartment you will have to remove the drain and epoxy the joint together again.
Not a job for the faint hearted!
JB
Apr 07, 2008 | Refrigerators
Water in Freezer bottom
drain line is blocked check bottom tray if is collecting water if not drain line blocked
May 10, 2007 | Maytag MSD2754G Side by Side Refrigerator
Viking DDBB363 Bottom Freezer Refrigerator Logo
1,089 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
