Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
3/4hp craftsman will not close the door fully
New 3/4 hp craftsman-
trolly closes to up stop ok. Trolley on down cycle only moves about 36" & stops either with door connected or not connected. to it. Unit is new & has never been used since it won't close. door! Door opens & closes full up or down by hand. Safety LED's are ok & aligned. Trolley works ok within limits described above either from wall keypad or from remote control. Opener lights work ok, on & off.
Problem summarized: trolley doesn't go far enough on the track to close the door. The door has no obstructions binding or blocking down travel.
thanks, jack duboff
    Top Expert:
  • Sears Master
  • 12,962 Answers
There are adjustments on the unit itself that control the distance door travels to close as well as the force it uses to close. The info and location of controls is indicated in the manual that came with your unit.
Posted on Apr 12, 2017
ctf1800
  • 4402 Answers
SOURCE: Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Posted on Jan 10, 2008
  • 118 Answers
SOURCE: unable to allign inner and outer trolley on a
You probably have a stripped gear. Take the cover off the opener and the bottom will be filled with white shavings and the gear will be missing teeth. You can repair with a liftmaster gear and sprocket kit.
Posted on Mar 06, 2009
SOURCE: garage door opener will not work after gear replacement
Mhindo,
Check this link: http://www.fixya.com/support/t519365-sear_1_2_hp_garage_door_opener_replaced
Should help. Solution 1 did it for me. My comments are under username Otrand.
Posted on Mar 21, 2009
  • 3197 Answers
SOURCE: Garage door opens 1 foot, then stops.
It sure sounds like you have a broken door spring. While you are at it remove the cover and take a good look at the drive gear. It is white nylon and is just in front of the motor. Might be stripped and unable to take the weight of the door.
Posted on Jun 24, 2009
  • 3197 Answers
SOURCE: Craftsman garage door opener 1/2 hp will not open door
It sounds like your chain is out of sync with the limit switches. Loosen the chain enough so that you can remove it from the sprocket on top of the motor unit. Now run the opener until the sprocket runs counterclockwise and stops. Now with everything attached and the door in the open position replace and tighten the chain. You are now in sync. You may need to tweak the up and down limit controls which are on the side of the motor unit.
Posted on Aug 16, 2009
Testimonial: "Awesome. Thank you so much, Don. "
Why wont my 3 remotes (hand held & factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain drive
It could be that your door is binding on the way up and so it stops automatically. Try releasing the emergency pull cord and move the door up and down by hand to see if it is binding, probably near the bottom. The track may be misaligned or there could be something rubbing against the door.
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
We just replaced the "trolley" component of the opener, now when we open the garage door it opens about a foot, then stops like its hung on something... it will go back down. If i help it pass the hun
Check your manual and re-program the up/stop and down/stop position. Also make sure the new trolly is in it's proper position.(in the closed position) Hope this helps
Oct 02, 2012 | Chamberlain 3/4-HP Power Drive Chain Drive...
Replaced the mini belt without incident, actually pretty easy to do. Reinstalled the unit onto the screw and hung in place. Reinserted the wires by color and plugged in the power. The rack and connected...
Start over by removing the belt.
Release the door from the trolley.
Then slide the door/trolly latch mechanism toward the motor assy half way,
Reinstall the belt but not the door to the trolley.
Ativate the remote and where the door stops, assuming it is closing , is the lower/closed limit.
Remove the belt, again.
Then side the door latch mechanism near the end of the trolley.
Reinstall the belt and activate the remote.
It should be close enough to fine tune using the limit switches.
Jul 26, 2011 | liftmaster Chamberlain 20B17 Mini Drive...
I'm having troubles getting my garage door to close. It will go up just fine but when I hit the wall switch when its fully up, I hear a click followed by the 5 flash trouble code. I know this means its...
First of all I have a question. If you cannot get it to close how do you know it will go up just fine?
All your symptoms and the things you have checked still point to the trolley being jammed against the stop bolt. The fact it will not move even an inch says jammed trolley or the up and down limits are completely misadjusted. Remove the cover from the motor unit and look at the limit switch assembly. Make sure the up and down contacts are not both contacting the center contact.
Aug 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have replaced drive gear on Craftsman GDO. Everthing engages and chain moves but door only opens 3 inches are so. Have ajusted opening cointrol on side to max and only 3 inches. When I unlatch GD from...
Loosen the chain enough that you can remove it from the pulley on top of the motor unit. Now with the door closed run the motor until the pulley turns in the clockwise direction and stops. Put the chain back on the pulley and tighten. You may have to tweak the up and down limits now.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door closing
HAVE YOU ADJUSTED THE SENSITIVITY??
ALSO SPRAY THE SPRING WITH A LITTLE WD-40 SOMETIMES THEY BIND AS THE DOOR CLOSES.
Mar 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not work after gear replacement
From your description it sounds like you forgot to plug in the RPM sensor.
Mar 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Installed new worm gear, but now i cant get the door down
Check to see if the 4 wire harness is hooked up from the limit assy.
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener/ brand garage master 1/3 HP
trolley is not attatced to the chain, grab that red rope that is hanging down and give it a ****. run the door up until it re-locks onto they trolley
Mar 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
297 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
