Question about IBM ThinkPad T30 2366 Notebook
Laptop switches off
My laptop switches off automatically after a few minutes i turned it on.This happened when I slamed the door of the counter while my laptop was on the counter.plz help
  • IBM Master
  • 4,806 Answers
Sounds like shock damage, take out the hard drive and turn on the laptop, listen to see if the system fan is running, time it to see if this happends again, if it doesn't turn off after a certain length of time, you know it was only the hard drive that was shocked and would need to be replaced.
if it does, bad news!! let me know for further instruction
regards
Posted on Nov 21, 2008
When i switch the laptop on the interneg connection is on for few minutes then dead i use ethernet cable from router my other laptop has no such problems on the same cable and router
does it happen also when you're on a different network than your home network?
check if the wireless is off.
also check your ethernet card settings. does it get automatic address from your router? try setting a static one.
Jul 11, 2015 | Computers & Internet
Won't connect online
This just happened to my siste and a frind of mine recently. It can be a few things.
Are you connecting via wire from your laptop or wireless? I'm hoping they did not remove a wireless router and not explain this to you.
With a new modem your main IP address would change. First I would try turning off everything, unplug the modem and any connected switches or routers. Wait at least 10 minutes, better yet, unplug them and go to work, go shopping etc.. Then plug the modem back in, wait 2-5 minutes, plug in any routers and switches, wait 1 minute then turn the laptop back on. See if that solves the problem.
Nov 19, 2007 | X-Micro Technology (XWL11GRIX) Router
Brightness on my laptop changes automatically, when i start laptop brightness is good after few minutes it goes down and i cant change it than. please help
Check you power save options on your control panel that would cause that to happen as the back light goes dimmer to save power on your PC.
Feb 22, 2013 | ASUS Notebook K55A-DB51 15.6inch Core...
2004 Fiesta. When I try to lock the car, it automatically unlocks again...
faulty switch somewhere ,would need a play here to locate which one it is but i wouldnt mind betting either the drivers door or the hatch ,if the load arm pistons are weak and the hatch door slams shut the look their first
Jan 01, 2013 | Cars & Trucks
When you switch the laptop on the blue lights on the keybord is on for a few minutes before switched off, but the screen stays black. When you touch over the blue light keys it's turn automatic on? HP...
The touch buttons are there so you can turn your laptop on into the Quickplay feature without having to load into Windows. So basically if you just want to use it for multimedia. If you was to press power button, these will just load straight into Windows. It is meant to do this. If you are saying that the screen doesnt come on when you turn the laptop on and are basically saying that the laptop doesnt boot at all and is just a blank screen, then it is very very likely you have a motherboard failure. Contact HP to see if they have still covered your laptop with warranty as this is a known issue on these laptops and some warranty had been extended
Jul 22, 2010 | HP Pavilion dv6000z Notebook
Turns off and doesn't complete restore to factory default
Actually it sounds like a heat issue. Is the bottom of the laptop getting hot? If so....
Using an air compressor (be carefull you do not need 150 psi) or a can of compressed air blow out all of the vents. Laptops have heatsinks that are so small it does not take much to plug them up.
You can also prop it up on something or get one of the fans to set it on and see if that does any good.
Hope this helps
Apr 21, 2009 | Acer Aspire 5100 Notebook
When I turn on the tv it automatically turns off itself
Back again. It appears that the key is the order in which you connect things and switch the TV on or off. It took some experimenting to get to what's reliable. I'll spare you the details and confine myself to what works.
1. Start with the monitor cable disconnected at the laptop.
2. Turn on the TV with the source set to your regular satellite (or cable) signal.
3. With the laptop on, plug the monitor cable into it.
4. Switch the source (at the TV) to receive the VGA signal (from the laptop).
Voila!
To turn off, reverse the procedure.
Mar 27, 2009 | Televison & Video
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? I am trying to find drivers for my laptop...
check whether the hiberbnate facility is on or off as it is turning off after 8 min or so.
this can also happen due to overheating of the processor , it can turn off itself automatically
try to increase the ram on the system
http://www.driverfiles.net/Other/NEC/page,level2,866,3,resultpage1.html
Jun 09, 2008 | Computers & Internet
Laptop turning off on its own
Over heating. Try clean the air flow. External and internal closed the heatsink.
Mar 01, 2008 | Fujitsu Siemens LifeBook E8020 Notebook
IBM ThinkPad T30 2366 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
