Question about Paradyne 6211 ADSL2+ Router (6211I1200)
Does your router has WDS in it - Paradyne 6211 ADSL2+ Router (6211I1200)
    Genius:
  • 1,269 Answers
New wireless routers are WDS compliant.
Posted on Nov 22, 2008
Where is wds bridging in belkin f7d2301
There is no Wireless Distribution System (WDS) on this Belkin product as it is a SWITCH, not a router.
See the reply from Belkin here.
Belkin F7D2301 Airport Xtreme BS 4th gen client configuration
You would have to buy a router, connect it to a broadband service and put this switch on the LAN side to get Internet access or connect up to a Wireless device.
Dec 23, 2014 | Belkin Computers & Internet
Ddsl 104wt cannot find wds setting anywhere
Here is a link to the manual, it will explain how to set up security for the router:
http://www.dlink.com/-/media/Consumer_Products/DI/DI%20514/Manual/DI_514_Manual_EN_UK.pdf
Mar 20, 2014 | D-Link DI 514 Wireless Router (DI-514)
Can a DLINK DI-634M WIRELESS ROUTER BE USED AS A REPEATER?
No, sadly it doesn't support WDS (Wireless Distribution System), most of the time I prefer Linksys routers since are easy to configure and WDS capable, if you get two of them I'm sure you can establish a WDS network easily.
May 17, 2011 | D-Link DI-634M Wireless Router (DI634M)
Hi, does belkin wireless router model f5d7234-4-h v5 support wds?
Yes Belkin router Model F5D7234-4-h v5 supports WDS. Please feel to contact us for information.
Jan 05, 2011 | Belkin Computers & Internet
I am configuring a engenius eoc-3610 with wds on a wrv210 cisco wireless router but the internet once setup is very slow.
Every node added to a WDS network cuts the network transmission speed in half. This is just a characteristic of any WDS connection, as WDS is a repeater protocol (it has to retransmit everything it receives).
It's not clear from your description whether you are trying to add the EOC and the Cisco to the same WDS network. If that is the case, it's a wonder you got it to work at all, since WDS implementations are model-specific, and usually require every node to be exactly the same model router.
Sep 24, 2010 | EnGenius 802.11b/g Wireless Access Point
I have a THOMSON ST585v6sl with AOL running off
Well it may be possible, only if your wireless router supports WDS. Also, note that in DG834Gv3 , v4, v5 supports WDS. If you have v2 or v1 then it wont connet wirelss with your existing network.
Please reply if your existing wireless router has WDS and the version of the NETGEAR router so that I will provide you with the required steps to make it work wireless.
Jul 13, 2009 | NetGear DG834G Router
Trying to configue a 3com router as an access point
You have to configure the WDS on the 3comm, configuring it to the MAC ADRESS of the BT router (if it is wireless), if not connect it by ethernet and set the 3comm as WDS allowing the other 3 more u want to add as acepted MAC ADRESS for access points.
Feb 20, 2009 | 3Com OfficeConnect Wireless Router
D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Dec 03, 2008 | Computers & Internet
3CRWER100-75 no DHCP IP on child routers
router 1 (base) router 2 (repeater) router 1 (base) is the network, the SSID is where u get your internet connection set router 2 with same SSID, DHCP on. i advise connecting hardline to make sure both routers are working correctly. once thats verified then go wifi
Jun 30, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
What is WDS?
Wireless Distribution System (WDS) allows you to make a completely wireless infrastructure. Normally, the access points must be connected with a wire (LAN). These access points create cells allowing a wireless connection. The WDS feature allows the access points to be wirelessly connected. This feature is normally used in large, open areas where pulling a wire is restricted or not cost effective and in residential circumstances. If the structure utilizing an access point is too large to cover using one AP, a second AP would be used as a wireless repeater. The WDS has forwarding functionality for extending the range of an AP. By setting up an extended service set (ESS) between access points. Stations can intersect with any AP of this ESS and move between the coverage of both APs while the higher layer network connection remains intact.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Paradyne 6211 ADSL2+ Router (6211I1200) Logo
146 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
