Question about Refrigerators
How do I clean the water lines on a refrigerator?
I have a GE Profile refrigerator that has been unplugged for about two weeks while moving. My question is, can bacteria form in the water line and dispenser? If so, what is the best method to clean it? I thought about getting a bucket of water with some bleach added but not sure how smart of an idea that is.
I will be hooking it back up tomorrow 11/22. Not sure if my new filter will handle what I am looking to do. Just don't want to get e-coli or some other bacteria.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 19 Answers
The ice dispenser spill shelf should be wiped dry immediately to prevent spotting if excessive spills occur. Water left on the shelf may leave deposits. Placing a paper towel under the grill will help absorb the water that would normally stand on the shelf.
To remove deposits, soak the area with one of the following solutions:
  • Undiluted vinegar
  • 1 teaspoon of non-precipitating water softener
  • Mixture of 1 teaspoon of citric acid powder (NOT to be used in stainless steel dispensers) per 1 pint of hot tap water.
Soak until the deposit disappears or becomes loose enough to wipe away. Usually 30 minutes of soaking time is adequate.
Posted on Jun 04, 2017
the dr
  • 447 Answers
SOURCE: water dispenser won't work
see my posts in my solved solutions on water line freezing. I can email you a bulletin for a heater kit.
Posted on Dec 06, 2007
  • 126 Answers
SOURCE: kenmore refrigerator leaking at water filter
make sure old gasket came of with old filter or make sure it is real tight you should have got a wrench with the refrig.
Posted on Dec 14, 2007
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
SOURCE: GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Posted on Sep 11, 2008
SOURCE: HOW CAN I CLEAN MY GE PROFILE ARCTIC REFRIGERATOR WATER LINE?
If the yuck is in the dispenser area pop off the bezel around the buttons very carefully and remove 4 small screws and clean with an old tooth brush. Install in reverse manner
Posted on Oct 31, 2009
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile side by side TPH21PR refrigerator leaks water on the floor at left front corner weekly but not daily. It there a fix or should we purchase a new refrigerator.
it sound like the drain pan and the drain line need cleaned or maybe the drain tube got knocked out of the pan, take a light and look and see what you find down there and let me know.
Feb 21, 2011 | GE Profile PSW26P Stainless Steel Side by...
Frig not cooling-water line frozen
Check to see if the fan in the freezer is working. It moves cold air from the freezer side to the refrigerator side. If it is not working or if there is an obstruction in the duct work the issue could be there. Fans and motors are cheap and easy to replace.
Apr 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
Nov 19, 2009 | GE Profile Stainless Bottom-Freezer...
I have a GE profile tfx30PBBB refrigerator
HI, Remove the cover at the top hinge. YOu will find three scrws holding the hinge. Remove those and the door will lift stright up. The freezer side will have a water tube and wire harness. Unplug the harness and there should be a fitting to release the water line' I hope the helps. Please let me know if I an assist you further.
Thanks
Vic
May 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a 2004 GE Profile Arctica, no display, no ice, no water
where the wire from the plug goes into the fridge give it a waggle. and push the fridge from side to side it sounds like a loose connection to me.
Mar 26, 2009 | GE PSC23NGP Side by Side Refrigerator
GE Profile Side by Side - Vegtable bin frozen and water not work
You may need service however you can try several pans of hot water overnight in the fridge, clean out the moisture and restart the next day. The problem may be solved.
Dec 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Unplug it for around 30 mins. then plug it back in and see what happens. Try this before anything.
Dec 26, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
1,303 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
