Question about Tomtom GPS
I cannot get access to tomtom home page to down load my map I purchased
  • 1 more comment
  • jonesaej Nov 21, 2008
    My problem is I download TomTom HOME2 which takes 10 minutes then it tells me its run out of time and the application has failed to integrate properly(0xc00000022)
  • jonesaej Nov 22, 2008
    How do I temporarily disconnect antivirus or firewall and how do I find out if browser accept cookies
    I have tried to turn trend micro off but seem unable to. Also what are the dangers of turning virus protection off even for a short time?
    Sergeant:
    Champion:
  • 283 Answers
To disconnect antivirus go to control panel then remove the anti-virus. after install your gps map install it back your antivirus. thank you...
Posted on Nov 22, 2008
    Genius:
  • 1,550 Answers
Just go to control panel and in that click windows firewall and select off .
Go to control panel -> windows security center ->virus protection and firewall and OFF it .
For accepting cookies just clear all the cookies in the web browser you are using .
    Sergeant:
  • 276 Answers
How do I disable my antivirus program in Windows? he answer to this question really depends on the antivirus program that is installed on your computer. However, thankfully all antivirus protection programs can be temporarily disabled by following the below steps.
  • 3 more comments
  • smarttech Nov 22, 2008
    Locate the antivirus protection program icon on the systray. Below are some examples of what your program icon may look like. Additional examples can be found on document CHSYS. Also moving the mouse over each of the icons and will also display what each of the icons are.
    McAfeeNorton, and AVG examples.
    1. Once the antivirus icon has been located right-click the icon and select disable, stop, or something similar. In some cases you may need to launch or open the program control center and disable the program from the menu that appears.
    If following the above recommendations do not help you with disabling your antivirus scanner you can also boot into Safe Mode, which will not load any third-party programs including the antivirus program. This is helpful for times you're concerned about the antivirus program interrupting a program during an install.
    Additional information about booting into safe  mode can be found on document CHSAFE.
    To specify that you're using a firewall that Windows does not find
    1.
    Click Start and then click Control Panel.
    2.
    Double-click Security Center. (You can also access the Security Center by clicking on an alert sent by the Security Center. For example, if you receive an alert telling you that your antivirus software is out of date, when you click that alert, the Security Center will open.)
    3.
    In the Security Center, under Firewall, click Recommendations. (The Recommendations button is not available when your Firewall setting is marked ON.)
    4.
    In the Recommendations dialog box, select the I have a firewall solution that I'll monitor myself check box, and then click OK.
    When you use this procedure, the Security Center displays your Firewall setting as Unknown, and does not send you alerts.
    To specify that you're using an antivirus program that Windows does not find
    1.
    2.
    3.
    In the Security Center, under Virus Protection, click Recommendations. (The Recommendations button is not available when your Virus Protection setting is marked ON.)
    4.
    In the Recommendations dialog box, select the I have antivirus software that I'll monitor myself check box, and then click OK.
    When you use this procedure, the Security Center displays your Virus Protection setting as Unknown, and does not send you alerts.
    to disable both antivirus and firewall settings click this link and follow the easy instructions step by step
    http://www.bleepingcomputer.com/forums/t...
    How to Enable Cookies
    To enable cookies, follow the instructions below for the browser version you are using.
    Mozilla Firefox (1.0 final release and earlier)
    • Go to the "Tools" menu.
    • Select "Options".
    • Select the "Privacy" icon in the left panel.
    • Check the box corresponding to "Allow sites to set cookies".
    • Click "OK" to save changes.
    Netscape 7.1/Mozilla 5.0
    • Select "Preferences" from the Edit menu.
    • Click on the arrow next to "Privacy & Security" in the scrolling window to expand.
    • Under "Privacy & Security", select "Cookies."
    • Select "Enable all cookies".
    • Click "OK".
    Microsoft Internet Explorer 6.0+
    • Select "Internet Options" from the Tools menu.
    • Click on the "Privacy" tab.
    • Click the "Default" button (or manually slide the bar down to "Medium") under "Settings".
    • Click "OK".
    Microsoft Internet Explorer 5.x
    • Click on the "Security" tab.
    • Click the "Custom Level" button.
    • Scroll down to the "Cookies" section.
    • To enable:
      • Set "Allow cookies that are stored on your computer" to "Enable".
      • Set "Allow per-session cookies" to "Enable".
    • Click "OK".
    Microsoft Internet Explorer 4.x
    • Select "Internet Options" from the View menu.
    • Click on the "Advanced" tab.
    • Scroll down to find "Cookies" within the "Security" section.
    • To enable:
      • Select "Always accept cookies".
    • Click "OK".
    Netscape Communicator 4.x
    • Find the "Cookies" section in the "Advanced" category.
    • To enable:
      • Select "Accept all cookies" (or "Enable all cookies").
    • Click "OK".
    Brigadier General:
  • 6,966 Answers
While downloading, May I suggest you try to temporarily disable your antivirus and/or firewall. Alternately, pls verify that the browser can accept cookies, the temporary internet files have been cleared, you have sufficient space in your temporary folder or recycle bin, and in some instances, allow pop-ups.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 22, 2008
    Appreciate the postback. Additional ideas:
    • To disconnect antivirus would be largely dependent on what antivirus was installed in your computer. In some version, doing a right click on the antivirus icon in the System Tray would reveal option to disable. In some other instances, doubling clicking on the same icon would pop open a new window with the options to disable;
    • firewall - would be inside the Control Panel, opening the firewall properties would again give you options;
    • the fatses/easiest to clean cookies (and for that matter all trash) would be to go to Start, Accessories, System Tools, Disc Cleanup;
    • to enable cookies depends on what browser is being used (IE or Mozilla). Normally there would be an option in the Tools menu.
    Sergeant:
    Champion:
  • 347 Answers
Hello Jonesaej,
Did you already downloaded TomTom HOME2 to your Computer?
When you clikced on download, Did you chose save or execute?
Posted on Nov 21, 2008
  • 1 more comment
  • Santiago Vallejo
    Santiago Vallejo Nov 21, 2008
    Go to this link:
    http://www.tomtom.com/services/service.p...
    And after clicking on Download, select a place on your computer to save it. When you are done downlaoding it, Double click on it and install it.
    Any problems you have, let me know,
    Dahaka
  • Santiago Vallejo
    Santiago Vallejo Nov 22, 2008
    Hello, to disable your firewall:
    Start >>Control Panel >> Winodes Firewall >> Disable
    And your browser does accept cookies since all browers by default create cookies, unless you have disable them..
    Good luck,
    Dahaka
  • Santiago Vallejo
    The risks of turining it off depends.
    While it is off, if you only visit safe webpages such as Fixya and you do not recive any files you should be safe.
  • 19,396 Answers
  • Ginko
    Ginko Nov 21, 2008
    Download the map using a different computer, is the best thing to do.
    Then you try fixing the computer, either by doing a system restore or reinstalling internet explorer.
    see:
    How to perform System Restore
    Internet Explorer: Get It Now
  • Ginko
    Ginko Nov 21, 2008
    Sorry, I did not understand the problem at first.
    It happens quite ofte, see:
    TomTom HOME Connection Help - AVForums.com
    It is because Home2 is stilll in beta and the server is often jammed.
    Go back to Home1 and download the map.
Purchased map for New Zealand online , got receipt but no map!! how do I upload or down load the purchased map ? using tomtom home for tomtom go 910 , or get a refund
Click the Windows Start button and then click Documents. Open the following folder: TomTom > HOME > Download > complete > map. You see a folder with the name of the map you were trying to install, for instance Europe or United_Kingdom_and_Republic_of_Ireland. Open this folder.
Feb 23, 2017 | Tomtom GPS
How do i update my tomtom xl
Go to tomtom home page and down load tomtom home it will step you through it but when you first start go to the back up Icon on tomtom home and back it all up. very important.I did not back up and lost my map and now can't seem to get it back with out buying another map.If you have to remove anything from the device make sure you leave one map, one voice and one application. It will give you a message telling you that you are about to remove the last one so read it well and keep one of each I did not. hope this helps.
Dec 10, 2011 | Tomtom One XL GPS Receiver
Can I get German road and streets. Where? What cost?
The easiest way to get maps is through "TomTom Home" software that you should have installed in your computer. If you don't have it, install it from www.tomtom.com and start TomTom Home. Then plug the GPS docking station to a USB port on your computer and place your GPS on the docking station. Turn the GPS on. If you are asked if you want to connect your GPS to the computer, answer YES. After the GPS is recognized by TomTom Home, you'll get a set of icons on the window screen. One of them should be labeled "get maps". Click on it. Most of the time, only a few maps will be shown. To get access to all the maps you can buy, choose "ALL" from the drop down menu that says "Recommended". Map prices vary by region, but in the USA we can purchase a map that contains Germany and a handful of other adjacent countries for about $90 US dollars.
Plese, report back if you need further assistance.
My ID: alexocuello_
Mar 30, 2010 | Tomtom ONE XL GPS
My Tom Tom Go 300 keeps coming up No Maps found. What can I do?
Either the map(s) in your GPS were deleted or you bought a unit without maps. Your only option is to purchase the maps that you need from TomTom. They cost about $70-$100 US dollars in the US. I do not know where you live or what maps you need, so I can't give you more information right now.
My ID: alexocuello_
Mar 25, 2010 | Tomtom GO 300 GPS Receiver
Map down loads
From what I understand, you have a 30 day guarantee for the latest update map. That 30 day stretch starts from the day of first use (not the time of purchase). It it is not a store demonstration unit then you still have 15 days. It goes without saying that if the licensed map has not updated within the 30 days period, there is nothing to update. You can however still use the Map Share feature to download the minor map corrections.
I suggest you frequently connect your unit to the calculator and the Tomtom Home software will do the automatic updates. If a new map is issued within your 30 period you will get. Even if you missed it you should console yourself in the knowledge that major map update are not that frequent. You can also buy other maps from Tomtom.
Jan 02, 2010 | Tomtom One XL GPS Receiver
Are there any new update maps for my new 340 s Tom Tom
If you bought your TomTom brand new, the first time you installed the TomTom Home software, you may have received a message that a free map upgrade was available. If you did not receive that message, then either the unit is up to date, or it was not new.
You can check the version of map you're using by going to the TomTom Home software, and from the main menu, click the "More" button to get to page 2. From there, choose "Manage my ONE XL", and click on the "Items on Device" tab.
Click the "+" sign to the left of the word "Maps", then click the "More Info" link to discover the version of map you are using. The most current version (as of December 1, 2009) is 840.2568.
If that is not your version and you believe you're entitled to it, call TomTom technical support and state your case. Otherwise, if you want this version of map, you will need to purchase it.
When trying to load a new map onto your device, make sure you first run the backup routine (in TomTom Home) to back up the old map. After downloading a new map, but before it can be installed, you'll need to remove the old map, since there isn't enough room on the device to have both maps loaded simultaneously.
Hope this helps.
Nov 01, 2009 | Tomtom XL 340S Car GPS Receiver
TomTom Home will not download from www.tomtom.com
I have down loaded western map from tomtom home for free and all my map of the UK vanished and now there is no map in my tomtom will any one help me out to solve my mysterious problem rasana
Jun 28, 2009 | Tomtom One XL GPS Receiver
Down loading Europe on my TomTom 1/3
Yes you can I have europe and canada on mine.
just plug your tomtom into your computer and start tomtom home
On the computer screen for tomtom select ADD MAPS
Here you can select and buy the maps you need.
Once you have confirmed the purchase you will be given instructions on how to download etc
Some maps may take a little time to install to the tomtom itself.
you should also ensure there is enough space on your tomtom
If not you will have to get an SD memory card.
I use a 4gb one that still has lots of room to spare
Jun 07, 2009 | Tomtom ONE 3rd Edition GPS
I am going to Hawaii from my home in Sydney Australia and wish to down load the maps from Hawaii so that I can use my TomTom during the trip. How do I go about getting the maps? Bernieh
over here
http://www.tomtom.com/products/maps/
Traveling abroad?
If you are visiting another region or country but do not have the map pre-installed on your TomTom device, simply get an additional map and you’re set to go.
click the goto map shop link on the page.
Oct 19, 2008 | Tomtom GPS
GPS Logo
154 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
