Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Open How Do I Open Ports On My Router 327w
  • samarie3487 Jan 07, 2009
    I am trying to hook up my xbox to the westell through my laptop and my NAT settings are Moderate, how do I change that to Open??
    Genius:
  • 1,269 Answers
Go to this LINK
Posted on Nov 22, 2008
Want to set nat type to open
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Jan 05, 2011 | NetGear DGN2000 Wireless Router
I have a Westell Versalink 327W with a strict nat and I want to open it up for Xbox Live. I have tried port forwarding but that only bumps it down to moderate not open. What should I do?
PS3 and Xbox ( NON BELKIN)
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
May 19, 2010 | Westell Wirespeed VersaLink...
I lost the security code for my westell 327w. need to find code so i can add another computer.
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Jan 01, 2010 | Westell Wirespeed VersaLink...
I cant open port for Zhone 6211-I3-200 Router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
Click Here
for more info
Dec 17, 2009 | Zhone 6211-I3-200 Router
I am trying to open the router ports to allow a ps3 to connect. when i try to play call of duty:modern warfare 2, i keep losing the connection. can you help me open the ports and configure the settings?
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Dec 13, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
HOW TO DO THE PORTFORWARD
For example ,
DNS ==> 53 FTP : 21
Dec 06, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Port Forwarding on NB7Plus4W router
For example ,
DNS ==> 53 FTP : 21
Nov 22, 2009 | NetComm NB5PLUS4W Wireless Router
Westell versalink 327w i need default password
If the 327 was never set up for wireless you need to connect to it with an Ethernet cable and plug that into your Mac and one of the RJ45 ports on the back of the 327. Type http://192.168.1.1 into your browser, this should take you to the Westell Home Page (Your Router). The default for wireless in this router is disable. There are tabs across the top on the page, select Configuration>Wireless>Basic. This opens the Wireless Operation Window. If Wireless is disabled, click arrow to enable. You can also enable and disable encryption in this same window and if you choose to use the basic WEP in the device, the WEP key is on the label on the bottom of the router. If all this is good your laptop should be able to detect the wireless connection, the default is the serial number on the bottom of the router so you will know which connection is yours. REMEMBER TO CLICK SAVE before exiting the window! Hope this helps.
May 21, 2008 | Westell Wirespeed VersaLink...
VPN through Westell Versalink 327w
do you have login access into the Modem/Router?
if yes, look for port forwarding and set it to your IP of your computer. open port 500 or what ever is required by MS fro the VPN
Nov 01, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
80 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Carlos Soto
Carlos Soto
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
